Question about Cameras
I have d 60 and i want to take star trail snap...does it work like that??i mean can i work with this in bulb mode for 1 or 2 hours???
    President:
  • 2,976 Answers
Set it up for manual photos and set your time exposure. Set the f stop for f8.
Posted on Aug 05, 2009
Third brake light not working
On the x Trail, the upper brake light cover snaps off, allowing access to the 5 bulbs. If all are out, the problem is ot a bulb, but probably no signal to the assembly. That is the situation I am now in. Need a wiring diagram to check the wiring
Dec 08, 2012 | Cars & Trucks
How do i change the bulb on my dimplex electric fire 930 3003.9
TO REPLACE LIGHT BULBS
1. Open the steel curtains (remove glass doors if applicable).
2. Remove the log grate retaining screws and remove the log grate.
3. Pull the rear edge of the log set forward by grasping the ember bed by the sides
(handle the log set only by the ember bed and not the logs) and pulling firmly
until the rear tab pops out from under the back ledge, then lift out.
4. Examine to determine which bulbs require replacement.
5. Unscrew bulb counter clockwise.
6. Insert new bulb screwing clockwise.
7. Replace the log set by inserting the front edge, pushing the back down until the
rear tab snaps under the back ledge and the logs are resting against the mirror.
Quantity 4 clear chandelier or candelabra bulbs with an E-12 (small) socket
base, 60 watt rating. Example GE 60BC or Philips 60CTC
CAUTION DO NOT EXCEED 60 WATTS PER BULB
Feb 23, 2011 | Heating & Cooling
Sony wega 70 in new bulb lasted 8 hours now
hello.+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Oct 21, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
My trail sentry will not let me reset the code
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Trail Scout and Trail Sentry camera re-programming procedure.
1) Turn unit on and wait for screen to prompt password
2) Press the enter button and hold until camera switches into 5-digit password mode _ _ _ _ _.
Trail sentry cameras will not indicate 5-digit mode on the screen, but will indicate _ _ _ _ instead of HHHH .
3) Press enter to confirm 5 digit mode (for trail scouts go to next procedure).
4) Enter 5-digit code 66214 and press enter button( trail sentry cameras will accept a 5th Digit after the 4th 0ne is entered in the _ _ _ _ screen.
5) Camera will now go into operating mode, and user can now program a new password from the setup mode
Oct 04, 2009 | Bushnell Trail Sentry 11-9200 Digital...
Thermastat on LG Split system
The star with a face is sleep mode, each time you press it you will see a 1 then 2 then 3 up to 7 appear in the lower right corner of the screen. This means that the unit will operate for 1 or 2 or 3 hours then switch off. The house with key if pressed will give you the actual room temperature assuming the remote control is in the same room. It will return to setpoint temperature in a couple of seconds. The triangle with face is termed "Chaos mode" The unit will stay on a preset temperature probably 18c but the airflow will vary and the louver will go up and down irratically or randomly, as it tries to immitate a natural breeze. The fan only button will put the unit into fan mode (no compressor driven cooling), the fan icon with circle around is for fan speed which goes up each time it is pressed. Hope this helps.
Jan 21, 2009 | LG LSC121PMA Split System Air Conditioner
Using Moultrie I-60 trail camera. We do not always get color pictures in daylight hours. Even though the info strip indicates sunny or partly sunny conditions, we often have only black and white...
THE I-40 & I-60 ARE KNOWN TO PRODUCE SOME B&W PICS DURING DAYLIGHT HOURS. ALSO THE DIRECTION CAMS ARE AIMED,I.E., FACING EAST, WEST WILL AFFECT TIME CAM SWITCHES TO IR MODE...
Oct 16, 2008 | Moultrie MFH-DGS-200 Digital Camera
Taking a picture
it is 1/60 mode change it...
1/60 mode means it will take a scene 1/60 of the seconds....
change the mode and then try... your problem will be solved...
change to normal mode...
there are many modes available in ur cam just like 1/80 etc & so it means it will take 1 photo for 60 seconds i think i dnt know exactly but by changing this mode to normal mode you problem will be solved...
by using this 1/60 mode v can clearly see in the photo the dirt and grit also.....
Feb 10, 2008 | Canon PowerShot A75 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
