Question about Dishwashers
The spinner for the top rack gets water, but doesn't seem to ever spin.
  • markandpa33 Jul 31, 2009
    The top spinner is not spinning on our Frigidaire Series dishwasher. The bottom one just cranks out the water and spins like crazy. The top one fills with water, but doesn't seem to move.
    President:
  • 1,129 Answers
Sometimes the place where the tube fits in at the back of the inside of the washer chamber has a second hole which has a rubber flap that fatigues and doesn't provide a good enough seal to provide adequete water pressure to spin the squirting propeller, remove the top rack and look in the back to inspect the holes that accomidate the feed pipe for the top rack if there are two one is not used and it may need a flap valve replace it if it appears fatigued or is not closing all the way.
Posted on Aug 05, 2009
  • 11,896 Answers
There are clogs most likely in the spray holes. You can use a toothpick to dig out the gunk in the holes.
Hi there
It sounds like there may be a small blockage causing the pressure to reduce and prevent the spin. Are you able to tell if water goes through the top spinner? This may be difficult to tell as the door would have to be closed.
See if you are able to remove the spinner and find any blockage inside.
If it cannot be removed, attempt to use a needle to clear any possible blocking of each nozzle.
Finally, try to spin it it by hand. Does it spin freely? If so, is it possible the spinner hits a dish in the dishwasher which prevents it from spinning? Test it without disher.
Let me know how it goes.
I look forward to your reply
nLinked
Posted on Aug 03, 2009
  • 10,865 Answers
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Posted on Aug 01, 2009
  • 1,000 Answers
If you can turn the "spinner" freely by hand chances are you have a water pressure problem that is caused by a leaking connection joint at the lower manifold connection, a leaky seal or joint at the upper "spinner" or you could have some debris in the water supply manifold or "spinner" that is plugging the water jet holes you can see in the "spinner"
I would start by removing the manifold and spinner. Check for cracks, broken locks and debris that may need to be cleared.
Remove the trays, generally the manifold and upper spinner snap into place, but double check for screws.
Let me know what you find.
Regards,
Posted on Jul 31, 2009
  • 19,396 Answers
Check that water is getting from the water supply with sufficient pressure.
Check the top arm attachment to the main line.
Try spinning the arm with your hand, ensure that is spinning and wobbling freely.
Check that the impeller pump hose is not clogged.
If you do not find anything else wrong, then it is usually a faulty pump.
Posted on Jul 30, 2009
  • 423 Answers
SOURCE: upper rack spinning device fails to aquire water and does not spin
Jeff, When a dishwasher acts like this, the most common problem is a blockage in the sump area, underneath the lower spray arm. Removing any/all filter and covers down there (screws will need to be removed) and inspecting with a flashlight, remove all debris (watch out for broken glass!)  Also, inspect the "impeller" that is turned by the wash motor for damage or being loose while you are down there.  Reassemble and test out.
If problems remain, the next most common problem is a failed wash motor.  It is common over the years for it to weaken as it heads towards total failure.  These motors, when they fail, can not be repaired, rather they must be replaced.
Please post back with what you find, OK?
Posted on Apr 14, 2009
  • 114 Answers
SOURCE: dishes not clean
There may be a couple of solutions to your problem. First, if you are not rinsing the dishes thoroughly before loading, your sump area in the bottom of the machine will get clogged, thus preventing enough velocity to reach top rack. Second, and most likely, your water inlet valve (or solenoid valve) is restricting. You have a timed fill mode through the timer and if the valve is not opening fully, you do not get the proper rate of flow into the machine. Replace the valve and your problem will most likely be solved.
Posted on Dec 01, 2008
  • 864 Answers
SOURCE: clean on bottom rack but dirty on top
Clean the filter at the bottom of the tub. If it is dirty or clogged the water pressure may not be strong enough to spin the top arm. Make sure also the there is nothing blocking the holes of the spinner arm. If the filter and arm are clear then the pump may be failing.
Posted on Aug 13, 2009
  • 423 Answers
SOURCE: whirlpool dishwasher top Spinner and top rack
First, confirm that the holes are not blocked on these arms. (I did not want to assume you have done this.)
Then check the impeller on top of the motor stem for being loose or worn/damaged - to rule the impeller out. If it is fine, then the motor is failing and too weak to drive the spray arms.
To answer your question, I think the answer is "They don't make them like they used too!"
Posted on Sep 12, 2009
SOURCE: I have a Whirlpool dishwasher that won't clean the
i have a du1148xtpb1 whirlpool dishwasher and the top rake dishes are not getting clean please advise
Posted on Jan 11, 2010
Top rack not getting water to spinner
You likely have one of two problems.
1. The water jet passage that supplies water to the spinning portion is blocked or restricted with a piece of debris or food. I have had good luck cleaning the passages of these sprayers with tooth picks or long pipe cleaners from an art supply store.
2. The main pump that circulates the water for the dishwasher is degraded or not working effectively. This is a much more expensive fix but is repairable.
I would check to make sure that you can spin the top "spinner" by hand and that all openings are clear of any blockages.
Mar 01, 2011 | Dishwashers
You wil have to excuse my lack of knowledge. I am not getting an error code so I don't know what the problem is. The washer has 3 spinners. The top and bottom spinner are spraying water fine, the middle...
Take out the top rack and inspect the pipe nipple that the rack slides onto. Make sure that there isn't any debris stuck in it. Next pull the wash arm in question off (it just pulls off) check for debris (toothpicks are the biggest culprits and food particles (sometimes glass so be careful). You should find something in there. The wash pipe goes from the bottom to the top of the unit, if the bottom one works and the top one works then your clog HAS to be in the middle wash arm. The water clearly makes from point A to point C so C has to have an obstruction or the wash arm is sticking and not spinning freely. Try to spin it my have but really inspect it for debris. Good Luck.
Feb 15, 2011 | Samsung DMR57LF Builtin Dishwasher
DISHES ON TOP RACK ARE NOT GETTING CLEAN TOP SPINNER NOT SPINNING POSSIBLY NOT ENOUGH WATER PRESSURE?
It would help if you provided the make and model of the dishwasher.
Most likely cause of not getting enough water pressure to top rack is the water diverter may be faulty.
Depending on the model - it is a small ball floating in a vertical channel which alternately opens and closes the bottom and top water inlets to the spray arms. Check part at Repair Clinic after selecting make & model of your dishwasher.
Jun 17, 2010 | Kenmore Dishwashers
Dishes on top rack don't get washed. Water
replace the wter conduit that runs up to the top and center spinner arms,after while these plastic conduit outlets get worn by water going thru them and leak past the o-rings installed on them
Apr 15, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
Bottom sray spinner doesn't spin. Computer and
Make sure that the spray bar when lifted by the water pressure is NOT hitting the dish rack OR has excessive friction. Test by manually lifting and turning.
Also the jets must exit at an angle to provide the torque.
Oct 20, 2009 | Amana 24 in. ADB2200AW Built-In Dishwasher
Whirlpool dishwasher top spinner and top rack spinner is not putting out water or very little and not spinning. I have taken apart and cleaned everything including the sump / chopper, can't find any...
Sep 12, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Clean on bottom rack but dirty on top
Aug 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Top rack not cleaning, possibly spinner not spinning?
Try twirling the spinner by hand to see if it is binding. If it looks ok then there could be something plugging the water passage to the spinner. If you have access to a water hose you could run water into that verticle passage pipe and see if there is an obstruction. If so it can be taken apart for cleaning.
May 13, 2009 | GE GSS1800H Built-in Dishwasher
Upper rack spinning device fails to aquire water and does not spin
Apr 14, 2009 | Kenmore 24 in. 16152 Built-in Dishwasher
Dishwashers Logo
226 people viewed this question
Top Dishwashers Experts
