Question about Hotpoint TDC32 Electric Dryer
Hotpoint aqaurius TDC32p dryer
Will not heat can you tell me where exactly the thermostat is to try and reset or change and any other suggestions you may have as to why it isnt heating up a diagram would be very usefull
thankyou for your help
  • dontgivashit Nov 28, 2007
    Drum still turning normally but no heat. I always empty water and filters. Have not called anyone out. My thoughts were Thermostat?? Im lost without it pleeease HEEEELLLPP
  • Anonymous Dec 09, 2007
    i too have a hotpoint aquarius TDC32 that has stopped drying clothes. All the filters are cleaned when used i even double checked them also vacumed all the vents and air ways for the vents. Everything else is working fine (as i can tell before stripping it down) just NO heat
    Problem Solver:
Dont forget to check for a blocked Float Chamber (Where the Water container snaps into).
I had similar problem, changed the stats to no avail. Only then to check the chamber to find it clogged wint wet lint causing micro switch to activate (ie Simulating a Full Container), hence no heat.
Try it out, hope it helps
Posted on Jul 03, 2008
  • 139 Answers
Well there is no diagram but i can advise you that he stats on the dryer are located on the back.. if you remover the panel that protudes outwards. yes the big funny shaped thing at the back.. Once that is removed then you will easily see that the stats are located at the top end with like orange and blue and i thnk white wires going into them .. these are easily replaced and are very common faults,, but make sure you take a visual check of the heater to make sure it is not damaged .. hope this helps..
Posted on Dec 02, 2007
I have a Hotpoint Aquarius condenser dryer model number tdc32p serial number 28101317. Is this a recall tumble dryer please
call ge they'll know i think it's 1-800-gecares look at the model tag or manual to find number
Feb 06, 2018 | Hotpoint Dryers
Hummin noise hotpoint TDC32P dryer
That noise is usually associated with a failed AC motor that turns the dryer drum.
Dec 01, 2016 | Hotpoint Dryers
Do a tumble dryer have a reset button once you have changed the thermostats?
check the heating element they might be the problem if they are not getting any power or are open.
Aug 27, 2014 | Hotpoint Dryers
Can anyone please email me a circuit diagram for the Hotpoint TDC32P condenser Dryer. thanks
on the back of your dryer remove the top six screws and inside the left top corner there is a diagram. Good Luck Tim
Feb 18, 2011 | Hotpoint Dryers
HOTPOINT TDC32P Dryer - No Heat Usual story. Have found the green spot thermostat had gone open circuit but reset it. All three stats including the one over front door test for continuity. Heating element...
Could well be a intermittentt sticking relay, I have experienced this myself, fitting new relay solved the prob, I doubt you will be able to obtain a wiring diagram , in any case , you should not need one.
I would fit a new relay myself if I were you.
Dec 04, 2010 | Hotpoint Dryers
My hotpoint aqaurius WD420 is not drying.
Could be stat or heater .Remove the top cover, and you will see the heater manifold on the right side of washer drum.
The element and stat/s are located on the top of the manifold box.
You willneed a meter to test with, also check for broken wires.
Feb 05, 2010 | Hotpoint Aquarius WD640 Front Load...
My hotpoint aquarius dryer is not got any heat
Most likely reason is failure of thermostat/s or heater element.
As you do not specify model, Ir is difficult to tell you exactly where to locate them, but generally speaking they are at the rear of the dryer.
Hope this helps.
Jan 12, 2010 | Hotpoint Dryers
Tdc32p condenser dryer has low heat only
It could be, also is the condenser taking the water out ok into the drawer, if not they could be a blockage in the pipes and a pump underneath the dryer may be blocked or faulty.
this could be the cause also.
Sep 14, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint aquarius tdc32p not heating up replaced old heating element but still not heating
I had the same problem which turned out to be the thermostat.
You can fix it at home easily with only a screwdriver.
UNPLUG FIRST!
  1. Remove the strengthening bar on the back
  2. Remove the small cover in the centre of the rear
  3. Remove the funny shaped cover from the rear (NOT THE WHOLE BACK PLATE) This will give access to the heating element and the 2 thermostats above it.
  4. Take off the thermostat with a green dot on and look at the bottom metal plate. If it's concave, bang it on the floor until it pops back out. (Seriously)
  5. Re-fit the parts in reverse order and you done!
Nov 08, 2008 | Dryers
Changing the thermostats on a TDC 32 P
your stats are at the back of the dryer take the metal cover off at the back u should see your stats straight away the cover should be the one that sticks out more than your back casing m8
Aug 27, 2007 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
408 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
