Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Exlim camera my camera makes a funny gurgling sound when i turn it on or off.  it has not been:  dropped, or near any water.
  • ZoSkee07 Mar 31, 2008
    same problem
  • 374 Answers
Any kind of sound when it is turned on or off is usually from damage to the lens. Send it into repairs and they will send you an estimate on what it would cost to fix it. Give them a call at 800-706-2534 option 2.
Posted on Apr 05, 2008
Gurgling sound dash
Depends.
It could be water trapped inside the heater box, or air in the cooling system. If the sound happens when you take off from a stop, it could be low on coolant. If it happens when you are making a turn, it could be water in the heater box. The drain could be plugged up.
Feb 24, 2014 | Jeep Cars & Trucks
Freezer gurgles
    • Give it mouth wash lol
      Check the water valve on the back of the refrigerator if it has an ice maker. Make sure the valve is turned completely on and not constricting the flow of water to the refrigerator via the water supply line. You might also hear a simultaneous buzzing sound when the gurgling noise occurs. In some refrigerator models, this filling process is on a timer, and you might hear the buzzing and/or gurgling every 15 minutes or so.
    • Check the water supply line for leaks or damage. You might see a puddle of liquid on the floor. If air is pulled into the water line as the refrigerator is pulling in water, that can create a gurgling noise. Replace the damaged hose yourself, or contact an appliance repair technician for assistance
      • f he refrigerator to feel a slight vibration. This is probably the compressor processing the refrigerant, which is a liquid. This flow of refrigerant can produce a gurgling sound, and it is normal. However, a simple way to reduce this noise is to make fewer trips to the fridge. When you open the door, you let hot air in, which means the compressor has to work harder (and gurgle the refrigerant more) to cool things back down.
    • Wait while the refrigerator completes its defrosting cycle if you hear water dripping and gurgling in the freezer area. When the heating coil turns on, the melted water from the frost flows down to a drain pan for evaporation to take place. The defrost process usually takes about 30 minutes. This is automatic and cannot be prevented in most refrigerators. Keep the closed to try to prevent unnecessary frost buildup.
    • Wait while the water equalizes in the refrigerator if you hear a gurgling sound when shutting the door. This is normal and is a result of air being forced through the drain tube. The gurgling can last several seconds but should eventually dissipate this usually happens with old fridges upgrade its a good investment
Dec 10, 2013 | Freezers
My culligan water filter makes a gurgle sound
The reverse osmosis faucet you have incorporates an AIR GAP to prevent cross contamination to the RO system. The waste water first goes up the to RO faucet AIR GAP and then goes to drain. The "gurgling noise" is the waste water going to drain. Some of these are much noisier than others.
RJ
Jun 10, 2010 | Culligan Under Sink Water Filter
Door was left very slightly open. reclosed but so...
This is normal when compressor starts u can hear some gurgling from evap. from feron flowing. If you hear gurgling only when you close the door it's water in drain pan when you close the door air is forced down drain tube blowing air into water.
May 17, 2010 | Freezers
Casio Exlim Z6. Lens stay out when camera is
Please view my FixYa Tip on this subject for a complete walkthrough of the potential causes and solutions.
http://www.fixya.com/support/r3556007-camera_lens_stuck_or_wont_retract
Many thanks for using FixYa.
Dec 18, 2009 | Casio EXILIM Card EX-S770 Digital Camera
My engine is making a gurgling grinding sound near
Is the coolant system completely full? It may have air in the system and what you are hearing is the air trying to pass the water pump.
You could also be hearing the valves and air flow through throttle body.
Nov 23, 2009 | 1991 Geo Storm
Casio exlim EX- Z29 lens error upon power on
If you've recently dropped the camera you may have damaged the lens tube (housing) or jarred the zoom mechanism off of its track -- either of these problems will require professional repair. If the camera has not been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may be too weak/worn to properly power the camera, or the camera may require professional repair.
Oct 16, 2009 | Casio Cameras
My casio exlim camera lens dropped and now my camera won't turn on nor take pictures
you've got a problem with your camera power management system. if you can open it try to follow where cables nor conductors from battery are going and check them physically.
Apr 28, 2009 | Casio Exilim EX-Z50 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
35 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
