Question about HP LaserJet 3380 All-In-One Printer
Paper gets stuck in ADF Feeder
Tried the ideas and links shown in your solution. Problem is, the paper is now in little bits and part of it is still stuck in the ADF feeder. Any help would be appreciated. Thanks,
  • 3 Answers
It sounds like you could need an adf assembly replacement
Posted on Jul 31, 2009
What does ADF document mean?
"Document in ADF", usually means that there is a document in the Automatic Document Feeder. Or to put it differently, there is a paper jam in the document feeder (probably of the scanner part).
The fix is to check the feeder and clear the jam. Sometimes it indicates there is a piece of paper stuck or a faulty paper detector.
Dec 26, 2014 | Office Equipment & Supplies
Need to remove piece of shredded paper stuck in the c309a ADF but can't unscrew the screws.
This video will show how to remove a part to get to a stuck piece in your printer's ADF. Hope it helps:
WP_20170601_002.mp4
http://www.303electronics.com/
May 29, 2017 | HP Photosmart Premium C309A All-In-One...
Paper feeder is off so paper gets stuck
Hello , sometimes what happens is that there could be objects blocking the path of the paper on one side. Maybe a paper clip or a pen, I have seen this many many times. Just turn off the printer and remove the paper from the feeder. Unplug the printer from the power cord. Then flip the printer upside down and shake it a little most of the times you will find something stuck in there and it will fell down. If you do not find anything maybe then there is something wrong with the feeder roller. Also try the following link http://bit.ly/9nrlMW
Feb 03, 2010 | Lexmark X5150 All-In-One InkJet Printer
Cutting off when i scan threw the adf feeder
Check if the paper size selected is same as that of the paper fed in. Clean the sensor in the ADF and remove if any scrap of paper is stuck.
S. Mohan
Oct 08, 2009 | Fujitsu fi-4750C Flatbed Scanner
When paper is going into the paper feeder it is is getting wrinkled immediately and jamming the feeder
Sounds like someone got something stuck in the ADF (Auto Document feeder). See if it looks like the paper is really getting wrinkled up more on one end than the other and focus on that side of the feeder. I have seen post it notes cause this problem. People put in their originals and forget to remove post it notes before feeding the documents through. They come off and get stuck in the feeder. Without more detail it is hard to say what is stuck in there but it sounds like there is something impeeding the paper path. Shine a flashlight in there to see.
Oct 03, 2009 | Minolta Di3010 Copier
Paper stuck in adf of HP Laserjet 3380
Please follow the instructions for clearing the paper jam outlined in this article from the HP online support site. Here's another link with info on the manual feed in case you need it, and the home page for your printer in the event that a manual would help.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 20, 2009 | HP LaserJet 3380 All-In-One Printer
I have a message coming up that I don't know what it means.
ADF = Auto Document Feeder (Usually on top)
RADF = Rear Auto Document Feeder, (On the back)
Something is stuck in one of these, a piece of paper, foam, paperclip, twist tie . . . it could be anything. Follow the squealing sound and check the paper feeder rollers.
Find what is in the way and remove it.
Cheers.
Jun 22, 2009 | Toshiba e-Studio 161 Copier Copier
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
My HP printer paper get stuck in top feeder whenever I try to fax
Lift the cover to the ADF (Automatic Document Feeder) and remove any paper debris from the rollers. Also, clean the rollers with a very damp cloth and a dab od dish washing detergent.
Also, check to see that the spring loaded lever is in place.
Clear the jam from the automatic document feeder (ADF)
  1. Make sure the product is turned off and the power cord is unplugged.
  2. Grasp the upper edge of the automatic document feeder (ADF) assembly and open it.
  3. Raise the roller assembly.
  4. Gently remove any jammed paper from the ADF.
  5. Lower the roller assembly.
  6. Close the ADF assembly.
  7. Plug the power cord back into the product.
  8. Press the Power button (c01346625.gif ) to turn the product on.
  9. Try the print job again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
ADF document feed
Hi, The problem seems to be a piece of debris , paper stuck in the ADF roller assy. You can check this by opening up the adf cover and inspecting the paper path. I have seen where a very small peice can cause paper path problems to where something is blocking the paper> Good Luck!
Dec 03, 2007 | HP 5590 ScanJet Flatbed Scanner
HP LaserJet 3380 All-In-One Printer Logo
73 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
