I have sennheiser wireless head phones not able to plug in to my smart tv I have 1 red cable 1 black 7 years old many thanks
5 Related Answers
Anonymous
  • 363 Answers
  • Posted on Sep 30, 2007
SOURCE: headset not working
A modulator is designed for the reverse of what you are trying to use it for. It is meant to be a local TV transmitter i.e. video and audio source INPUT for the TV. It converts A/V to a UHF radio signal that the TV can receive. If the TV has no audio OUTPUTS or headphone jack then headphones cannot be used with this TV. As for the new problem with the TV, I'd like to think this is co-incidental and not your fault. The fantastic thing to do would be to go and buy the lady an LCD TV of a the biggest size you can afford. Most have a headphone socket.
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Jan 25, 2008
SOURCE: TV makes chirping noise, won't turn on!
That usually means a problem in the start up or deflection circuits. Diode, Horizontal ouput or driver transformer. What Chassis is this set, and I will be ableto give you some better information. Rca , GE and phillips need to be diagnosedwith the chassis number. Let me know the chassis.
Anonymous
  • Posted on Jul 26, 2008
SOURCE: MAGNAVOX 51MP6200D/37
I also have the same problem this TV is garbage!! everywere I go on the internet I here the same thing, but NO solution has anyone fix there TV ,and what was it??????
Anonymous
  • Posted on Dec 17, 2008
SOURCE: Hooking up Xbox 360 to JVC TV 20 inch 1 year old tv from Luxembourg
change the plug on the back of your xbox 360 from hd to tv unless of course your tv is hd then change it to hd :]
ginko
Ginko
  • 19396 Answers
  • Posted on May 22, 2009
SOURCE: toshiba 50HX81 projection 'tv- blinking red light
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Should I hook it up to my cable box or tv?
Hook it to the TV. That way if you play a dvd you'll hear it. Cell phones will interfere, as well as cordless phones, so there's not much to do about that.
Sennheiser 126 connect to tv
You should be able to hook the tv to the cable box the cable box should have your A/V jacks. If so unplug the PS3 plug in your receiver to the cable box and run the PS3 through the receiver. Also check the side of the tv for HDMI inputs if you have HMDI you can go to Radio Shack and get a converter to go from HDMI into A/V
2helpful
Red and white cables?
My Sennheiser comes with a black and red cable. I plugged the red into the red in the back of the tv and the black into the white in the back of the tv and it works for me. Hope this helps.
HOW DO I CONNECT TO TV
There are many methods to do this.
If your cable are ONLY RED,WHITE,YELLOW
1 Plug the red white and yellow cables to there corrosponding jacks on your DVD player
2 Plug the red white and yellow cables to jacks labled video IN, Audio IN. They will be colored on the back of your Tv
3 Plug in the power cable.
4 Turn it on and flip through the inputs on your tv until you see the picture
IF your cables are RED, GREEN, BLUE, RED, AND WHITE
1 Your are using what is called conponent video. This is a high definition video.
2 Three of your plugs are for video. They are Red(Cr) Green(Y) and Blue(Cb)
3 Plug the GREEN into the Y jack
4 Plug the RED into the Cr jack
5 Plug the BLUE into the Cb jack
6 Plug your power cable int o the wall if you havent alredy done so
7 Plug the other red cable into the audio right jack
8 Plug the white cable into the audio left jack
9 Turn it on and surf through the input until you find it
If you have a BLACK, RED and WHITE
Do the same as RED WHITE and YELLOW but
1 Put the black cable into the s-video slot
2 Surf through the inputs until you find the picture
If you have ONE BLACK CABLE
1 This is called HDMI(High-definition multimedia interface)
2 Plug one end into the tv and the other inte you dvd
Thank you for your time, Good luck and I hope this works
I HAVE THE HDR130 WIRELESS WHICH I HAVE NOT USED FOR A WHILE. I HAVE LOST THE INSTRUCTIONS FOR WIRE HOOK-UP TO A FLAT SCREEN TV. COULD YOU LOCATE THIS INFORMATION AND SEND IT TO ME? IF YOU CAN NOT E-MAIL...
when you pur chse wi fi head phone u get 2 thing 1 head phone and other wireless outlet which connect with cable to TV .
Coonec *** to TV with cable in sound output jack of TV .
then switch on headc phone check its battery cell are ok/.
Top Sennheiser Audio Players & Recorders Experts
 Grubhead
Grubhead
john h
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
