Question about Asko T761 Electric Dryer
Asko T760 Dryer - Computer Screen Blank
The computer screen on our Asko T760 dryer goes blank. It seems to come back on when we go from AC power to generatror (the drjyer is on a boat). Help.
    President:
  • 1,922 Answers
You have either a frequency related issue or there is a lot of t.h.d. total harmonic distortion on the line, this will raise cane with electronics, I would try a power line conditioner on the dryer power circuit
Posted on Sep 26, 2009
The dryer stopped in the middle of a load, the display showing fast up-scrolling numbers...clearly faulting. Upon resetting it, including pressing back button, unplugging it, power button off/holds, I can...
It seems that the main board, the program controller unit is a suspect and to confirm you need to remove the customer control panel and check . Check the +5 to the processor, check the connectors and the power supply, check for leak in the storage electronic capacitors, check for faulty voltage to the control board.- check rectifier and regulators.
If not the fault can be the processor which must be confirmed with a data check or oscillations of the crystal.
Sep 29, 2011 | Asko T761 Electric Dryer
My dryer stopped working this morning. The light to the on switch is "on," meaning it's red. But everything else looks dead: The start button doesn't have a light. And, the display panel is...
If it there is power in the system (red light on power swithch),yet the dryer does not run - with a totally blank LED screen (no error message), the controller board may be out. You can snap in a new one (remove the top of the dryer, take picture to make sure you know where the wires go) remove from clips n replace. Only thing, it'll cost you $220 to buy a new one. Try repairclinic.com - if it doesn't work you can return for full refund.
Mar 11, 2011 | Asko T731 Electric Dryer
ASKO T760 has no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 31, 2010 | Asko T761 Electric Dryer
Monitor screen goes blank
Check the chord of your monitor connected AC Supply.
Mar 16, 2009 | Toshiba Tekbright 15" CRT Monitor
Screen going blank and laptop freezes.
Go into the diplay properties, under the screen saver tab there is a button marked power, open this. Under one of the tabs there is a section that reads, when I close the lid, under this section set it as never.
Jul 10, 2008 | Dell Inspiron 1000 Notebook
Asko t760 display panel
My Asko T761 had the same problem, power button lights up but the LCD panel if off. This is not the fuse becuase I replaced with "new fuse replacement kit" provide by Asko but this did not solve my problem. All I needed to do was press the "reset button".
Feb 08, 2008 | Asko T761 Electric Dryer
Asko T761 Electric Dryer Logo
362 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
