Question about Arris High Speed DSL Modem
I need a power cord
Lost the power cord, no manual, no idea of volts amps required
  • 76 Answers
The is no volt or amps for a power cord, that is for power adaptor, you can use any cable that fit in your modem adaptor.
Posted on Feb 09, 2010
    Novelist:
  • 169 Answers
Go to makers web site click support and input model number and serial number then download manual.
spec for power will be in manual or maybe they sell psu unit for modem
Posted on Sep 15, 2009
Power from electical outlet to power a travel trailer,AC,MW,LIGHTS 110to 220
all trailers use 120 volts a 30 amp cord 3 pronged is wired a hot a neutral and a ground a 50 amp cord 4 pronged is 2 lines of 120 volts but its not 220 volt it has 2 separate 120 volt hot lines a neutral and a ground you should see a dealer to explain for safety
Jun 30, 2013 | Cruiser RV 2013 Fun Finder X X-214WSD
Where do I get a new power cord for the HP 3970 which has been in storage for a while, but I want to begin using it agains, and can't locate the power cord. HP has discontinued this model and nothing on...
The correct part number for just the "brick style" power module (AC Adapter) for an HP Scanjet 3970 is L1970-80003. It is a specific 12V DC 2 Amp module. Today it can be purchased for $18.06 plus shipping from the HP Parts Store. However, if you are looking for just the power cord to your scanner's AC adapter, this brick style power module AC adapter does require a separate standard C13 detachable power cord to the specifications of your area, for instance, in the USA the power cord to connect the scanner to the power module AC adapter is part number 8120-6260, and it is a common power cord for monitors and computers. I learned all this because I had a scanner error message when I tried to use a different power module on the HP Scanjet 3970 when I lost the power cord to the original module. I hope this info helps somebody else, too.
May 24, 2010 | HP ScanJet 3970 Flatbed Scanner
I lost my power supply cord when I moved. Where can I find another for a model USB 1930-52?
Hello,you can buy one AC to DC voltage converter (usually 1000mA) - which comes with multiple output tips and you manual setting the Volt that are required by your burner(check behind of your burner near the socket that you plug the power it should right ..Volt and the mA or AMP) and adjust the converter
Jan 20, 2010 | Pacific Digital X-treme CD-RW Burner
I lost my power cord for my seagate freeagent pro 500g en route to iraq and can't figure out what the power requirements are, how many volts and amps, i don't want to short it out
  • Power Specifications:
  • Input: 100-240Vac, 50/60Hz, 0.55A Max. 50VA-80VA
  • Output: 12Vdc 2A
http://www.evertek.com/viewpart.asp?auto=41485&cpc=PPI
Good Luck and thank you for serving.
Jul 07, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Lost power cord
Specifications:
  • Manufacturer: HP
  • Input: 100-240V, 50/60Hz
  • Output: 32V, 16V
  • You can get more information here:
    http://www.unitedsale.com/product_info.php?products_id=18583
    Please vote me if you like my post.
    May 25, 2009 | HP Photosmart 2610 All-In-One InkJet...
    What type of powercord and outlet does this dryer require? Electrician installed a 220 outlet.
    ELECTRICAL REQUIREMENTS
    ELECTRIC Dryer
    CIRCUIT - Individual 30 amp. branch circuit fused with 30
    amp. time delay fuses or circuit breakers.
    Use separately fused circuits for washers and dryers, and DO
    NOT operate a washer and a dryer on the same circuit.
    POWER SUPPLY - 3 wire or 4-wire, 240 volt, single phase, 60
    Hz, Alternating Current.
    POWER SUPPLY CORD KIT - The dryer MUST employ a 3-
    conductor power supply cord NEMA 10-30 type SRDT rated at
    240 volt AC minimum, 30 amp., with 3 open end spade lug
    connectors with upturned ends or closed loop connectors and
    marked for use with clothes dryers.
    WARNING – Risk of Shock. Appliance grounded to neutral
    conductor through a link. Grounding through the neutral link is
    prohibited for (1) New branch circuit installations (2) mobile
    homes; (3) recreational vehicles; and (4) areas where local codes
    do not permit grounding through the neutral, (1) disconnect the
    link from the neutral, (2) use grounding terminal or lead to
    ground appliance in accordance with local codes and (3) connect
    neutral terminal or lead to branch circuit neutral in usual manner
    (if the appliance is to be connected by means of a cord kit, use
    4-conductor cord for this purpose). USE COPPER CONDUCTOR
    ONLY. The dryer MUST employ a 4-conductor power supply
    cord NEMA 14-30 type SRDT or ST (as required) rated at 240
    volt AC minimum, 30 amp., with 4 open end spade lug
    The complete installation manual is at ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134917700es.pdf
    Jan 28, 2009 | Frigidaire FEQ1442ES Electric Dryer
    Lost Charger
    yes take your player to radioshack and get a new power adapter the reason you take player with you is to get the proper power rating in volts and amps which usually is printed near terminal where you old adapter plugs in on on a sticker on the bottom of the dvd player or try ebay:
    search.ebay.com/kawasaki-dvd-player - 67k
    Jan 23, 2007 | kawasaki PVS-10921 Portable DVD Player
    Arris High Speed DSL Modem  Logo
    230 people viewed this question
    Top Arris Computers & Internet Experts
    bobkoure
    Level 1 Expert
    Jerry
    Jerry
    Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
