Question about Janome Sewing Machines
EVERY TIME I START TO SEW THE BOBBIN JAMS UP WITH A WAD OF THREAD AFTER ONE OR 2 STITCHES
  • Janome Master
  • 1,388 Answers
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
EVERY TIME I START TO SEW THE BOBBIN JAMS UP WITH - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
www.bargainbox.com.au
Posted on Jul 30, 2009
Thread jams when I sew.
Hi
Try changing the needle.
if not check your tension and make sure its not to slack
Jul 15, 2015 | Sewing Machines
LOWER BOBBIN BINDING UP
Readjust the needle timing and check the thread tensions top and bottom.
Jun 09, 2013 | Kenmore Sewing Machines
My thread keeps breaking and the bobbin tension is too loose
adjust the top thread tension one number or letter higher at a time
and sew on a scrap piece of fabric till the stitches look normal
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Jan 15, 2013 | Sewing Machines
Pixie plus bobbin housing
if you have the reciept for the machine, I'd take it back & get another one
maybe some place else
Feb 23, 2012 | Singer Pixie Plus Sewing Machine
My bobbin wont engage with the stich. it just keeps getting jammed up. i lost the manuel i have no idea what to set the tension.
Try these solutions
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
* When you start to sew a seam, Hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
Dec 24, 2009 | Sewing Machines
I am having trouble with my bobbin . When I put into the sewing machine and begin to sew the cotton just bunches up and jams . Any suggestions
Here are a couple of things to try.
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
Hope this helps.
Sep 13, 2009 | Husqvarna Designer I
I have a Shark Intelli Sew 9110 Euro Pro. It was
There is no solution for that problem. My machine was doing the same thing, I returned it for "repair". Got it back 2 wks later and had the same problem. Just the other day, the machine did that, and then something "popped" and now the upper thread won't catch the bobbin thread. I called Customer Service and was told that if I want my machine repaired, I have to send them a check with the machine for $81! Your best bet...get rid of the Intelli-Sew and buy something that doesn't break every month or so!
Aug 16, 2009 | Euro-Pro 9120 Computerized Sewing Machine
Kenmore 385 model Automatic Button Hole Apparatus Jams Thread?
Practice and practice some more! Use the same fabric and interfacing as your project and a NEW needle (the correct needle) This is for the Sears Kenmore 385 automatic button hole maker. Make sure you pull the bobbin thread through the Guide Block - it is that simple. Make sure you pull your thread to the back of the machine though the presser foot slot - the correct presser foot. Account for both thread tails before starting to sew. Keep thread tails to the back of the machine 4-5", insert fabric under presser foot keeping thread tails clear. Mark button hole and sew.
Mar 30, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Mar 15, 2009 | Singer 3116 Simple
Sewing Machines Logo
164 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
