Question about Hoover Vacuums
Taken Hoover sprint quick vac completely apart. Down to last clear filter how can I get to inside?
  • 7 Answers
SOURCE: pwr cord rewind reel
You have to pop the grey button off for the cord rewind. There is one more screw under there. You have to be very careful, because you can break one of the tabs that hold the button on. In fact, it is almost a garuntee. There are three tabs that stick off the button that hold it in place on the orange hood. There's a long tab about 3/4 inch long on the inside corner of the button you need to be careful of. Good luck!
Posted on Jan 09, 2008
  • 71 Answers
SOURCE: poor suction (new bag, clean filter, clear hose)
check the impeller on the moter it may be missing a fin or two (question does it make any unusual noise or vibration ?)
Posted on May 02, 2009
MNfisherman
  • 11896 Answers
SOURCE: Dyson Animal with no suction from floor brushes
Check the canister seal for dirt or gaps. This is normally where the vacuum leak is.
Posted on May 14, 2009
bomark2002
  • 160 Answers
SOURCE: MY hoover steam vac hand held hose cleaner leaks profusely
try taking a sharp knife and shaving a little off the edge of the plastic, or a small file if you can get to it, see if it is getting binded. If its getting stuck internally, you will have to replace the switch instead of risking takin it apart.
Posted on Jul 09, 2009
  • 190 Answers
SOURCE: how do I clean the nozzle of my Hoover steam vac Jr?
No, this assembly can only be rinsed under running water.
Posted on Oct 03, 2009
Motor housing is hot
This model has 2 side filters, check and clean those. Be aware that this is a quick clean vac, not to be used for extended periods of time to replace a full size upright. clean the inside filter in the dirt cup.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Apr 16, 2010 | Hoover S2220 Flair Bagless Upright Vacuum
Hoover steam vac deluxe - no suction and the scrubbers aren't spinning uless you tilt off the floor.
I would suspect that your turbine assembly bearings need to be replaced. also check for debris inside the brush assembly. check the intake filter under the front clear cover. verify the recovery tank lid is on securely, as well as the foam filter on the tank lid is clean.
Oct 10, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
How do I clean the nozzle of my Hoover steam vac Jr?
Sep 29, 2009 | Hoover F5411 SteamVac Jr. Canister Vacuum
Dirt Devil Extreme Quick Vac - Won't turn on
Check that the filters are completely clear and not blocked - especially the top filter on top of the bin assembly. If its clogged completely brush it free of dirt and then reassemble. Make sure the inner cone filter and mesh filter is also completely clean. Then check the hose and main dust channel - something is clogged that makes this machine overheat and stop working - and often with this model (Hoover also make it in the UK under the Alyx name) its down to clogged filters or small clogs of dust in the dust channels.
Don't forget to rate, thanks.
Mar 06, 2009 | Vacuums
Have an old Hoover steam Vac and it will spray the cleaner down but will not **** up the cleaner. The red ball keeps coming up right away. What is the problem?
Check the filters, make sure they aren't clogged. Also if this has the foam filter on the inside of the tank lid, make sure it has at least a 1/4 is gap from the top.
May 17, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Z-400 - Hepa Filter
These filters should be changed at least once a year, they get clogged up and won't clean out. So I would try a new filter and go from there, make sure there are no clogs in the hose and down below where the dirt inlet is.
Feb 20, 2008 | Vacuums
Hoover steamscrubber
I had the same problem. Fixed it by taking the machine apart and lubricating the bearing inside the turo tunnell. It's a pain, but not impossible if I could do you can. You must start by taking off the cover. Don't forget the scvrews on the front by the water vacuum. I used WD-49 and white grease so far so good. The turbo tunnel will come out by itself.
Dec 30, 2007 | Hoover SteamVac F5914-900 SpinScrub...
HOOVER STEAM VAC F5858-910
Check the brush block to make sure that the shaft going into the turbine hasn't broken off, if it is ok, then the turbine is bad and should be replaced.
Dec 18, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
52 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
