Question about AT&T Blackberry Curve 8300 Smartphone
Can you tell me how to erase or delete the icon that displays the number of voicemails that you have? I just activated a new device and have no voicemails, but there is a count icon that says there are 3 messages waiting. Thanks!
    Brigadier General:
  • 7,752 Answers
Take the battery out and try again or check to see if you have txt messages that have not been read.
Posted on Jan 30, 2010
My vetch phone shows "new voicemail". how do I delete this
To clear the "New Voicemail" display from the handset
is a slightly different procedure for each model of cordless
phone.
Try the following (tested on my own cs6229 phone):
press [menu]
scroll to "Clr voicemail"
press [select]
display reads "Turn Off Indicator?"
press [select]
phone will (chirp) press [off ]
Or, this one (tested on my own cs6114 phone):
press [menu]
scroll to "Settings"
press [select]
press [select]
display reads "Reset VM Icon?"
press [select]
phone will (chirp) press [off ] [off ]
Other models, check your manual. The model number
is on a small sticker under the battery in the handset --
enter this number at www.manualslib.com to get a free
copy of the User's Manual.
Feb 13, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
How do I delete my voice from voicemail? I want to redo it.
Go to phone mail and listen to the options. One of them should allow to change. Most phones hold down 1 to go to phonemail
Feb 08, 2015 | Tracfone Wireless Alcatel A392G
How do i delete my masseges
Are you asking about voicemail messages or text messages? Most phones allow you to erase voicemail by pressing the number 7 during or after the message. If you have a touch screen phone and want to erase text messages, try touching and holding your finger on the message for a few seconds...a delete button may pop up. 25254526-ipxh3zptubm5u5d1ogqxpt0r-2-0.png
Oct 24, 2014 | Cell Phones
Unexpectedly, my voicemail has a password. I have no idea how that happened but I can't check my voicemail without a password. Not available in "settings" to change anything it remove this...
Hi, you'll need to restore your iphone as a new iphone it will wipe all the data from your phone but its necessary as if you try to restore your phone and use previous back ups it will bring the voicemail password back...Hope this helps..
Use the following steps to restore your iPhone.
***** IF YOU CANT SEE YOU IPHONE IN ITUNES OR IT IS STUCK AT THE APPLE LOGO - POWER DOWN YOUR PHONE - HOLD DOWN THE HOME BUTTON FOR AROUND 6SECS WHILST CONNECTING TO ITUNES - RELEASE BUTTON - ITUNES WILL THEN APPEAR WITH MESSAGE SAYING IT HAS DETECTED IPHONE IN RECOVERY MODE & CONTINUE TO RESTORE YOUR PHONE - FOLLOW FROM STEP 6! ) *****
  1. Make sure you have the latest version of iTunes installed and running before attempting to update.
  2. Connect your device to your computer.
  3. Select your iPhone when it appears in iTunes under Devices.
  4. Select the Summary tab.
  5. Select the Restore option.
  6. When prompted to back up your settings before restoring, select the Back Up option (as seen in the image below). If you have just backed up the device, it is not necessary to create another.
  7. Select the Restore option when iTunes prompts you (as long as you've backed up your device, you should not have to worry about restoring your phone).
  8. Once the restore process has completed, the device restarts and displays the Apple logo while starting up:
    iPhone only: For the iPhone only, after a restore, the iPhone displays the "Connect to iTunes" screen. Keep your device connected until the "Connect to iTunes" screen goes away or you see "iPhone is activated." If iTunes does not have an Internet connection, you cannot complete this step.
  9. The final step is to restore your device from a previous backup. Once your device is restored and-in the case of the iPhone-in the process of activating, you should be able to see the following in iTunes:
    Select the backup you want for your device and select the Continue button to complete your device's restoration.
If you do not want to restore from backup, select "Set up as new...
Dec 26, 2010 | Apple iPhone 3G
VOICEMAIL iCON ALWAYS DISPLAYED
Your provider can remove the voicemail icon on you screen but you have to contact them of course. Sometimes what happens is the voicemail is exited improperly and what you'll need to do it get back into your voicemail and follow the prompts to exit the system (I believe it is the star button to exit voicemail). What I would do is leave yourself a message, call into your voicemail, delete the message and exit the system. If icon is still on the screen then you have no choice but to contact provider. Good luck and hope this helped.
Feb 05, 2010 | Nokia 6288 Cellular Phone
Voice Message Icon always displaying
The voice mail symbol is sent to your handset by the network when you get a voicemail, they then send the handset another message to remove the icon once you have listened to the voicemail... Sometimes an error occurs and the phone doesnt receive the removal message...
Try getting a friend or using another phone send yourself a voicemail, then using your phone, check your voicemails, listen to the one you have and delete it... The icon should go... However if its a hardware fault with the handset display then this will not fix it...
May 07, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Voicemail icon won't go away.
I've had the same problem as well. I made sure no messages were there, then called and left myself a message from another phone. I went in and listened to the message and waited till the option to delete came on and for the indication there were no more messages. Icon was gone.
Aug 06, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Envelope icon flashing on screen (not voicemail icon)
Try deleting some text messages in the in box this may solve the problem.
Jul 02, 2008 | Samsung Cell Phones
"NEW VOICE MAIL" is stuck on screen
what you do is call your own phone number it will tell you to set up a voicemail account and make a 4 digit pin ....once that is made you can listen to the prompts to listen to your voicemail and erase the messege and the phone will get back to its normal self hope this helps
Feb 17, 2008 | GE 25932 Cordless Phone
Deleted my voicemail key
Use the super key again to program a speed dial key that dials the voicemails number. Instead of selecting 'clear' slect "change" and type in the number. To find the number of the voicemail, go to another phone and press their voicemail key and watch the display. It may briefly display the voicemial group number. You also can dial the voicemail number without the use of a button on your phone. But, you have to know the voicemail group number to dail it. Sorry i dont know the number to tell you, it could be anything that the installer decided to make it.
Sep 27, 2007 | Mitel Superset 4025 Corded Phone...
AT&T Blackberry Curve 8300 Smartphone Logo
66 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
