Question about GE Profile Spectra JBP95 Electric Kitchen Range
Replce smooth glass cook top
I'd like to get some instruction in replacing the smooth glass cook top on my GE Spectra Profile reange. II have had it replaced once already but didn't do it myself. I am handy and am sure I can do it myself with a little help.
  • Anonymous Mar 30, 2014
    need to replace glass top
  • 447 Answers
Id be glad to help from my end. I would reccommend a live chat session while you are working on it so i can give you expert pointers.
Posted on Nov 24, 2007
Can I get a replacement door for my GE Profile Refrigerator
Warners Stellian in Minneapolis can help.
For cleaning DeBruce Polish is the answer.
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Feb 01, 2010 | GE Profile PSW26P Stainless Steel Side by...
Tip
Can you please show me where to order the smooth cook top glass? My range is...
This advice is for Electric Ranges equipped with glass smooth tops. If it becomes necessary to replace the cook top due to wear or damage, here's some helpful tips on how to complete the repairs yourself. NOTE: Cook tops are NOT cheap. Prices vary between models, but most are in the $200 to $300 range. With added labor charges, this repair can cost over $600 from an appliance repair company.
WARRANTIES: Most warranties DO NOT cover cosmetics. That is, if your cooktop paint starts to wear off, most manufacturers will not replace it. Warranties also DO NOT cover accidents such as dropping something on the top and breaking it. Warranties DO cover blistering, warping and heat related breakage (if you are using the recommended cookware). This is why it is important to follow all the manufacturer's use and care instructions that come with your range. I know this does not include ALL manufacturers, but this is true with most.
This is a recommended two-person repair job. Please read through the instructions carefully before starting the repairs, and follow any safety recommendations.
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. If the old cook top is broken, you will need to get rid of a much of the glass shards as you can and thoroughly vacuum the area around the oven box. Use extreme care when handling broken glass. Wear safety glasses and gloves.
3. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
4.On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
  1. Unplug the cook top and leave the elements in place.
  2. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
  3. Remove the surface element assembly leaving all the elements wired together.
  4. Place the new cook top face down in the same manner and lay the surface element with wiring harness directly on to it and screw in place.
  5. Install the new cook top back on the range and you are DONE.
5. If the wiring harness does NOT unplug, follow these steps:
  1. There are a series of screws holding the element assemblies in place. Leave these assemblies wired together for ease of replacing. It is recommended that a second person holds the assemblies in place to support the wires until all the screws have been removed.
  2. Lay the intact element assembly, with wires still connected, on top of the oven box. Handle the surface elements with care. They are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure.
  3. If you have to remove the elements, individually, make sure you write down how the wires were connected to ensure you reconnect them in the right order. Make sure you also take note of the numbering scheme on the element and make sure you place the mounting brackets in the same holes that they came out of. Use care when screwing into the new cook top. CAUTION: The screw holes are usually painted and a little force may be required to thread the screws. Do not apply too much pressure on the glass, or you can damage it.
  4. Prop the new cook top in place and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
  5. Lower the new cook top into place and secure with screws.
    Good luck and I hope this helps.
on May 03, 2009 | GE Spectra JBP78 Electric Kitchen Range
I have scratches on my stove top, what can I do to erase them?
  • Firstly clean with DeBruce Polish to clarify area.
  • you may have to "re-grain" those finely scratched areas.
  • Blend or "scratch out" the misdirection scratch's with new "controlled" scratching, useing a 3M scotch brite #7447 you get at auto parts store (Nappa). Use medium very firm pressure.
  • -Re-clean with DeBruce Polish. Touch ups are now a breeze
  • Dec 23, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    The glass top on my Spectra feels smooth but the burner area is turning black. How can I return it to it's spectuled gray?
    if its a build up you can use a razor scaper after you warm it up just a bit
    'warm the burner do not get it hot
    then scrub the dust with a non abrasive pad/sponge
    with a chem. called cryramabrite
    Oct 04, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Discolored cook top
    We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
    Apr 10, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Stains on glass top
    This is smooth glass - you can use a razor blade on it. Hope this helps!
    Jan 13, 2009 | GE Profile Spectra JBP95 Electric Kitchen...
    Replacing glass top on stove
    its not too bad.kill the power.then under the frount of the top where the top meets the oven door .under there are screws remove those and the top lifts up as on hinges.their is a ground screw wire to loose and unplug the the wire harness that connects the burners to the rest of the stove.then all is disconnected so lift entire top off from hinged area and set upside down on table.transfer all burners to new top thats nexted to old one upside down also.when done reinstall.ive done lots wont be bad.please dont for get to help me with my rateings.God bless ,tom
    Jan 05, 2009 | GE Profile Spectra JBP90SFSS Electric...
    Cracked glass top
    Your crack was most likely cause by a flaw in the glass top. Most GE smooth-top ranges (espesially if manufactured prior to 1/1/06) have a five year warranty covering this type of failure. The labor is not covered after the first year. Check the back pages of your use and care book for warranty info on your model. I'd advise against continued use of the cook top with a crack, as spills can get to components and cause further damage.
    Aug 21, 2008 | GE Spectra JBP78 Electric Kitchen Range
    I also have a ge spectra with a broken glass.
    Jan 14, 2008 | GE Profile JTP18 Electric Single Oven
    Ge spectra glass top stove.
    Two possible reasons come to mind.  1. There most likely was a short circuit that activated the top unit. Was any part of the top glowing when you looked at it while it was crackling?
    2. Be aware that glass tops CANNOT take as heavy a load of pots and pans as a STANDARD range can. The glass will crack. The stress can accumulate over a period of time and you will be left with the 4 am  madness dim experienced.
    If anyone out there finds themselves in a similar situation, don't wait when  you hear the crackling. Pull the the range plug, or find the ranges circuit breaker in your electrical box and turn it off.
    Nov 24, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE Profile Spectra JBP95 Electric Kitchen Range Logo
    219 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
