Question about Samsung SF-340 Plain Paper Inkjet Fax
What direction paper to fax out - Samsung SF-340 Plain Paper Inkjet Fax
    President:
  • 3,085 Answers
Face down
Posted on Jul 30, 2009
I CAN'T SEND FAX WITH EXTENSION NUMBER
Generally if you wanted to send a fax to a facsimile which is connected to an extension.you must dial only the direct line number and ask operator to transfer this call to fax (wanted extension).After you heard the fax tone you can push start button.
If the fax machine full-time connected to same extension & dedicated direct-line there only for faxing,we can program the pbx for automatically transfer the incoming fax or call to that extension.so outsider have to dial only direct fax number without ext no.
Only Panasonic PBXes having a unique feature if i'm wright if it detect fax tone from any direct line it will automatically transfers towards fax extension.
Mar 24, 2014 | Panasonic KX-FL611 Plain Paper Laser Fax
How do I unjam a fax machine 1010
to clear document jam:
1 Open the front panel.
2 Carefully remove the jammed document.
3 Close the front panel firmly until it clicks
into place.
If the fax paper jams while you are receiving or printing, Remove jammed paper and press
Cancel appears in the message.
if the paper is jammed in the printing area
1 Remove the jammed paper by pulling it out
smoothly in the direction of the arrow as
shown.
If the paper tears when it is being removed
check to ensure that no small pieces have
been left inside the machine.
2 Press Cancel.
3 If this was a fax, reprint the fax. For more
information, see reprinting faxes on
page 29.
if the paper is jammed in the paper feed
area
1 Remove the jammed paper as shown.
removed check to ensure that no small
pieces have been left inside the machine.
2 Reload new paper with the print side
facing toward you.
3 Press Cancel when finished.
May 04, 2012 | HP 1010 Plain Paper Inkjet Fax
CHECK 5100
Jams in the Document Tray
When a document jams or misfeeds in the Document Tray, CHECK 5100 are displayed on the LCD.
When CHECK 5100 is displayed
1 Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2 After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jams in the Multi-Purpose Tray
If paper jams in the Multi-Purpose Tray, CLEAR PAPER JAM is displayed on the LCD.
1 Gently pull any jammed paper out of the fax as
shown, then press [Stop].
Pull it gently in either direction.
If you cannot pull the paper out, continue with the steps below.
2 Open the Printer Cover.
3 Gently remove the jammed paper inside the fax.
4 Press [Stop].
The fax returns to standby mode.
Feb 20, 2012 | Office Equipment & Supplies
IN WHAT DIRECTION DO TO PUT THE PAPER IN TO FAX
directly above the control panel you will see the tray where to put in the document you want to fax, load the document top edge first face down, lcd should change to enter fax no & press start.
Please rate if this helps
Thanks, vikroks
Mar 25, 2011 | Brother IntelliFAX 1270E Plain Paper Fax
My fax machine states 'fax RX in memory' and does not receive any faxes?
There is a Fax in memory. Either, the machine has a paper jam, is out of paper, or needs the ink cartridge replaced. Fix the above and the fax will print and the machine should work in Fax mode again.
For a unit with paper and no paper jam, try adjusting the paper stack and check if the unit picks up the paper properly. If you have ink in the cartridge, try cleaning the print nozzles and contacts. If a nozzle cleaning from the unit doesn't work, do it manually. Use a damp cloth (lint-free) and wipe in one direction only. Dampen the cloth with bottled or distilled water for best results. See your manual for pictures.
If you need the manual, try the Sharp site or http://www.retrevo.com/support/Sharp-UX-B700-Fax-Machines-manual/id/310bh149/t/2/ .
I hope this helps.
Jan 14, 2011 | Sharp UX B700 Plain Paper Inkjet Fax
NEED DIRECTIONS TO TURN ON FAX RECEIVING MODE
press menu and fax function and choose tel,tel/fax or fax
May 24, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Paper jam
The following is general advice that applies to removing paper jams in most printers, copiers, etc.
Switch off the printer at the wall and unplug it. Remove the paper tray from the printer. Check to see if the printer has an access door in the rear to allow you to see inside (open it). Open any other external flaps (eg. manual paper feed tray) that will allow you to see inside. Open any internal flaps or levers designed for user operation and usually indicated with a green or orange coloured tab.
Always remove jammed paper by pulling it in the direction of normal travel only. Don't try to pull it out against the direction that it entered the printer. Sometimes rollers inside the machine have a knob (usually coloured green or orange) that can be used to manually wind the page through the printer or fax. Always turn in direction of arrow indicated only.
After removing page, return all levers, flaps, doors, paper trays etc to original positions, reconnect power to the printer and test
Mar 08, 2010 | Brother Fax-1360 Plain Paper Inkjet Fax
Size of received/sent fax
you must have the reduction mode on in the fax section. This allows incoming faxes that are larger than the size paper you have available to be printed. You may have you paper set in a direction or size paper that is not the same as the fax being sent.
Nov 17, 2008 | Panasonic Workio DP-1820E Copier
Cannot send fax until I activate the Memory button, want to send "Direct"
Hi rlandriani,
There should be a setting under user paramaters in the menu section that will allow you to change the default "memory on" setting to "off".
The user parameters set on the menu currently can also be printed for you to go through at your leisure so that you can customise the machine to your own personal prefferences.
Oct 17, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Sharp UX B20 Plain Paper Fax
http://www.sharpusa.com/files/fax_man_UXB20.pdf hope this helps Cops
Oct 07, 2007 | Sharp UX B20 Plain Paper Inkjet Fax
Samsung SF-340 Plain Paper Inkjet Fax Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
