Question about LG Washing Machines
Rapid ping and flashing UE
Have an LG wasing machine and near the end of the wash did rapid ping and was flashing UE.
  • 6,784 Answers
This is an Imbalance error code.
One of the following will need to be corrected:
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly
* Door switch assembly is out of order
* Gasket on door may be creased in
Posted on Jul 30, 2009
  • Michael Masters
    Michael Masters Jul 30, 2009
    I apologize. i posted the wrong solution to your issue. please disregard the above solution. the actual issue is below.
    * The load is too small
    * The appliance is tilted
    * Laundry is gathered to one side
    * Non-distributed things are put into the drum
I washed a comforter and my LG washer is flashing UE in the window. I took the comforter out (still soaking wet), and tried to redistribute it. Still reading UE, and i did this 3x. HELP!!
You did not post the model number but if this is the top load model, pull it away from the wall and see if the back of the machine that has a galvanized cover, is dented. If the machine walked and thumped because of being off balance, the internal sensors may be contacting the cover.
Jan 14, 2016 | LG Washing Machines
UE Error Code on LG Tromm Washer
From back or underneath, check that all three shock absorbers are attached. Take top off and check if both springs are in place and un broken
Mar 22, 2017 | LG Tromm Front Load Washer And Dryer Set
Have a load of washing in my front loader and now my LG wasing machine says 'UE'. What does this mean and how do I fix it?
is this an Lg washer ie error code is an water inlet error machine notices low water pressure , you either have kinked fill hoses , plugged screens in fill hoses coming to you watervalves or watervalve is damaged from foreing debris coming into watervalve .........
Jan 24, 2011 | LG Washing Machines
UE displayed on panel westinghouse 708 washing machine near end of cycle shows 6 mins left on spin then shows UE, cannot go into normal cycle.
I WOULD TRY TO LOOK AT THE DRAIN PUMP ASSEMBLY ON THE UNIT.... IT IS EITHER STOPPED UP OR NOT PUMPING FAST ENOUGH OUT DUE TO DEBRI IN THE PUMP AREA... GAIN ACCESS TO THE DRAIN PUMP AREA AND REMOVE HOSES AND LOOK INSIDE AREA.
the code data base for this is saying ue = drain failure... hope this helps you out
Jan 06, 2011 | Westinghouse Washing Machines
Lg inverter 75kg wd1238c problem, after before getting to the spin stage of the wash, it stops and the screens says UE on it and UE is flashing on and off
Error code UE cause : Load is too small, load is out of balance( 1 or 2 large items) solution: Add items to help balance the load, rearrange load to allow proper spinning.... Hope this is useful .....
Sep 18, 2010 | Washing Machines
Error code UE on LG F1247 TD5 washing machine
it means uneven load do u have a pillow in there or something that soaks up lots of water!!
Oct 28, 2009 | LG Washing Machines
Washer shows UE even with nothing in it and makes a metalic pinging sound bell like when trying to spin
Imbalance error (UE)
One of the following has occurred. Try correcting one or more of these issues below.
Aug 12, 2009 | LG WM1812C Front Load Washer
Error message UE
out of balanced? adjust your clothes till there even around the bowl. set the machine on a higher water level. cheers
Mar 31, 2009 | LG Washing Machines
Code error ue lg washing machine
ue is (imbalanced error) cause. the load is to small,washer is tilted, laundry is gathered to one side, non distributed things are put into the washer
Jun 20, 2008 | LG WM-2077C Front Load Washer
Fault code
I have look over the codes for your model and dont see an FH code if you post your email here i will send you the service manual
Jan 26, 2008 | LG WM1814CW Front Load Washer
Washing Machines Logo
137 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
