SOURCE: Where is the bleeder screw located on the back
The bleeder fitting, should be close to the pressure line connecting to the back side near the top of the wheel cylinder assembly.In fact, it should be directly above the line on the wheel cylinder.I have seen where a Mazda b-2000 pickup used only one bleeder fitting for both brakes,was there at the end of the line,being on the left rear wheel..
SOURCE: 2003 FORD TAURUS 3.0 VIN S LOST INJECTOR PULSE,
Hello
Have you run the OBD2 electronic engine control fault code test? both the of the tests must be done and the result's diagnosed, that is the key on engine off test (KOEO) and the key on engine running test (KOER) as well. How have you confirmed the injector pulse is lost? each injector has its own driver in the PCM (Powertrain Control Module), the injector grounds the injectors to open them in the proper sequence, it is the same as the firing order of the spark plugs. To confirm loss of injector pulse you use a little tool known as a "NOID", they can be bought at any good auto parts store for about $5.00, they contain a little light that flashes when the injector pulse is present, it plugs into the harness connector at each injector. Each injector shares the same Battery (+) circuit and is powered off of a fuse and it in turn is powered off the ignition starter switch.
SOURCE: I need a diagram for a 1962 ford 2000 industrial
The best place to get this will be from a ford tractor dealer or from a tractor manual.The good thing about this is that most tractor engine ran similar fuel system set up so if you another tractor of the same age and HP you will probable be able to see how things are set out
