Question about SanDisk Audio Players & Recorders
Unlocking sandisk mp3 player - SanDisk Audio Players & Recorders
SOURCE:
ThaMp3Doctor
  • 8596 Answers
SOURCE: my sandisk mp3 player screen broke how can i get it fixed??? please help me!!
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Sandisk 2GB Mp3 player
-Tha Mp3 Doctor
Posted on May 28, 2008
SOURCE: SANDISK MP3 PLAYER
Unplug the sansa and turn it off. Then plug it back into your computer. If it still doesn't recognize it, unplug it and change the usb setting, make sure you highlight it and then press the inner circle or it might change back into the other setting. This worked for me.
Posted on Oct 18, 2008
drlalitv
  • 488 Answers
SOURCE: instruction manual for sandisk sansa c250 mp3 player
get it here
hope it helps!if the link fails please let me know
Posted on Nov 26, 2008
SOURCE: Product manual for 8gb sandisk sansa view mp3 player
Here is a direct link for the manual
click here for manual
Please do rate my solution if accepted.Thank you in advance.
Posted on Apr 10, 2009
OK PEOPLE!! have asked this same question over and...am getting the run around...please don't make me continue asking for help with this question. its a sandisk mp3 mini clip, and this issue is getting any...
Use SanDisk MP3 Players
SanDisk is an electronic device manufacturer that creates various types of MP3 players under the SanDisk Sansa product line.
The SanDisk MP3 players range in storage capacity, starting at 512mb, and are intended to operate on the Windows operating system.
Most SanDisk MP3 players also include a built-in video player with a color screen, an FM radio tuner, and a memory flash card slot to expand the MP3 player's storage capacity.
Use SanDisk MP3 players to take your computer's MP3 library with you and listen to music wherever you go.
1. Verify that your computer meets the operating specifications required to sync the SanDisk MP3 player with the PC.
All SanDisk MP3 players require Windows XP or later; Windows Media Player; and a USB 1.0 port. A USB 2.0 is important if you want high-speed music syncing.
2, Check that the SanDisk MP3 player has a full battery charge.
All SanDisk MP3 players have a rechargeable lithium ion battery, and some SanDisk devices have a replaceable battery.
The battery icon on the top right-hand side of the SanDisk MP3 player's screen displays the current status of the battery's charge.
If the battery is low, recharge it before using the SanDisk player for the first time.
To charge, connect the player to your computer's powered USB port using the included USB cable.
The SanDisk player's screen will display a yellow charging icon.
Unplug when charging is complete.
3. To turn on the SanDisk MP3 player for the first time, unlock the "hold" switch on the top of the MP3 player by sliding it so that the orange tab does not appear.
Then, press the "power button" once.
Wait for the SanDisk MP3 player to respond.
The thumbweel of the player will flash a light and the screen will turn on to display the player's menu options.
Turn off the SanDisk player by holding down the player's power button for two seconds.
Wait for the screen to display "Goodbye" before releasing the button.
4. Practice resetting the SanDisk MP3 player to solve critical software errors and to fix the MP3 player if it freezes.
To reset the player, hold down the power button for fifteen seconds.
This resets the MP3 player to its original factory settings and can help resolve any problems you encounter while using the SanDisk MP3 player.
5. Connect the SanDisk MP3 player to your computer using the included USB cable.
Once the computer has sensed the connected device, the SanDisk player's screen will display "Connected" and the SanDisk Portable Media Player will be listed under Other in your computer's My Computer window.
6. Add music to the SanDisk MP3 player.
Double-click the Portable Media Player listed in the My Computer window.
Double-click the Music folder.
Select the MP3 files that you wish to load onto the MP3 player and drag them into the Music folder.
The player will load them into its internal memory and make them available for playback once the device is disconnected from the computer.
7. Sync your MP3 song playlists from Windows Media Player to the SanDisk MP3 player.
Create a playlist in Windows Media Player and connect the SanDisk MP3 player to your computer (see Step 5).
Once its connected, Windows will display a dialog box. In the box, click "Sync digital media files to this device."
In the next window, click Set Up Sync. In the menu, click Personal Playlists and then select the playlists that you wish to transfer to the SanDisk player.
Click the Add button then push the Finish button to transfer your Windows Media Player playlists to the MP3 player.
Aug 09, 2013 | SanDisk Clip Audio Players & Recorders
Connecting sandisk mp3 player to a computer
try going to www.sansa.com click on support and then click on your model player. Go through the troubleshooting questions and find your problem. there should be a few solutions for you to try. Good luck :)
Jan 27, 2009 | SanDisk Sansa e250 MP3 Player
I know its a silly question but can anyone please tell me the step-by-step process to transfer songs to my sansa c150 MP3 player......... Thanks
  • Step 1:Free a USB port on your desktop computer. Now, grab the USB cable for your SanDisk Sansa MP3 player and connect the player to your computer.
  • Step 2:Wait for your computer to find and recognize the player. This may take a few moments. Once you receive a confirmation message, open your computer and scan the icons for the SanDisk MP3 player.
  • Step 3:Open the SanDisk Sansa MP3 player on your computer. The music files that you currently have saved to the player’s memory are displayed.
  • Step 4:Open a folder containing music files that is stored in your desktop computer’s memory. Scan the files for songs that you want to transfer to the SanDisk Sansa MP3 player.
  • Step 5:Left-click on a song file and drag to the SanDisk Sansa window. Drop the file and let your computer complete the transfer. The transferred file appears at the bottom of your music list.
  • Step 6:Unplug your SanDisk Sansa player from your computer. Turn the player on and allow the file transfer to update to the internal memory of the MP3 player.
Tips & Warnings
  • When properly connected, the SanDisk Sansa MP3 player displays a USB Connected message on its LCD screen.
  • The music files in the SanDisk Sansa MP3 player will have different icons next to their filenames which will tell the file type at a glance (MPEG, MPEG layer 3 or WMA, for example).
  • Some songs feature copyright protection which may interfere with your ability to transfer music to the SanDisk Sansa MP3 player.
Jan 27, 2009 | SanDisk Sansa c150 MP3 Player
How to download videos on to my SanDisk MP3 Player
download the sansa media converter from the sandisk website and then use that to convert videos to your mp3 player.
Mar 09, 2008 | SanDisk Sansa e250 MP3 Player
Sandisk sansa
Did you try unlocking it at the top of the device where it says "hold" (switch should be in position closer to the mic than the headphone jack)?
Mar 01, 2008 | SanDisk Sansa e260 MP3 Player
Key locked
Try unlocking it by switching the switch on top, of the player by the earphone plug, from red/orange to white.
Thank you and please respond with any comments or more questions.
-John-
Feb 29, 2008 | SanDisk Sansa e250 MP3 Player
Mp3 player says refresh data base, i just want to reload my music
  1. i need help unlocking my mp3 player.
  2. i need help re downloading my songs to my mp3 player.
  3. how do take the srceen that says refreesh database off and restart.
  4. wat is the best website to go to or phone number to dial to get information.
  5. i got the c240 mp3 player for christmas and i through the box it came in the trash.
  6. my email is seonjena67@yahoo.com or seonjeneenickerson@yahoo.com
Jan 25, 2008 | SanDisk Sansa c240 MP3 Player
22 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
