Washing machine wont spin on spin cycle. washes and drains fine. on spin cycle, motor runs but basket does not spin
I have replaceced the motor coupling but the shaft for the transmission will only turn counter clockwise whein i turn it clockwise it only goes so far but will nlot spin agitater ...has broken 2 couplings. i plan to drpo the transmisson out tomorrow to see if i can see why the saft is locked up!!!!
Posted on Jun 19, 2011
  • 69 Answers
The transmission may be shot
Posted on Jul 30, 2009
Hi i have a SIMPSON ESPRIT 600 TOP LOADER WASHING MACHINE. The wash cycle works fine however during the drain and spin cycle, the water wont drain. The machine makes a noise during the drain cycle but...
My guess would be replace the pump, it is normally driven by the motor and if the wash cycle is good the motor is operational. You have to investigate to find the actual part to replace.
Dec 03, 2014 | Washing Machines
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Zanussi Washing Machines
My washer does not spin or move during wash cycle the moter runs but nothing is moving.
Hi, this motor has faulty windings, causing it to lock up and not rotate the drum/basket. replace this motor asap if possible.
May 29, 2009 | Kenmore Washing Machines
Kenmore 110 Heavy Duty 70 Series Washing Machine won't spin
Can you move the basket by hand...if so you need a basket drive. If not you have a bad clutch or gear case
Jun 07, 2017 | Kenmore 24032\24036 Top Load Washer
Washer wont spin or drain
did you check to see if there was anything stuck in the pump? sometimes socks and other small articles get dow there and wont allow the washer to spin or drain
Feb 07, 2009 | Frigidaire Washing Machines
Will not spin,
Washing machines may drain but doesn't spin because of the following reasons:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
  • Thank You
    Jan 16, 2009 | Frigidaire GLTF2940ES Front Load Washer
    My kenmore elite oasis runs fine but wont go through spin cycle
    Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
    Jan 13, 2009 | Kenmore 23822 Top Load Washer
    Intermittent spin cycle on Kenmore 90 Series washer
    You may try the speed selection switch.....Ive had problems with these.
    Jan 23, 2008 | Washing Machines
    Machine does not spin, clothes are soaked
    fill washer and make sure it agitates. If it does not agitate but can here motor running you have a bad motor coupling. If it agitates but wont spin make sure lid switch is good, if good you have a bad gearcase.
    Jan 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Washing Machines Logo
    102 people viewed this question
    Top Washing Machines Experts
