Question about HP Officejet 5510 All-In-One Thermal Printer
No black ink is appearing on paper
When submitting a print job to my HP DeskJet 832C the printer goes through the motion but no ink is printing on the paper even after a new cartridge was installed. Blank sheets come through (I have it set to print black only) I have primed the printer and only the color cartridge prints on the paper. Had been working fine up until now!
  • 108 Answers
If this is an old printer. The nozzles might be clogged. A Q-tip with a little alcohol might get some of that dried ink out. Be careful it could get messy. Also see if your printer has a built in cleaning test. you might have to access the test from the printer tools on your computer.
Posted on Jul 30, 2009
Im looking for a driver for Hp deskjet 825c for windows 7 in south africa
Use the Deskjet 830C/832C drivers. I have a Deskjet 825C and the Deskjet 830C/832C works fine on my Windows 7 64 bit OS. It will work with the 32 bit version as well.
Previously I had Windows Vista installed and found the Deskjet 830C driver worked ok with it as well.
1. Start, Control Panel, Devices and Printers
2. Click Add a printer
3. Click add a local printer
4. Selct Use an existing port
5. In the drop down list select USB001 or 002 or 003, which ever appears. It should say "(Virtual printer port for USB)"
6. click next
7. On the install the printer driver screen under manufacturer select HP
8. Under printers select HP deksjet 830C/832C
9. Click Next
10. If prompted for Which version of the driver do you want to use?" select "Use the driver that is currently installed." and click next
11.Type a name for the printer int the text box for printer name:
12. Click next
13. If you want other computers on your network to be able to share this printer select "Share this printer..." and click next.
14. click print a test page.
15. Click finish.
Download Driver...... HP Deskjet 825c Printer Drivers
Read More help... HP Printer Support
Thanks,
Aug 18, 2014 | HP DeskJet 825c InkJet Printer
Do I have to have a color cartridge in order to print? Can I just use a black ink cartridge?
The HP DeskJet 6122 can print with both or only one ink cartridge installed. The printer driver includes an option to print in gray scale as a substitution for color. If you choose to print a document that has a color other than black and white with only a black cartridge installed, I recommend you select the gray scale print option. To select gray scale, select the printer properties and check the box for gray scale rather than color printing. This selection can be made either at the time a document is ready to print (ie., a one time selection, using the "Properties" box in the print options window), OR as a permenant setting using the Control Panel, Printers, HP DeskJet 6122, "Properties" window. Once changed in the general printer properties, these settings remain active anytime the HP DeskJet 6122 printer is selected to print a document.
Sep 03, 2013 | HP DeskJet 6122 InkJet Printer
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
My HP 3550 deskjet will simply not print. It goes through the motions and seems to be printing --but the page is blank or very faint. I have already cleaned and re-calibrated the printer
Check ink-levels -- no ink means no printing.
Run a few more "print-head-cleaning" cycles -- clogged ink-jets cannot spray ink onto the paper.
Jun 20, 2011 | HP DeskJet 3550 InkJet Printer
My document will not print even after changing both the color and black ink?
Does the printer go through the motion of paper coming out when you press print. If it does and still no paper then the print heads may be the issue. Sometimes they do not come on the ink catridges. given how old the printer is proll better to replace it. If it doesnt go through the motion then its a software issue and need that fixed maybe by uninstalling and reinstalling.
Mar 03, 2011 | HP DeskJet 812c InkJet Printer
My deskjet 3745 wii not print with new ink. The cartridge shows full and the printer goes thru all the motions. The final print is no color and light black
Use the HP software (installed when you installed the printer) to run a "print-head-cleaning" cycle -- you've got lots of ink, but the print-heads are CLOGGED.
Aug 24, 2010 | HP DeskJet 3745 Printer
Mac OS 10.5.8 HP Photosmart C3180 does not print
Exactly what I'm experiencing, it goes though all the motions, but no ink is on the paper. I just installed 10.5.8 last night on my Mac Pro. The drivers are up to date, but no ink hits the paper.
Sep 22, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP DESKJET 5650 - DOES NOT PRINT ON ANY PAPER
Hi dear; When you put in the new cartridge ,did you removed the plastic seal(tape)?
Dec 10, 2008 | HP DeskJet 5650 InkJet Printer
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
HP Officejet 5510 All-In-One Thermal Printer Logo
218 people viewed this question
Seeker5211
Seeker5211
