Question about JVC TH-M505 System
Subwoofer shuts down
I bought JVC TH-M303 about 3 years ago. When i turn on my system subwoofer turns off after making a big sound in about 3 secs. because of that i get no sound. I am only able to watch video.
Re: subwoofer shuts down
Check the connection in the back of the sub,where your wire plugs in from the DVD unit, the connector is loose in the unit itself. Had mine replaced and is doing the same thing again
Posted on Dec 05, 2007
0 characters
3 Points
My subwoofer shuts off when I turn it up too loud. How do I fix it?
Don't turn it up so loud.
Or get a bigger subwoofer.
It's got a junk 6.5 inch speaker and the amp barely does 50 clean watts.
Claims 167 Watts at 10% distortion - impossible when it is drawing 160.
Drive it too hard and protection circuit will cut in and shut it down.
Dec 31, 2010 | JVC TH-C40 System
Subwoofer JVC TH-M606 suddenly stopped functioning
Hiya, sorry that will have to go in for repair as it sounds like it may be protecting. Could be something loose but that would be lucky. Suggest finding a electronics shop in area that can assist. Best of luck
Jul 14, 2009 | JVC TH-M606 System
Cannot figure out how to hook up my jvc th c5 to my tv & cable tv
Do you have audio outs on you tv to run to the jvc
Mar 15, 2009 | JVC TH-C5 System
What are these parts and where can i get them, subwoofer turns of
your looking at a capacitor (big round thing) and transistor (little black thing)
the y-221 on the capacitor should be a voltage designation, how to identify the transistor, well, i cant see it good enuf to say.
Mar 07, 2009 | JVC TH-M505 System
Sub woofer its on for 3 sec..
your cooling fan is not engaging and coming on like its suppose to. One, the fan is probably burned out, which sucks because its low voltage and the only thing on the board that is low voltage. Two, there is a thermostat type component that tells the fan to start which HAS burned out and doesnt start the fan accordingly. If you look at the back fan and turn everything on you will see the fan either doesnt start or starts right as the relay trips turning the sound components off. If it starts at all your fans good.The thermostat component will need to be replace and I cant recommend a source. Just trying to explain the problem so you can look for the right repair. Hope it helps. I have one of these and have found this is the problem, but cant find the solution.
Apr 28, 2008 | JVC TH-M505 System
Jvc th-m45 shut off
shut off audio system is performed to protect it from damage due to high current consumption or short circuit in speakers try to disconnect subwoofer first and check if it is ok. the problem in your subwoofer or its cord-change the cord and check if it is ok thats fine if not change the previuos for all speaker one by one.
if all above failed you must contact service center for help.
Apr 06, 2008 | JVC TH-M45 System
Subwoofer Shutdown
Whay don't you take a look at your data cable and jack contacts to see if any of them are bent or misplaced. Terry
Oct 02, 2007 | JVC TH-C50 System
JVC TH-A10 Won't TUrn on...
Unplug the JVC and the subwoofer from that outlet. Then, plug them back to a different outlet (where power is constant and not interupted by any switch.) Hope this helps
Aug 25, 2007 | JVC TH-A10 System
Systems shuts off if sound gets too loud.
Yes, i had this same problem. If it was too loud, at level 37+, any loud boom would shut down the subwoofer, subsequently shutting down the speakers. As such, I figured it might have been the 8 pin dim cable, but that wasn't it. What solved the problem was lowerin the BASS level. Not the level on the subwoofer, but the actual BASS level. I had it at +10 (the max) and it was too much for the system to handle. I don't think I ever had it like that so I'm assuming someone, maybe my daughters, moved the settings. But anyway, moving the bass level back down to either 0 or +3 at most maintains the "boom" effect of the subwoofer minus the shutting off of the system.
Oct 20, 2006 | JVC TH-C60 System
Subwoofer not powering up
I could either be the sub or the main unit. The main unit actually sends a signal to the sub to turn it on so if that circuit is bad in the main unit the sub is never going to come on. I've also seen bad cables (You'd be amazed at how stubborn people can be when din connectors don't cooperate).
Sep 10, 2006 | JVC TH-M505 System
JVC TH-M505 System Logo
252 people viewed this question
Top JVC Home Theater Systems Experts
Are you a JVC Home Theater System Expert? Answer questions, earn points and help others
