Question about E-Machines eMachines Desktop PC
I NEED TO KNOW WHAT PINS TO JUMP TO RESET MY PC
  • 89 Answers
Open your computer case after you unplug the power. Look for the CMOS battery. It is a small cylinder - looks like a watch battery. Right next to the battery is a set of three pins. Move the jumper to the opposite side for about 10 seconds and then put it back in original postion. Power up and restart your computer.
Posted on Jul 31, 2009
How do i reset after installing new battery
New battery in what? Your mouse, Keyboard, Battery Backup, or your motherboard. If the latter, then simple jump the 2 pins on the motherboard for cmos reset. Every motherboard is different, so check the documentation that came with it. Good Luck!>
Feb 12, 2015 | Computers & Internet
Bios setup
To reset bios, turn computer off and remove side cover, remove coin battery from motherboard and jump appropriate pins on the motherboard to clear cmos. These pins can be found in the owners manual online at the E-machines website.
Sep 18, 2013 | E-Machines etower Computers & Internet
My 1990 Toyota pickup 4x4 3.0 5spd failed its smog test in Ca. The shop said that the timing was set at 5 degrees after. How do I set the timing to the correct setting?
there is a small black check connector next to the big black fuse block that has coded pins that you can jump to check different systems.but to check the timing you will need a jumper wire and jump pins te1 and e1 together. the location for the pins that you need to jump are located on the inside of the lid of the small check connector.start the truck and let it warm up and set the idle to around 800rpm and hook your timing light up to the battery and the #1 plug wire and put your jumper wire in. the engine speed should slow down a little and you should also be able to see the timing mark move with the timing light when you connect and disconnect the jumper wire.once you have everything hooked up loosen the dist. bolt and set the time to 10 degrees btdc at idle.tighten the dist. and unhook everything and and see how it runs.if not running to good the timing belt could be stretched or it could have jumped a tooth.the throttle position sensor can also make the timing to crazy things.....i hope this will help you let me and fixya know and a thumbs up if i did my job........if you have anymore questions let me know i have been working on toyota and lexus for 25 yrs......good luck.......
Jun 21, 2011 | 1990 Toyota Pickup
Failed to unlock HDD System Locked
What you need to do is unplug pc, open up the door panel to your pc and remomo cell battery from mother board then find the jump pins on the mother board they look just like the one in back of the hard drive. The jump pins are connected with a jumper similar to the pins jumper that sets up your hard drive to master, cable select, or slave. You need to reset the mother board the way you do that is by removing that pin jumper and replacing the cell baterry then the pin jumper. If done correctly you will reset your motherboard password setting and bios allowing you to boot your operating system. If you need help google your pc manufacture and model number and search mother board jump pins. Or email me with your pc info to andreioneluv@yahoo.com , and I will try to help you find it. Please rate if this was helpful...
Jun 08, 2010 | Seagate (9W2892-337) 80 GB Hard Drive
Accidently un-setaed three jump switches --Power EW,Power LED, HD
If your talking about the pins on the mother board for the on power switch, HDD LED, reset, power led, and system speaker you would need to note the make and model of *********** board. If you look very closely you should see little letters for example , PWS, HDD,RST,PCS,PLED, These mach up to the pins on the motherboard. also most commonly the PC speaker has an open pin so it will be 3 pins long and not just 2. To find the make and model of a motherboard you can find a name and a group of numbers something like " Intel A33Y97 " and then google for more information if needed.
Apr 11, 2010 | E-Machines eMachines Desktop PC
I just aquired this Dell tower but it is missing the power/reset switches what is the wireing diagram to the board
The switches are missing? or are the wires not connected. If you want to jump the system up, open the skin, lay it on the side. Look for the block of pins for rst spkr pwr and some others. Take a small flat blade screwdriver and with the plug in and supply power on touch the two pins for pwr. and fans should come on immediately.
Mar 30, 2010 | Dell Dimension 4600 PC Desktop
Engine light
you do not jump the pins. that is for older cars. you have obdII you need a scanner to read it. auto zone will scan for free and rent the tool for free so you can reset it.
Dec 30, 2009 | 2005 Toyota Corolla
Master reset for pc
Unplug your machine from wall outlet. Open the case and remove the flat battery from the motherboard. Wait 5-15 minutes and replace it, your machine is now at default settings.
If this helps plz take the time to write a couple of word testimonial. Thanks.
Oct 19, 2009 | Compaq Presario 5000 PC Desktop
Bios password reset
then u will need get take aprt labtop take battery out main batery out litte one also unplug it for 20 min then try thats can reset or jumpe ron mobo that resets it jump pins over ok
Oct 12, 2008 | Dell Inspiron 6000 Notebook
E-Machines eMachines Desktop PC Logo
95 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
