Question about Toshiba Satellite A40-S161 Notebook
My toshiba satellite a40 isn't turning on it just show up with a abmer light, flashing in the power supply area. I checked the memory and the power supply, even perchased a new battery and power cord, could it be the motherboard.
  • hardest305 Jul 31, 2009
    HI, the DC in icon flashs orange, that would mean its a power supply malfunction, I tried turnnig it on with the battery and power cord, waited five mintues, then tried with battery only then power cord only. The results are the same. Off for the first two seconds, error code eight followed by this blink code 01000010 half a second, full second, four halfs of a second, followed by a half of a second and repeats the cycle. What does this blink code mean?
    Yes the solution was very helpful. Ilearn alot more about this laptop computer.
  • Toshiba Master
  • 13,433 Answers
So you have the Battery Icon and the DC in icon (charger - power)
Are they flashing / blinking? which colors?
Battery icon - Lights orange - Quick charge
battery icon - Lights green - Battery is fully charged and ac adapter is connected.
battery icon - blinks orange (even intervals) - the battery level is low
battery icon - flashes orange - the power switch is pressed on when the battery level is too low.
Doesn't light - any other than above.
DC in icon
Lights green - DC power is being supplied from the ac adapter
blinks orange - Power supply malfunction
doesn't light - Any condition other than above.
If the DC icon blinks.
1. remove the battery and ac adapter to cut power supply to computer.
wait 5 minutes
2. reinstall the battery and ac adapter.
If the power supply microprocessor detects a malfunction the dc in icon blinks orange, the blink pattern indicates an error.
First off for 2 secnds
Error code 8 blinks
1 = light is on for one second
0 = on for half second
Interval between data bits - off for a half second.
if the problem remains write down exactly how it is blinking.
Posted on Jul 30, 2009
  • 1 more comment
  • Ekse Jul 30, 2009
    Also try turning on the laptop with just battery and then with just the power adapter.
    completely unplug and remove machine from any power when you try this.
    to try the machine with just battery remove battery and the power adapter, wait 1 minute and plug in the battery. does it turn on?
    If not, unplug the battery and wait 1 minute, now try without battery and with power adapter instead, what happens? do you get a blink code or does the machine turn on?
  • Ekse Jul 31, 2009
    thanks I'll get back to you in a few with details.
  • Ekse Jul 31, 2009
    The issue is the mainboard since you have already replaced the power adapter and the battery, you will have to send the laptop to repair - get the mainboard repaired (almost no one does that) or replace the mainboard.
    If you are inside warranty contact your dealer or toshiba for warranty repairs which should be free.
    If you are outside of warranty try a toshiba service center to get the machine repaired or ask for a repair estimate, any other non toshiba service center will most likely just replace the board, a toshiba specialist may be able to fix this without replacing the board.
    In the end the components of the mainboard are too small for us to fix, also the mainboard is multilayer (many layers of circuit board put together on top of each other) which makes the repair next to impossible.
    If you are interested in replacing the board yourself.
    the price of the mainboard goes around 100 to 500 usd $. You can check for replacement parts at www.pchub.com
    A40 series mainboard
    http://www.pchub.com/uph/laptop/64-31719...
    note that the above mainboard on the link may not be the exact same mainboard your model has.
    if you need anything else let me know.
    Thanks,
    Ekse.
Toshiba satellite a40-s270 won't turn on
Either the power supply is not working or the battery has failed and will not hold a charge. If the laptop is 3 or more years old, the battery is the likely suspect.
Feb 12, 2010 | Toshiba Satellite A40-S270 Notebook
Toshiba satellite pro 6000 power
Sounds like a bad motherboard to me - assuming that it has memory installed.
Nov 29, 2009 | Toshiba Satellite Pro 6000 Notebook
Good Morning: I have a Toshiba Satellite A40, I
more than likely your hard drive is failing. it is quite common for a defective hdd to halt the reimage process.
Oct 28, 2009 | Toshiba Satellite A40-S161 Notebook
Toshiba Satellite Pro A40 Can't find RAM memory
The memory is located under the keyboard
Remove batt and cables
open screen
pop out the rectangular panel surrounding the on off buttons
remove the 3 screws and lift up the keyboard to access the memory
Dont ask me why they made it this complicated
Manual can be got here
http://209.167.114.38/support/download/files_downloads/SA40/SA40EXUM.PDF
Sep 05, 2009 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Toshiba S25-A279 - dont turn on
The memory may be bad. Try changing it.
The hard disk may also cauuse such problem.
So troubleshoot harddisk, memory and any new device you recently attached.
Jun 19, 2009 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Accessing RAM slots in toshiba satellite A40 laptop
http://www.edgetechcorp.com/memory/upgrade.asp?cid=22608#
Click on never installed memory? warch how, then click on laptop and watch video. Enjoy
Jan 17, 2009 | Toshiba Satellite A40-S161 Notebook
Toshiba satellite pro psa45e-007n1-en manual
Also, Is it "Toshiba Satellite" or "Toshiba Satellite Pro"?
Sep 14, 2008 | Toshiba P000392200 - Satellite A40, A45...
Toshiba Satellite A40-S161 Notebook Logo
510 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
