Question about Whirlpool Refrigerators
My ed25pqxfwo2 fridge door seems slightly lower than freezer door.gravity not closing door. do i need a new bottom hinge?
  • 2,418 Answers
You got a worn bushing you could try and make one out of PVC. May just be a loose hinge.
Posted on Jul 30, 2009
Fridge door magnetism does not work - when closing door does not pull shut?
if it's new or recently been moved for some reason, Making a minor adjustment to the front wheels, slightly positions your Refrig. so that a rear-tilt causes gravity to allows the doors to close, assisted by the weight of food products on the door.
If you've had it for some time, You might want to check and clean the metal surface area and the door gasket on the hinge-side. As a habit, cleaning door gaskets, with soap and warm dish towel, will preserve the life of the gasket and save you couple of bucks down the road.
Aug 28, 2013 | Bosch Exxcel KGV35421 Bottom Freezer...
Both the freezer and fridge doors hinge on the right, and the left hand side has sagged a little so neither neither door is sealing properly. How do I adjust the doors to raise the left side of the...
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
May 04, 2011 | Refrigerators
I have an Inglis fridge and when door is closed there is about a1/8 of a inch space between the seal at the top and fridge . Bottom seals properly
That can be caused by hardening of the bottom seal due to ice build up in the seal or the door hinges need adjusting by loosening the lower hinge and pulling it out slightly to compensate for the door seal.
Mar 05, 2011 | Microwave Ovens
Whenever fridge door is shut hard/ quickly it causes the freezer door to pop open a little...and meltdown the frozen stuff. The fridge door has dropped a bit but I don't think that is it. It seems there...
Nov 30, 2010 | Fisher and Paykel Active Smart E522B...
I have a new 4 door Samsung Refrigerator. Is there a way to level the fridge from front to back? The fridge slopes back 1" from the bottom to the top. The delivery people said it was tilted back so...
the front supports are threaded to allow for the adjustment and levelling
while you want the appearance to be in line with everything else, the next complaint will be that it is not cooling properly or the door will not close properly
unfortunately fridges do not come with a self closing door and people are forgetful and that is why it is best to have a slight slope to compensate for forgetful people and yes it is good old cheap gravity
Aug 06, 2017 | Samsung RF265AA Bottom Freezer French Door...
Freezer door will not stay closed when closing refrigerator door
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
To replace it Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Sep 04, 2009 | Refrigerators
Freezer door opens easily
The freezer door has a rubber gasket fitted with magnet beading. In case the gasket is torn or the magnet strip is missing due to continuous use the door does not close. Just replace the gasket and you will see that the door does not open unless you physically open it.
Jul 13, 2009 | Refrigerators
Door will not stay closed
Try tilting the fridge slightly back, or use a spirit level or plumbob at back, non-curved vertical case of fridge to align.
The base should have adjustable feet for levelling.
If tilting forward, even a fraction, gravity will open it.
Dec 19, 2017 | Kenmore 91493 Stainless Steel Compact...
Top freezer door pops slightly open when frig door is closed
try to adjust hinges and check the door gaskets for pinching. Also I have seen that if the fridge is slightly pitched forward and not slightly towards the back gravity sometimes this causes the problem you describe.
Apr 26, 2009 | GE Refrigerators
Freezer door rubbing
take the freezer door off and put a washer or two on the bottom hinge. sometimes there are extra plastic washers on the top hinge that you can move to the bottom to lift it up.
also check if the hinge is bent or loose, as this may cause the problem.
Jun 28, 2008 | KitchenAid Architect KTLA19KRSS Stainless...
Refrigerators Logo
69 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
