SOURCE: dishwater fills with water, hot...but doesnt wash?
when in the wash phase, listen for a low hum near the wash pump. if you hear this it indicates the wash pump capacitor is faulty or something jammed in the pump.after that you will have to access the wash pump and check if there is any supply to it
SOURCE: Dishwasher drain hose.
Its ok to hook to the sink drain but an air gap should be inline with it to prevent sink water from backing into the dishwasher.
SOURCE: I need to replace the
I figured it out my self. I have to say however I am a bit disappointed in your web site. It seems to me that if you need any help you need to pay for it so I guess I will stick with the other trouble shooting sites I work with now which are free. If anyone wants to know how I replaced the detergent dispenser on my Miele G868 U (part cost 158 saved 265 in installation / tech charges) just post me a message and I will tell you how it is done (No Charge). This trouble is closed fixed by my self
Cheers,
Mitch
SOURCE: Miele G868 dishwasher - leaks from front panel air vent
Hi all,
I have had the same problem. Here is what I've done. Take the door apart (a whole bunch of screws on the side of the door). The front panel will come off and you will see a rubber tube. Take it off and blow it out. Then take the blower out (you need to unscrew the inside of the blower). Take apart the blower and clean it out.
Good luck.
SOURCE: Miele G868 Dishwasher is dead, won't even turn on
I had a similar problem. Check the control knob that turns the machine on. At this age, it sounds like the control knob is either bad or a wire has burned off. Check to see if their is an internal fuse in the washer.
