Question about Kenwood Audio Players & Recorders
Trying to get the belt around the gears of my
Hi, I'm trying to get the belt around the gears of my Kenwood Full Automatic KD-47F turntable.. I accidentally turned it over when lifting it to move it to another place -___- and the whole turntable area popped off...
    President:
  • 1,126 Answers
I know this isn't the same model as yours, however it shows what I would describe to you on page 7. Hope this helps.
http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Home/Manuals/kd-491f.pdf
Posted on Oct 19, 2009
I have a DENON Fully Automatic Turntable System DP 297. I had been keeping it in storage in a box in my new home for some time. When I got it out and plugged it in, nothing happened. There are simply TWO...
hi,
from ur narration i think the ur turntables belt have some problem.it may be become loosend. if not put the belt correctly. first insert the belt on the round circle underside the plater( metal table). the put it on the turntable by pulling the belt with ur finger through the hole on the platter , engage the belt with the motor pully( brass spindle ). then plug it and try .
ok
Dec 21, 2010 | Denon DP-47F Turntable
Kenwood KD-491F belt come off How do I put it back?
You have got to lift the table on which the vinyl is placed underneath you will find the belt laying loose on the bottom of the table is a pulley on you fit the belt then on the right hand side or rear is the pulley on the motor which the belt also has to be fitted then carefully lower the so as not to let the belt come off again this should provided the belt is not stretched or snapped then it will have to be reaplaced
Oct 11, 2010 | Kenwood KD-291RC Turntable
I have a kenwood full automatic turntable KD-67F ac 120v 10w 60hz. I dont know how to get the thing to work what else do i need? speekers? or other things if u could let me know it would be a great help
First of all you will need an amplifier, because a turntable has no sound power and its impedance needs to be balanced by a phono input, often found on a receiver or an amplifier. Then you will connect the speakers to the receiver or to the amplifier. I believe that a good start would to buy an old cheap stereo receiver, which has phono inputs, where you connect your kenwood turntable. Hope this will help. Flavio/Brazil
Sep 18, 2010 | Kenwood KD-291RC Turntable
The rubberband came off the turntable, and i was wondering what the pattern is to put it back on. thank you
Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
Jan 04, 2010 | Kenwood KD-291RC Turntable
My turntable on my kenwood kd-3070 stopped spinning when i turn it on. If there is a quick fix for this, please help! I'd like to avoid taking it into the shop.
Is it a belt drive?
If it is then unplug it take the rubber mat off use the holes in the platter to lift it off,then you'll see the belt lieing around somewhere put it back round the edge of the platter then the motor wheele. i'll finish this when u tell me wether or not it's a belt drive.
Aug 08, 2009 | Sony PS-LX250H Turntable
I,m trying to replace my kenwood KD 47F turntable V68 catridge & N68 needle stylus with an Audio technica set due to non availibility of N68 stylus in my home country- singapore. Audio technica...
hi, any cartridge are posible in every turntable as long the needle is available...the wiring is the same the position ,, but the only thing that im not sure is the sensetivity of the needle ..some are not good but some is compatible..u
Jun 30, 2009 | Kenwood KD-291RC Turntable
My KD-291RC has power but my turntable wont turn. I touch the needle and I can hear its on and when I move the arm towards the record or set it on it it will not turn. Help?
Your turntable is belt-driven, it's likely that the belt just fell off. The belt lives under the turntable. On my turntable (a totally different model) the turntable lifts off.
Apr 13, 2009 | Kenwood KD-291RC Turntable
Turntable starts playing record middle 1st song
The tonearm lift is no longer level as it should be and the arm is sliding along it under gravity as the arm lowers to the record. Has it received a knock?
Have a close look to see whether it has been tilted slightly. That would be enough to give the problem.
Jan 24, 2009 | Kenwood KD-291RC Turntable
KD-67F fully automatic turntable--servo mechanism has suddenly stopped
I wish to help but I "NEED MORE INPUT". mgfr, model, type,ect.
Sep 08, 2008 | Kenwood KD-291RC Turntable
Fixing a Kenwood KD 491F turntable
The reason why the audio is low, is that todays receivers do not have a phono input, and these types of inputs are differant then the ones of today. You will need whats called a phono preamp, and one should still be available from Radio shack. Or you can go here to find out more about them: http://www.phonopreamps.com/ To reseat the belt, take off the rubber mat on the turntabe disc. Install the belt around the inside ridge, there should be a couple of holes on the platter disc. Install the patter back onto the center spindle. Turn the platter around till you see the motor pully through one of the holes in the platter. Take the belt that is around the turntable platter, and pull it over to the motor pulley. Good Luck
Jun 15, 2007 | Kenwood KD-291RC Turntable
352 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
