Question about Kenmore 24032\24036 Top Load Washer
Leaking from behind?
Washer seems to run okay but does seem to leak every time from the bottom or behind. It appears that the problem is worsening. Anything I should be looking for specifically?
  • 5,911 Answers
If the leak is coming from the back of the washer, the problem may be attributed to either a leaking water inlet valve, or the associated internal hoses that run from the valve to the dispenser. The following link explains how to access the inside of the washer and/or replace the valve (if required):
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
If the leak is coming from under the front of the washer, the problem may be the drain pump. These pumps can develop cracks and start leaking. they are non-serviceable and will require replacing is defective. The following link explains how: http://www.fixya.com/support/r397092-replacing_water_pump Inspect all internal hoses and hose connections as well. There are two drain hoses on the water pump, and several small hoses near the water inlet valve. These hoses can develop leaks over time. If the leak appears to be coming from the bottom of the wash tub, you may have a leaking tub seal, or cracked wash tub (worst case scenario). You will see tell-tale signs of water marks on the gearcase (transmission) if this were the case. On the lower right hand side of the wash tub is an air dome with a small rubber air hoses attached. Make sure this hose is still attached and has no leaks. The air hose can slip off the nipple it is attached to and water will begin to pour out of the washer when it starts to fill. This will be an "attention-getting" leak as water will gush everywhere. Double check the air hose just in case. If parts are required, you can purchase from any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop all of them for the best deals.
If you have any questions about this repair, or require additional assistance, please let me know. I hope you find this helpful.
Posted on Jul 30, 2009
  • Jeff Rockwell
    Jeff Rockwell Jul 30, 2009
    http://www.fixya.com/support/r600647-rep...
    http://www.fixya.com/support/r397092-rep...
    repairclinic.com
HL04932940 27" FRONT LOAD WHIRLPOOL HE WASHING MACHINE LEAKING WATER FROM BOTTOM
First check is the standpipe drain. The hose that comes from washer should not be inserted more than 4". More than that can cause a syphoning situation that can cause leaks from beneath. If that seems okay you will have to see where water is coming from by observing the machine in action with back or bottom service panel removed (if it has one.)
Jan 06, 2013 | Whirlpool LHW0050PQ Front Load Washer
Water coming out of the bottom of the machine
Sometimes, what may seem like a washing machine leaking from bottom locations is actually one that leaks slowly from other spots. Slow leaks can accumulate beneath your washing machine making it seem like you have a bottom leak. For more help identifying the exact point of the leak, see Washing machine leaking.
Bottom leaks may be better identified using a newspaper. Just dry the floor and lay the newspaper beneath the washing machine before you test for leaks. Darkened sections map out your water leak. This method is not always foolproof, however. The best diagnosis will come from a qualified service professional inspecting your machine.
If your washing machine is leaking from bottom in the rear, you may need a replacement pump and professional installation. The leak could also be caused by a faulty air dome seal or a hole in the tub. For more troubleshooting steps to tackle that leak, see Washing machine leaking from bottom. I hope that helps!
Sep 27, 2012 | KitchenAid KHWS01PMT Front Load Washer
Bosch WFVC6450UC Washer leaks at bottom
How about loose fill hose connections?
How about incomplete shutoff of the internal fill control valve between wash cycles?
Sep 22, 2012 | Bosch WFVC6450UC Front Load Stacked Washer...
I have a LG front load washer seem to leaking front area. Hoses OK Need o see what causes it to leak
you will need to narrow down where the water is leaking from. under the door...? behind the bottom drain door..? underneath machine..? behind machine..? leaks can be found in many areas.
May 16, 2011 | LG WM-2277HW Front Load Washer
Frigidaire Dishwasher leaking but not from door
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Jun 30, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Bosh Washing Machine leak
Regildg,
No, I have not fixed it. I can see the water dripping off what appears to be electric motor plates hanging low on the bottom of the washer.
It does seem to leak most right after I have used the machine.
The drip is not getting worse and appears to be about the same.
Jun 29, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Water leaks out bottom of washer when filling
Open up the top of the machine after disconnecting the mains. Check the pipes coming from the inlet valve to the dispenser box. One of these must hv come off. Refix carefully.
And don't forget to rate me pl..............
May 31, 2008 | Kenmore 46462 Front Load Washer
Whirpool Front Loading HE (GH9400PW4) washer is leaking! Hellllp!
remove the bottom acesss panel and run through drain/spin cycle youll see where the leak is then. perhaps debis has puntured drainline hose or pump housing is leaking
Mar 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washers leaking
SOUNDS LIKE THE OUTLET PUMP / HOSE
Oct 21, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
237 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
