Question about HP LaserJet 1300 Printer
My HP 1300 does not always print a complete page when using card stock. About 1/3 of the page prints and then the printer has an error message on the display. I am using an HP with Vista. Can this be corrected?
    President:
  • 3,085 Answers
Remove the paper tray and toner cartridge.
Clean the gray roller with isopropyl alcohol.
Posted on Jul 30, 2009
Why is my hp 5610v not printing on cardstock?
Are you print through manual bypass? If not try doing it that way. Card stock is very thick and by using manual bypass it doesn't require as many turns for the card stock.
Apr 26, 2014 | HP Office Equipment & Supplies
My 1300 hp printer still all lights on how to resolve problem
HP LaserJet 1150 and 1300 Series Printers - Understanding and Troubleshooting Control Panel Light Patterns This document explains how to interpret the light patterns on the HP LaserJet 1150 or 1300 series printer control panel. It lists the error conditions, describes the possible causes, and provides steps to resolve the conditions. Description of the control panel The control panel contains two lights and one lighted button. Patterns of light indicate printer status.Figure 1: Location of control panel c00007297.jpg 1 - Ready light 2 - Go button and light 3 - Attention light Figure 2: Light conditions c00007298.jpg 1 - Light off 2 - Light on 3 - Light blinking The following table explains the lights on the control panel. See "Status light patterns " below for an explanation of the light patterns.Light or button Description Ready light Indicates that the printer is ready to print. Go button and light To print a demo page or to continue printing while in manual feed mode, press and release the GO button. Attention light Indicates that a printer media input tray is empty, a print cartridge door is open, a print cartridge is missing, or other errors. Status light patterns This section describes the meaning of the light patterns. If a problem persists, see the flyer that came in the printer box for contact information, or click here to go to "Contacting HP support" below . Ready Light pattern c00007299.jpg Description The printer is ready to print. Action No action is necessary. To print a demo page, press and release the GO button on the control panel. Processing Light pattern c00007300.jpg Description The printer is receiving or processing data. Action Wait for the job to print. Continuable error Light pattern c00007301.jpg Description The printer is in manual feed mode. OR The printer is out of memory. Action The software controls manual feed. If manual feed mode is not wanted, change the setting from the printer properties. See the User Guide for information about changing printer properties. OR Take one of the following actions:
  • The page being printed might be too complex for the printer memory capacity. To continue printing, press and release the GO button. The printer might print a partial page, or the quality might be lower than normal.
  • Lower the resolution. See the User Guide for information about understanding print quality settings and changing print quality settings.
  • Add more memory. See the User Guide for information about installing DIMMs (HP LaserJet 1300 series only).
If the problem persists: Attention state Light pattern c00007302.jpg Description The printer is in an error state that requires operator intervention or help. The door is open, the media is out, the printer cartridge is installed incorrectly, or the media is jammed. Action
  1. Check that the printer cartridge door is completely closed.
  2. Load media into the correct input tray.
  3. Check that the print cartridge is correctly installed in the printer. (See the user guide for information about changing the print cartridge.)
  4. Check for any media jams and clear them. (See the user guide for information about clearing jams.
  5. Check that the left side panel is completely closed. If the left side panel is completely closed, open the left side panel and push the door sensor. Occassionally, if the left side panel appears closed, the sensor will still remain in the open position, generating this error. Pushing the sensor will shut the door tight, returning the printer to the normal mode.
Mar 19, 2013 | Office Equipment & Supplies
I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock...
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
Mar 19, 2011 | Office Equipment & Supplies
Keep getting error message from HP PSC 1510 all in one...asking to align, but aligning always fails
For completing alignment both print cartridges need print in good quality.After the alignment page is printing put it on the scanner glass to way as shown on the page and press scan button.If not help replace the cartridges and try again.
Nov 09, 2009 | HP PSC 1510 All-In-One InkJet Printer
Printer name :hp Laser jet 1300 the print
this printer prints a multipage document on 1 page everytime
Oct 21, 2009 | HP LaserJet 1300 Printer
HP Photosmart 7550 - Full Page Photo Printing Jams at end
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 17, 2009 | HP PhotoSmart 7550 InkJet Printer
HP C4280 incorrect paper feed
Check your printer's capability.
Buy the card stock they recommend.
If all else fails, print on plain and take card stock to a copy shop and have them do it for you.
Walking there beats going nuts over stupid software or hardware problems
Dec 16, 2008 | HP PhotoSmart C4280 Laser Printer
HP 1300 printer prints 2 or more pages into 1 page.
Is it actually printing 2 pages on top of each other or is it 1 page with shadows on top?
Oct 24, 2008 | HP LaserJet 1300 Printer
Only prints business cards correctly on plain paper, but not on the card stock.
I am the guy with the hp d'jet D2445. I ran out of card stock in failed attempts. Not wanting to give up I bought more (Avery, no serrations) and it worked fine. Don't ask why.
Oct 21, 2007 | HP PSC 1410v All-in-One Printer
Hp 1300 printing blank margine lines
hello it was your printer fuser asembly problem and in fuser u have teflion flim which was demange so u need to replace teflion flim
Aug 20, 2007 | HP LaserJet 1300 Printer
HP LaserJet 1300 Printer Logo
107 people viewed this question
Seeker5211
Seeker5211
