Question about Whirlpool LER4634J Electric Dryer
Dryer won't start when i push the button,checked breaker,removed back,i believe there is power to switch.what di i need to check for?
  • 5,911 Answers
If your model number is correct, all the heating circuits on your dryer are easily accessible from the back of the dryer. All you have to do is unplug the dyer and remove the back panel. Look for the Thermal Fuse. This will be a small plastic looking component with two wires attached to it. Its mounted on the blower fan housing on the left hand side of the dryer (as facing from the rear). Unplug the wires from the Thermal Fuse and take a resistance reading across the terminals. If good, it will read 0 ohms. If bad, you must replace it.
This component will blow in an overheat/over-current condition and must be replaced. Usually when this component fails, it fails for a reason. Check your blower fan housing for any clogs or obstructions that may be causing the dryer to run hot.
For clarification, refer to appliancepartspros.com for exploded view daigrams of your dryer. Just type in your model number and look under Section 3 for item 19 (part number AP3132867).
Something else to consider:
1. Does the dryer have multiple breakers? An electric dryer runs on 220VAC. Some home use two 110VAC breakers instead of one 220 breaker. Double check your power distribution and make sure you have the breaker(s) set properly.
2. Have you checked the voltage at the wall receptacle? Unplug the dryer and take a voltage reading across the two hot (left and right slots) terminals. If good, you should read 220-240VAC.
3. Have you verified the power cord is good? You can check the power cord by leaving the dryer unplugged and remove the back panel where the power cord is installed on the back of the dryer. This is called the terminal block. You can either perform continuity checks between the prongs on the cord to the terminals at the terminal block, or you can plug the cord back in and take a voltage reading across the RED and BLACK wires at the terminal block.
If good, you should read the same 220-240VAC that you read at the wall receptacle.
If continuity is good you will read 0 ohms resistance from the end of the power cord to the terminal block.
4. Have you verified the door switch? When you open the door is the drum light on? With the dryer plugged in, you should be able to open the dryer door and see the light on insode the drum. Toggling the door switch with your finger, this light should go out if the switch is making contact. If the switch is defective, the dryer will not run.
I hope I've given you enough items to consider. If you have any questions, please let me know. I hope you find this information helpful.
Posted on Jul 30, 2009
  • Jeff Rockwell
    Jeff Rockwell Jul 30, 2009
    PS I forgot the most obvious (and common) problem - check your dryer belt. You can check by lifting the lint screen cover on the top of the dryer and removing the two screws. With the screws removed, the top panel will lift up exposing the drum. The belt should easily be seen wrapped around the drum. If you pull on it, the belt should be tight with no play in it. If the belt is missing it or comes off the drum, replace with a new one.
    NOTE: If the belt is missing it usually comes off the drum when it breaks and gets wrapped around the drive motor shaft.
    If the belt is still wrapped around the drum, but is loose, it probably came off the idler pulley and needs to be re-installed. Let me know if you need assistance with installing a belt if this turns out to be the problem.
Electrical on but dryer does not start
Sounds silly, but because it's an electric dryer, it's run on a 220 line. Double check your breaker box to make sure both breakers are in the correct position. If only one breaker is in the correct position, you'll have electrical power, but the drum won't spin.
Jul 28, 2013 | Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas...
Kenmore HE2 Super Capacity won't start. All lights come on, able to select the cycles but when you push the start button, it won't go.
Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok.
Next, remove the back panel to access this part. Be sure that you unplug the machine before starting. Once the back panel has been taken off and placed aside the thermal switch will be located on the left lower side near the blower housing . It will be thin and long and located near the cycling thermostat that has for prongs on it. On certain machines, the thermal fuse is located in the front. To access this you must remove the kickplate, which can be done by pushing the clips, one on each side jsut above the top of the kickplate, in between the top and abottom portion. The part numbers are the same for either style dryer. To test this part you can either take the wires off it and tie them together then plug the machine back in and see if it starts, or you can use a multimeter and check to see if there is continuity, if there is its good, if not, bad. The thermal fuse will usually be white, and if located in the back, be thin and long with two wires on it, left and right. If in the bottom front, it will be front center on the exhaust duct. Another possible problem is that the door switch isn't functioning properly. You can visually check this by open the door and pressing the switch and listen for a click sound upon pressing and releasing .
In some rare cases the timer itself will prevent the dryer from starting. If you have tested both the thermal fuse and the door switch, and verified that the terminal block where the cord connects are ok then this will be the problem
Jun 17, 2012 | Kenmore 6.7 cu. ft. Electric Dryer
No power
Proper Voltage from the House
Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in.
If your dryer's door switch is defective, it will not allow your dryer to start. Test your dryer's door switch. If it is defective, replace it.
check the thermal fuse in the back of the machine,, remove the back you'll see it
Jun 05, 2011 | Dryers
Having problem with my Electric Maytag. I push the start button and nothing happens.. The model bumber is pyet344ayw..
Have you checked the circuit breaker? I would start there. Dryers run off 220v, and sometimes only one leg of the breaker trips. so you need to flip the breaker all the way off, and then back on. sometimes the breaker feels off when it's not. make sure you completely trip it off then back on. Does the dryer light work? is there any indication that it's getting some power? If the breaker is fine and your still not getting power, then the next step is to make sure you have power coming to the plug behind the dryer. At this point you should only continue if your comfortable working with electricity. Once you move the dryer you can check the outlet with a meter, or other circuit tester. If you got power here, then you'll need to start checking things on the dryer. you can remove the plate where the cord goes into the dryer and look for loose or burnt wiring there. If that looks ok, then you'll need to start taking the dryer apart; front panel, top, back, etc, as needed to access the wiring and controls. From here you can trace the wiring from the supply to the controls and to the motor, etc. look for anything burn, If nothing looks out of place you can start checking temp sensors, or fusable links. If this is above your head, then stop where your not comfortable and have checked by a service tech.
Sep 20, 2010 | Maytag Dryers
Whirlpool dryer will not start the start buttton click when pressed and the timer works if i have the door open and press the start button there is no click so i figured it was not the door swich ...
The first thing to check on a electric dryer is the power.
I know It look like you have power but you have a 220V dryer and it need both sides of power to work.
If you can't ckeck for proper power at the outlet then please at least ckeck your breaker box and maker sure you turn both switches off and then back on to make sure that one site of the breaker did not trip. Then check your dryer to see if this did not solve your problem. ((((( I flip a breaker at least once a month for a customer and recive $60.00 for doing so :) ))))))
Ok if this did not solve your problem.
When you push the button for start do you here a hum noise ??? if so Most common problem would be the motor.
No hum.... Open dryer door and turn drum by hand and close door and retry dryer.
No Hum....
Now it get real fun !!! The start switch needs to be checked, Then the Thermal Fuse and the High limit thermostat.
In most cases this is going to be forign to you and you should call a tech for service.
Sep 05, 2010 | Dryers
The "push to start dryer" button does not start the dryer when pushed. It quit working after doing a usual load. I removed the back cover to reveal the connections and vacuumed off the dust...it all looks...
Check the circuit breaker first to make sure you have power. There is a micro switch on the door to stop the dryer when you open the door during normal operation. Unplug the dryer and locate the switch by visually inspecting around the door and identify if you can remove the switch without opening the dryer top. If you cannot remove the switch from the front you can access the switch by lifting the top of the dryer cover off. Most dryers have clips in the front which allow you to lift the top cover by pulling forward and lifting up or you can use a non marring tool to push the clip in then lift the top up. Unplug one of the wires on the door switch and touch the connector to the other connector using electrical tape to insulate and hold it in place. Plug the dryer in and push the start switch to see if it works. If it does you need to order and replace the door switch. If it does not, the start switch could be bad and you will need to test it with an ohm meter which will be the safest way to test the switch, or you can touch the two switch wires together to see if the dryer starts. To stop the dryer remove the short on the door switch.
Jun 23, 2010 | Dryers
Dryer will not turn on although the timer is working
IF your hearig a click when you push the start button then the button and relay are good check the saftey switch on the door to see if it has come loose and follen down or moved back if the switch is not pressed the motor will not work also I have seen the switches go bad you need to unplug the dryer and cross the too wires togeather plug the dryer back in and press the start button if she starts order a new swith. The motor could also be bad you nees to remove the back cover and check to see when the button is pressed if you are getting the correct voltage you will need a volt meter to check this they cost around 10- 20 bucks if you have correct voltage from the wires and the conections to the motor are ok the motor is no good and needs to be replaced hope this helps...
Jul 07, 2009 | Kenmore Dryers
Normal 0 Hi, UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
Please let me know if this help or if I can assist you further.
Thanks
Vic
May 30, 2009 | Dryers
Dryer won't start
I believe you have lost a leg of power.Check you breaker and then the wiring in the back of the dryer.
Jan 09, 2009 | Whirlpool LER5636P Electric Dryer
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
Whirlpool LER4634J Electric Dryer Logo
612 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
