Question about Nikon Coolpix 8700 Digital Camera
I cannot get my camera to take photos nor can I get to the menu or zoom
There is a clicking sound like the camera is trying to focus when I switch it on, I have been able to take 5 pics but it is trial and error, I cannot zoom and I cannot get to the menu, it seems to be sticking? the lens seems to be continuously focusing, it's a great camera usually and I want it to work again. Living in Turkey the nearest service centre is 12 hours away in Istanbul (I live in Bodrum) and they have not replied to my e-mails, please help me get my camera functioning again.
Re: I cannot get my camera to take photos nor can I get...
Have you got it on macro. If so it will continually make a noise as it keeps on focusing. try it on the auto setting
Posted on Mar 13, 2008
0 characters
3 Points
My samsung es80 does not make sharp pictures anymore
Difficult to go on only does not make sharp pictures anymore.
Seeing one picture says more than 1000 words. Still I give it a try.
When you are sure you did not change the focus settings and don't switch over to macro settings, while shooting normal, I can't help. But I do advice to look in the manual on page 41 and put the camera in Auto focus. (Not one of the macro modes) then when shooting, wait till the camera has focused, while you pressed the shutter realise button half. When the camera is in focus, the square in the middle of the screen becomes green, press the button down. (without moving the camera)
Also select a high resolution (big photo size) because small photo size is easy seen as a blurred picture.
Feb 17, 2014 | Digital Cameras
Sanyo optical 3 x zoom s70 problem of no zoom out when switch on usb connection is display when switch on card reader pictbridge cancel. when any option is selected ok, nothing happens.
Hi there the question is not much clear. But i will inform you 1st the if you connect the USB with camera you can't operate the camera for photo taking . So zoom not working. But if you mean that as normally when you try to click photo with out USB connection but that time zoom or lens not working then try to do this.
Please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 27, 2011 | Sanyo Xacti S70 Digital Camera
Strange noises
This camera has an auto lens. Which means it will focus automaticly evey sec. you can turn this option off:
1: Go into the menu
2: Chose option Cam Setiings
3: Swich AUTO focus to single lens and click OK.
Dec 10, 2009 | Kodak Easyshare M341 12.2MP Digital Camera...
When i press the on button camera makes a buzzing sound but does not switch on. previously it has been taking photo's but they are blurry.
Your Camera is either out of battery of uncharged.The buzzing sound is the sound it makes when the camera zooms in,most cameras automaticly do this when started up.The reason for your pictures being blurry,could just be off focused.Hope it helped
Oct 10, 2009 | Samsung Digimax D73 Digital Camera
I have problems focusing my f8000sd fuji camera when zooming in on small things.IIf I try to zoom right in on a butterfly for example,it will not focus and I can't use macro and get closer in case it flies...
Use spot metering & focus when taking pictures of an object.
Set your camera to highest Megapixel setting, Only use max. optical zoom on the subject (do not use digital zoom) .U dont need to get close to object as you can edit/zoom/crop the picture using any photo software program afterwards .
Aug 09, 2009 | Fuji Finepix Z20fd Digital Camera
Sounds like camera shake. When you use the zoom you get more camera shake. Try taking pix without zoom and see if you still have blurred photos.
Use only optical zoom and use a tripod.
Mar 13, 2009 | Digital Cameras
Soft clicking-grinding noise
i think that you have the full-time auto focus on.
go into the menu and turn it of and all should be fine.
seekreep from Edinburgh - Scotland.
Jun 10, 2007 | Olympus C-7000 Zoom Digital Camera
Out of focus
Sounds like the camera is trying to focus if you hear sound when pressing the shutter halfway down or zooming. If the noise is a scraping or grinding sound, you might have debris stuck between the cracks of the lens and the camera body. This happened to me after i dropped my canon sd550 on the beach just once and it never recovered. Next to water sand has got to be one of a camera's worse enemy. Also, the lens might be cocked a bit which would prevent the camera from focusing and zooming smoothly. Try gently adjusting the the lens. Sometimes the slightest imperfection in the lens will throw everything off. Good luck!
Apr 11, 2007 | Kodak EasyShare Z760 Digital Camera
H1 out of focus above 7xzoom?
HI, are you sure that there is no conversion lens setting activated in the setup menu? It sounds like that to me. These modes limit the ranges. I hope it will help, otherwise you will have to bring it back.
Sep 12, 2005 | Sony Cyber-Shot DSC-H1 Digital Camera
Nikon Coolpix 8700 Digital Camera Logo
88 people viewed this question
Top Nikon Digital Cameras Experts
Are you a Nikon Digital Camera Expert? Answer questions, earn points and help others
