Question about Dynamo ABOVEGROUND POOL PUMP - 3/4HP -
Wiring pool pump
4 wires 115volt how do i wire
  • John Prohaska
    John Prohaska May 11, 2010
    4 wires as in 230 V with a ground, a neutral, and two hot wires on the supply line?
  • 128 Answers
Unless you have a 2 speed motor you only need 3 wires. Hot (black), Common (white) and Ground (green). The wiring diagram is on the motor
Posted on Aug 30, 2009
A.O. Smith 1/4 hp 115v red black blue and white
Not sure what wires you are talking about. Normally on a 115volt motor you will have L1 and L2 and a green ground screw. Black or red goes to L1 and L2 (either one). White goes to either L1 or L2 (either one) and the green ground to the green ground screw. These would be the incoming voltage wires.
Sep 13, 2014 | Pool & Spa
Pump not primeing, lines are clear, makeing motor smoke,water is where its supposed to be......
The pump impeller could be bound up causing motor to try to turn harder if motor turn easy by hand with power disconnected. How long has motor smoked? It could be too far gone already.might just need to replace motor brushes if they are excessively win how old is pump? Was it used or new ?
May 18, 2014 | Pool & Spa
Changeing 115volt to 230 volt
Most power Flo pumps run above ground pools and run on 115v only.You can look at the wiring diagram on the motor label to see if it is convertible, it will show wiring configurations and amps for both 115v and 230v. If not, it is a 115v motor only.
Sep 11, 2013 | Hayward Power Flo Lx 1 Hp Pool Pump Sp1580
Wiring for a Dayton motor 6k857L
Wiring diagram appears on side of motor.
This motor is rated 115Volt.
Hot and Neutral wires connect to main terminals.
Connect other wires as shown on label.
For example there can be yellow, black, blue and white wires.
Dayton manufacturing is owned by WW Grainger.
Contact Grainger.
http://www.grainger.com/Grainger/static/help_contactus.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 12, 2012 | Dryers
Wiring for timer
T101P3 is ordinary 120Volt T101 mechanism inside a beige plastic box.
Rated 40 amp.
Three terminals A 1 2
Very small white wires that power the WG1570 clock motor are connected to terminals A and 1.
White neutral wire from breaker box connects to terminal A
Black Hot wire from breaker connects to terminal 1.
This will power the clock motor, which will switch the timer on-off.
Green ground wire and bare copper wires connect to green ground screw.
115volt motor should have 2 wires.
Connect white wire to terminal A
Connect black wire to terminal B
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Aug 21, 2012 | Intermatic T101P3 Pool Timer IndoorOutdoor...
Wiring a 230v ao smith pump : L1 and L2 connection
Hi, assuming you have 4-conductor wire, use the black and red wires for L1 and L2. It doesn't matter which goes to which. If you do not have a red wire, use black and white. The green or bare wire in a 3-wire cable goes to the ground. If you have 4-conductor wire, the ground wire is the one you used for the GFCI on the breaker--usually the white wire. Please let me know if you have more questions, and thanks for using FixYa.
Aug 08, 2011 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
1/3 Hp 115 volt 24 year old motor 40 amps. single Phase. is this for 110 volt Plug in to wall.It also 3 wires , Orange,Red, White, were do i hook these up to on a 110 Plug. Can you Please help.
You looked at nameplate on motor to get the rating information?
Rating plate may also have small wiring diagram.
I was looking at AO Smith single-phase 2-speed pool pump motors yesterday.
The rating plates show wiring.
Open following link:
http://waterheatertimer.org/images/AO-smith-rating-label-500.jpg
Notice the image shows the words: Brown White Line Line.
Brown and white are wire colors. Line means 'power' from breaker box.
240V will have two Line wires, L1 and L2. 115Volt will have Line or L1 and N or Neutral.
Look at your rating plate and then add a comment with clear description of what appears on rating plate, or include in-focus photo. Put your camera in macro to take close-ups.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Your wall outlet has 2 plug-in slots. One is wider that the other.
'Line' will refer to Hot wire from breaker which corresponds to smaller slot on outlet.
'N' or 'Neutral' is neutral wire from breaker box which corresponds to wider slot on outlet.
Apr 30, 2011 | Electrical Supplies
Inead a new timer for a jacuzzi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First thing:
Determine Hp (horsepower), wattage and volts. There is a label that shows these values
1) Indoor Jacuzzi pumps are usually 115Volt and 1 Hp to 1.5 Hp. 1 Hp or horsepower is 746 Watt, 1.5 Hp is 1119 Watts
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Which timer? If wiring is already connected to a switch, ordinary in-wall 15Amp timer can handle up to 1400 Watts.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 2) Outdoor Jacuzzi or Hot Tub pumps can be 115Volt or 240Volt and up to 5 Hp. 5 Hp is 3730 Watts
Which timer?: Wide variety of Pool and spa controls at Aplus
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.aplussupply.com/intermatic/timerpool.htm
If you need more help, re-post electrical details about your jacuzzi and exactly what you want timer to do.
Sep 19, 2010 | Jacuzzi Hardware & Accessories
Just purchased a new super pump 1hp, but it is
Can you be more descriptive? My guesses are that the motor is wired wrong, the motor is defective, There is a leak in the supply line or the pump and air is getting into the pump, causing the pump to cavitate.
Jun 02, 2010 | Hayward 1HP Super Pump II Inground Pool...
Which wires goes to which post ? Just bought an ao smith 3/4 hp booster motor for my polaris pool cleaner. It has two yellow wire posts. Which do I conect the black and white wires to?
It does not matter. Just make sure it is set to the correct voltage your system supplies to it and that you put pne wire on each terminal as the diagram on the side of the motor will show you.
Jun 11, 2009 | AO Smith Pool Pump Motor Hayward Swimming...
Dynamo ABOVEGROUND POOL PUMP - 3/4HP - Logo
754 people viewed this question
Top Dynamo Pool & Spa Experts
Jay Finke
Jay Finke
Gil Shultz
Bosse Photos
Are you a Dynamo Pool and Spa Expert? Answer questions, earn points and help others
