Question about Logitech Cordless Internet Handset Phone
Drivers for skype phone for vista
I have thompson skype phone, i need the drivers for Vista, I cant find them anywere!please help
    Problem Solver:
  • 18 Answers
Re: Drivers for skype phone for vista
Try this website,en?osid=13.
Its the Logitech Download Centre.
You will find your Vista Drivers for your skype phone there.
Posted on Nov 28, 2008
0 characters
3 Points
Where can I find driver for Philips VoIP321 for Skype 4.1 and Windows7 64b?
go to properties(right click->Properties) of the voip321 program and set the compatibility mode to Windows XP.
Jan 17, 2010 | Philips VOIP3212 IP Wireless Phone
"please upgrade your operating system"
I had the same problem. Bought a CIT300 off ebay. Cisco/Linksys no longer provide drivers for this device. I'm running Windows 7. I downloaded a driver from Softpedia, says it is from Microsoft dated 7/12/13 version 6.1.7601.18208. It solved my problems. Hope this helps.
Jan 06, 2010 | Linksys CIT300 IP Wireless Phone
Phone disconnected ver cit200
I got the same problem with my CT200 when I updated for Vista. (disconnected) The solution I found is: I avoid logging on to MSN. If the problem still persists I take out the batteries from the phone wait for 10 seconds , reinsert them and the phone works. Hope this helps.
Apr 01, 2009 | Linksys CIT200 IP Wireless Phone
GE 6.0 Dect 28300 not working in Vista w/skypemate
Uninstall skypelink and remove the usb cable of the phone from the computer. Reinstall, and after install, plug in the usb cable.
As per installation instructions, you shouldn't plug in the USB before you have installed the software....
Mar 24, 2009 | GE 28300EE1
Logitech cordless internet handset for skype -- base unit problem
You can uninstall the Skype Application and reinstall it in compatiblity mode and chose XP. To do this right click on the install exe and go to the compatibility tab/section and from the drop down chose XP. Then try reinstalling it.
That has solved a lot of issue for me with Vista.
Let me know if you need anymore help or if that does not solve your issue.
Dec 29, 2008 | Logitech Cordless Internet Handset Phone
Cit300 ip phone problem installation
Make sure to use the driver for Vista here
* Just look for CIT300 and download the 32bit driver.
* Make sure to uninstall the previous installation you did.
* Unzip the download file
* Run the setup_web CIT300.exe file and just follow the installation instructions.
Hope this helps! Goodluck!
Nov 08, 2008 | Linksys CIT300 IP Wireless Phone
You advice was such a blessing
Haven't experienced this one, it should open if you right click on the icon in the tray at the bottom.
However you should still be able to change your Skype options, click on "skype", then "Tools", then "Options", then "Audio Settings", change microphone and speakers to "logitech" or whatever your computer has listed your device as. This should have the effect of changing logitech to "use handset" and gets the same result. Unfortunately the phone will never work as good as it should, for instance I can't make test calls. I hope this helpful.
Jun 13, 2008 | Logitech Cordless Internet Handset Phone
Trying to download driver for philips skype/land line phone
Click on the following link
Click download for the Vista Drivers. Download the driver to your desktop open the file to install the drivers. Reboot the computer
Plug the VoIP321 back into the computer.
Then on Skype go to Tools then Options.
Click on Advance and manage other programs access to Skype choose allow for the voip321.
Jan 13, 2008 | IP Phones
Logitech Cordless Internet Hnadset Phone on VISTA! for SKYPE
Handset shows DISCONNECTED.
On Logitech support page lookup document 6674 (search).
Boot computer with minimum og services and programs running.
Start Logitech handset program - this starts skype.
the handset will disconnect.
As soon I start the new LIVE MESSENGER BETA - the hanset disconnect.
Therefor I installed a msn messenger extension in Skype extras.
This gives me the opertunity to use msn messenger without using the LIVE MESSENGER PROGRAM - if I do - Logitech Handset will not work.
Sep 06, 2007 | Logitech Cordless Internet Handset Phone
Logitech Cordless Internet Handset Phone Logo
1,176 people viewed this question
Top Logitech IP Phones Experts
Level 1 Expert
Are you a Logitech IP Phone Expert? Answer questions, earn points and help others
