Question about Pioneer PRO-99 TV
Can you tell me the resolution for this model. I'm trying to hook up an apple tv component and it's giving me resolution options
  • 55 Answers
Resolution is 1000
Posted on Jul 30, 2009
I try to use my Norcent tv with computer with a vga cable, but I get a "no signal input" memo on the screen vhen I try to set the source. What do I need to do?
you need to set the computer to display on another monitor. You don't say what kind of compture you are trying to hook up, but generally if you right click on your screen and then click either "settings" if XP or "screen resolution" if Windows 7 you can find an option to use the tv as a monitor. most laptops will have the option to "display on projector" option. These alll vary with each computer model, but you have to tell the computer to display on your tv, most won't do it automatically
Mar 16, 2011 | Norcent Technologies2703 27" TV
I have a Mitsubishi WS-65513 65 in. rear projection HDTV. I recently hooked up a DVD player to the Component 2 cable inputs but I cannot find the Component 2 selection on the 'Device menu' to tell the TV...
If one or more of the inputs is "missing" or not there you may need to do a hard reset of the TV with the original remote.
If you want to try this confirm the actual model number and I will tell you how to do it.
SD TECH
Dec 11, 2010 | Mitsubishi WS-65513 65" Rear Projection...
Tv resolution
It will produce 1080i or 480p using the component input jacks. No way as sharp as 720p. This is of coarse your cable provider gives it to you, and your using a box.
Dec 16, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
No dvi pictur showin up on my plasma tv
try a lower video output resolution on your PS3
Nov 09, 2009 | Gateway GTW-P42M303 42 in. Plasma...
I am trying to hook the Philips 30pf9946 up to an HD Tivo
I am wondering what you are making the connection with, If you are using s-video or composite from your tivo to your hd tv it will only produce 480i. in order to get 480p and above you will need a component video cables or better(hdmi) in order to produce the signal. You may have already known this, but I couldnt tell be the information provided. Hope this helps.
Jun 20, 2009 | Philips 30PF9946 30 in. HD-Ready Plasma...
No color from iphone to tv
that is because the resolution of your TV doesnt match the resolution of the movie file. try to play it another tv with higher resolution
Feb 21, 2009 | Apple COMPONENT AV CABLE (MB128LL/A)
My plasma tv is over zooming and I cannot see any top graphics or see any words on the bottom
I'll need the model number to solve this completely, but here's the first try:
1. Check the "aspect ratio" setting. Usually there's 4 settings: Normal, Wide, Stretch, and Zoom. Flip between those to check which is best.
2. If you've got your computer hooked into it, under the options there's a "fine sync" option, that will allow you to fine-set the resolution. Use the "clock" and "h-sync" option.
Try those, and if you can give me the model number, I can be of more assistance.
Jan 04, 2009 | Panasonic TH-50PHD8UK 50 in. Plasma...
Invalid format message when trying to use the RGB(PC) port
Honestly, that sounds like one of two things happened. Either the resolution of your computer video card changed or (I'm not sure with your specific TV) the TV's resolution changed.
If through the TV menus you can adjust PC resolution, I would try changing the resolutions. In the LG 47LB5DF TV, press Menu, then go to Picture, then go down to Screen. On the screen menu, you will see Resolution, Position, Size, Phase, and Reset. First try adjusting the Resolution to some of the options you see. If that doesn't work, try to reset the screen settings.
If adjusting those settings on your TV does not help, then you will have to change the resolution through the computer. Try connecting a monitor to the computer. If you get a picture through the monitor, on the desktop right click and select Properties. If using XP go to the setting tab, if using Vista/7, select Display Settings. Lower the resolution to something you think the TV will be able to handle, then connect the PC to the TV again. If you are using an HDMI connection to the TV, you may have to turn off the computer, connect the cable, then turn the computer back on with the TV on the correct input.
If the monitor doesn't show the picture or if you don't have another monitor, you can try adjusting the picture in safe mode, by pressing F8 after you press the power button, before you see the Windows loading screen. Press if multiple times if necessary. You should see a screen that gives you a few startup options. Select Safe Mode. After Windows boots up, you should still see the screen as the resolution would have been reduced. From there try changing your display settings.
Hopefully that info has helped. I noticed that you asked this question 2yrs ago, so I hope you have already figured out how to fix your problem. I simply wished to post this in case it would help you or anyone else had a similar problem. Good luck and take care.
Dec 15, 2008 | Philips Magnavox 42MF521D/37 Television
How to connect the apple component av cable to panasonic tv
you may need to check you display setting on your flat screen to see if it set to 480p. You may be sending to low of a resolution from the phone to the TV
Aug 23, 2008 | Apple COMPONENT AV CABLE (MB128LL/A)
Televison & Video Logo
164 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
