Music Logo
ndrm_uk Posted on Feb 06, 2018
Casio CT 656 Hi, anyone know where I can purchase a replacement 9v input socket. Not the power supply itself, but the actual input socket which is soldered to the internal pcb. Cheers
Demara Jackson
Level 1:
New Friend:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Feb 08, 2018
Demara Jackson
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
12
Questions
Helped
3001
Points
27
I have replaced several of these sockets. I usually take them out of old toys. I would however suggest either frys electronics, radio shack (if still open near you) or amazon
2 Related Answers
Michial Gueffroy
  • 1140 Answers
  • Posted on Aug 06, 2009
SOURCE: Power input needle snapped on Casio CTK 1000
The answer is repair shop if you don't have tools or experience with soldering. If you do it is simple to take it apart and take the old supply jack out. Take it to an electronic parts supplier so they can match a new one up for you. Make sure that the holes in the circuit board are clean and free of broken pins. Make sure that the traces leading to the holes are intact. Do not use too much heat or they will separate from the board. It might help to take the adapter with you as the jacks and plug have to match in size.
Fred Yearian
  • 5603 Answers
  • Posted on Jul 29, 2011
SOURCE: Hi, I have just bought a casio CT-670 keyboard (
This service manual should be close to your unit... it is a CRK671:
http://elektrotanya.com/casio_ctk671_sm.pdf/download.html
Scroll down to "get manual" and click on it to download. IGNORE other download links.
Power input schematic is on page 10, lower right corner. They appear to "or" in the batteries with the adapter if adapter is used. Look for the diodes and also the bifilar power inout filter.
1helpful
What 9v to ac adapter do i need for a boss distortion pedal ds-1
9V AC Adapter for Boss DS-1 Distortion Guitar Effect Pedal ...
www.amazon.ca > Adapter-Distortion-Guitar-Effect-Ch...
9V AC Adapter for Boss DS-1 Distortion Guitar Effect Pedal Charger Power Supply. AC Input 100V-240V 50-60Hz;DC Output. Industry Quality : Over Voltage Protection, Over Heat Protection. Brand New Adapter, 100% Compatible. Warranty:1 year warranty, 30 day money back guarantee. Shipping from USA !
Accessory USA 9V AC Adapter for Boss DS-1 Distortion Guitar ...
www.amazon.com > Accessory-USA-Adapter-Distortio...
Accessory USA 9V AC Adapter for Boss DS-1 Distortion Guitar Effect Pedal Charger ... D'Addario Accessories PW-CT-9V DC Power Adapter - Minimize Need to ... Rating: 4.3 Ā· ā€Ž15 reviews
Dec 17, 2020 • Boss Music
My casio ct 615 210 tonebank keeps switching off after so many minutes? Why, and how can I stop this from happening. Thanks
To rule out the power supply, or the related power supply circuitry - try it with batteries. If the problem goes away, you can try another 9v power supply with the same ma current (or higher) just make sure it is the correct polarity.
Sep 16, 2017 • Casio Music
I can't get power on my Casio lk-50. ? Help
Hi, There are several common reasons why this and most similar keyboards have this problem.
If you can fit known good batteries, and it works, this confirms the problems will be with the external power supply or connection.
Usually batteries are not available, so.......
Do the obvious.
  1. Is the power supply plugged into a known good mains socket?
  2. is the mains socket switched on?
  3. is the power supply plugged into the keyboard?
  4. is the keyboard switched on?
If the power supply is not the one supplied with the keyboard, then check it is compatible.
(You do not have to buy an expensive replacement power supply, a universal, regulated one, with a selection of connectors will be fine. Supermarkets and the like sell them.)
The manual, or a label on the bottom of the keyboard will tell you the voltage, current consumption, and whether the current is AC or DC.
Invariably the current is DC.
All the Casios I have are 9 Volts, (9V) and very few are more than 300 milli amps (300mA) More milli amps is fine, so the current can be the same or greater.
A TYPICAL power supply is likely to be:-
  • 9 V
  • 300 mA or more
  • DC
BUT DO CHECK
Important
The power supply needs to be REGULATED.
Polarity
This is the way round the connector is wired.
Usually the center is negative (-) and the barrel is positive (+)
This information is molded into the plastic or on a label next to the socket.
On a replacement (universal) power supply, there will be a set of connectors, and when you have selected the correct one, the arrow on the end of the lead should point to the correct polarity symbol on the connector.
Fault finding
The most common fault is the power connector being broken or the solder has been broken.
Slowly moving the connector round, to find it works in some positions, is a sure indication that is the fault.
Repair is quite simple, but there are a lot of screws to take out.
Ideally, drill a hole in the case, where convenient, and fit a metal connector. Now connect to the PCB, in place of the original socket, with flexible wires.
Other wise if it is just solder failure, re solder and glue the socket with epoxy resin (Araldite) or hot glue from a glue gun.
Hope this helps, Chris.
Mar 15, 2016 • Casio Music
Got a used CTK 720 and it has no power. sugestions
try plugging in without the bateries...Also check your adaptor as well as your ac requirements on your keyboard..It specifically calls for a Casio AD-5 Adaptor.
  • 9V power supply; 850mA
  • Positive sleeve/negative tip This needs to match your adaptor Good Luck
http://support.casio.com/pdf/008/ctk_720_01_e.pdf
WE CAN NOT USE OUR CASIO KEYBOARD NOR FIND A POWERCORD #AD12ULWK1630 anywhere
Hi, This is a copy and paste from a similar question, please excuse my laziness........
Do the obvious.
  • 9 V
  • 300 mA or more
  • DC
BUT DO CHECK
Important
Polarity
Fault finding
2answers
I lost my adapter to my keyboard and I need to find either a substitute or a new way to turn it on without the adapter, HELP!!!.
Some Casio Keyboards use 9V DC (center negative) others 12V DC (center negative).
If check what voltage your Keyboard use. Generic AC adapters are usually center positive. So you have to invert the wire with a new DC plug to make it center negative,
Easiest is to buy a Casio ac adapter made for your keyboard from a Casio retailer.
Hi, I have just bought a casio CT-670 keyboard ( very old I know). It was not working when I bought it. I have taken the back off and all looks well except for the power wires. They are attached to DC 9V...
Jul 28, 2011 • Casio Music
1helpful
How do you replace the adaptor jack on a Casio WK-1200 keyboard ? is it easy ?
Unfortunately the adapter jacks are a bit of a weak point on many keyboards but it is quite seldom the jack socket itself that is at fault.
Often the sockets are soldered directly on to the printed circuit board and are prone to either one of the soldered legs breaking, or even the circuit board itself cracking around the jack socket.
Whilst it is generally possible, with care, to resolder a broken leg on the socket if the actual circuit board has cracked the whole board will have to be replaced.
If the actual jack socket itself is damaged it should be possible to snip through the legs and remove it before soldering a new one on to the stumps of the old legs. this is likely to prove easier than trying to solder directly onto the circuit board, unless this is something that you are experienced at doing.
Apparently you can purchase a full service manual for the Casio WK-1200 here for a modest price but I have not used this source myself so cannot vouch for how good it might be.http://www.tradebit.com/filedetail.php/2084335-repair-manual-casio-wk-1200-electronic-keyboard
Feb 02, 2011 • Casio Music
2helpful
Aug 04, 2009 • Music
Top Casio Music Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Casio Music Expert? Answer questions, earn points and help others
