Follow these steps:
1. Go to Account Settings (Tools > Accounts)
2. Click on the "Mail" tab
3. Click on "Properties"
4. On the "Servers" tab, check that you are using SMTP server. Outgoing mail (SMTP)
5. Make sure there is a tick in "My server requires authentication" (the "Settings" should be "same settings as incoming").
6. Next, click on the Advanced tab, under 'Server Port Numbers' change the Outgoing mail server port from 25 to 2525 (or vice versa, depending on which one you have there already. You could also try 465 with encryption).
7. Save your changes and try sending email again.
If these steps didn't work then contact to Outlook customer service team by dialing their phone number. Their support team will help you.
Outlook Email Customer Service 1 844 794 2730 Number
Https://support.microsoft.com/en-gb/help/287073/how-to-upgrade-from-outlook-express-to-outlook
SOURCE: Send/Receive Mail with iPAQ
Software problems are usually dealt with by starting from the scratch. Delete every account you have in Outlook start it again, fill the needed data and Use your outlook. Try closing the outlook then disconnecting from your internet.
SOURCE: Outlook Express - email
ur pop3 server may be nmma.sancharnet.in at port 110
ur smtp server may be nmra.sancharnet.in at port 25
try these...
SOURCE: Outbox - Outlook Express 6
Hello
I havent seen that problem with Outlook Express just with Microsoft Outlook. but this solution should work with outlook express to.
here how you solv it. you need to remove the outbox file manually. remember that all your outbox files gonna be deleted.
step by step.
1.close outlook express
2. go to C:\Documents and Settings\"your user name"\Local Settings\Application Data\Identities\("alot of numbers here.->"{7850C6E6-099E-4EFD-A3F5-A88CA4FC6169}\Microsoft\Outlook Express\
* if you can find Local settings you need to show hidden files!
a. go to tools>folder options->view-> mark show hidden files and folders-> ok
3.in the map outlook express delete the outbox.dbx or move it somewhere.
4. try now to start the outlook express and the outbox should be empty.
good luck.
SOURCE: Outlook Express 2003 sending email permanent failure
The message you're getting is because the Yahoo mail server has flagged you outgoing message as either Spam or, it contains a virus.
The first thing you should is scan your pc for viruses / malware using a well known anti virus program. Sophos and Kaspersky both make good products. You can also run a free online scan of your pc from Trend Micro's website.
If a scan of your pc does not detect any viruses or malware then you will need to contact Yahoo's customer support to find out exactly why your messages are being rejected.
There's nothing wrong with your account settings and the free version of Yahoo mail has no restrictions on sending outbound mail except for possibly a size limitation on messages containing attachments.
