Question about Hayward H Series
Hi, I cannot get the pool heater to kick on. It
Hi, I cannot get the pool heater to kick on. It clicks to go on but the ignitor will not light. There is no glow in the sight window to indicate the ignitor is on. I just installed a new ignitor and still no ignition. Please help. The heater was working at the start of the season. I had a small leak in one of the heater tubes. I repaired the leak but have not been able to get the heater to light since then. Please help !
    Problem Solver:
There is an adjustment on one of the sensors. It takes a small aleen wrench. I had to adjust mine after I soldered my exchanger. Maybe this will work.
Posted on Sep 01, 2009
  • 128 Answers
If the ignitor is not glowing then it's the ignition module.
Posted on Aug 30, 2009
Heater Kicking off breaker
Heaters are dangerous. If you are not an experienced tech you should get qualified help. A tripped breaker indicates a serious problem.
May 18, 2013 | Legacy Jandy Lrz125en Swimming Pool Spa...
Teledyne Laars Series 2 pool heater just clicks when the heater thermostat is turned on
check to see if voltage on both sides of pressure switch if so see if ignitor is lighting if ok check to see if voltage to gas valve should be 24 volts on each if no voltage check transformer also
Jul 10, 2012 | Teledyne Laars Laars Lx Nat Gas Pool...
Why is my Jandy Lite 2 Pool Heater Tripping the Circuit Breaker
shorted ignitor remove the ignitor leads and see if it still trips if it doesnt trip replace the ignitor
May 17, 2012 | Jandy Laars Lite2 - 125,000 BTU Propane...
I have a hayward H400 serise propane heater. I replaced the gas valve. When it goes tot turn on it takes about a minute then starts clicking to ingnite the gas. SSoem time it lights but then goes out other...
0. Check the spark ignitor conection to the board
1. Check the water by-pass valve if you have it
2. Check your gas pressure. (5-7"wc for natural gas, 9-13"wc for propane gas)
3. Clean your filter for your water system or remove it and try again
4. Check the Hi-limits on your heater
5. Replace the thermostat
May 27, 2010 | Hayward H Series Pool & Spa Heater 400k...
Hayward pool heater H100ID keeps blowing GFI
First, I don't see any heaters in my parts wired thru a GFCI. Why did you resolder inputs on board. Usually, those are not repairs that are acceptable. If the pins have shorted, then you need to replace the board. Could be a problem with the ignitor, but this might be one that you will need to call a pro in for. Did you install the heater yourself???
May 19, 2010 | Hayward 100,000 BTU Pool Heater H100ID1 -...
New ignitor..still won't light
Clean out the pilot assemby or replace it. It is probably blocked by rust and/or spiders and is not letting enough gas (if any) through.
Jun 18, 2009 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Hayward H Series Logo
106 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
