Question about Panasonic Lumix DMC-FZ7 Digital Camera
My DMC-f27 suddenly quit being recognized by computer
The Camera is hooked up via usb, but when I turn on camera, I get the Message," Picture is diplayed for 4:3 TV" and gives the directions to change the display ratio. It just started doing this I used the thing last night and came back to restart proect and boom.
First, make sure both ends of the USB cable are firmly connected to the computer and camera.
If no screen pops up asking to select PICTBRIDGE or PC, then there might be a problem with the cable.
I would suggest getting a card reader instead to download pictures. They are many times faster than USB cable, and they aren't too expensive. ($10.00-$70.00).
I recommend this card reader.
Posted on Jul 11, 2008
Is there a long lens for the Panasonic DMC-F27?
Camera is currently equipped with a Leica 12X zoom lens. I would like to be able to take pcs. from a greater distance than this lens permits. Can you recommend a lens that I can attache to the Panasonic DMC-F27 that will enable me to do so? Thank you!!
Apr 14, 2013 | Panasonic Lumix DMC-FZ7 Digital Camera
When I connect my Canon PowerShot A3100 IS camera to either of two laptops via USB cable, I get an error message stating "USB Device Not Recognized - One of the USB devices attached to this computer...
I had this problem today and you might want to check this
from PC's menu = go to my computer right click and select properties
select device manager,
locate "canon camera" which may be under portable devices as mine was
There is either a plus or minus sign next to it. If it is negative as mine, delete this driver. Make sure your camera is off and unplugged before you delete it.
Plug camera in, turn on and the camera should download the driver again.
It worked for me - I'm not technically brilliant but basically, the driver wasn't working correctly.
If you can't find the same settings, call customer service - they were great.
Aug 26, 2011 | Canon PowerShot A3100 IS Digital Camera
My brother-in-law gave me a lumix dmc-f27 camera without the accessories, how can I download photos from its memory card?
Hi there.
If the camera has a memory card, take it out and put it in a card reader. Connect the card reader via USB to the pc. You can transfer photos from there.
Let me know if you need further assistance.
Thanks!
Aug 15, 2011 | Cameras
My computer will not connect with my Panasonic DMC-Zs5 camera. when i plug it in it says USB device not recognized. i have previously been able to plug in the camera and upload pictures just fine but all...
It may be time to consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 26, 2011 | Panasonic Lumix DMC-FS5 Digital Camera
Suddenly My camera is not able to be recognized by any computer. I have my USB cable plugged in but the "connecting to PC" message remains on and the icon never appears on the "my...
Pros avoid this very problem (which happens more frequently than you'd expect) by using a card reader instead of the camera.You should too. da926ea.jpg
Oct 29, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
My Panasonic DMC-LZ3 camera appears to have locked up
Make sure the scene mode dial is correctly "clicked" into a choice. You could also try this...remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
May 24, 2010 | Panasonic Lumix DMC-LZ3 Digital Camera
Will not recognize the PC. USB cable OK. Memory
Use a card reader to download your pics...works every time.
Mar 28, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
The flash does not work on my dmc-f27, why?
Check to see whether you've turned on the digital conversion for a wideangle or other lens. As I recall, that disables the flash. There may be a conflict between the flash and some of the other possible camera settings as well.
Jan 08, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
My wife and I bought Panasonic DMC TZ5 for Christmas. When we try to download pics, we receive message USB port not recognized. We have tried another USB lead but still same problem, Is there anybody who...
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Jan 03, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
USB port does not recognize the hardware.
I want to know where can I find the chinese manual about Panasonic Lumix DMC-TZ5
Jul 30, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic Lumix DMC-FZ7 Digital Camera Logo
88 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
