Question about Husqvarna Garden
Have e series 142 saw, how do you engage the chain after starting and saw is running
    New Friend:
  • 49 Answers
I'm not familiar with that particular model, but every chainsaw I've ever used has a safety bar or shield that must be pulled back (toward the operator) to engage the chain drive. It is a handy feature when you have to climb up to cut something: you can leave the engine running with the safety engaged, then pull it back when you're ready to cut.
Posted on Jul 30, 2009
I have Husqvarna 142 chainsaw it starts but wont stay running
all chain saw fuel filters are in the tank. find something to fish it out so you can grab and change fuel pick up
Oct 02, 2014 | Garden
My e series 142 spins the chain and idles insanely fast when I have the choke pulled out. Then when I give it throttle it calms down and then I can barely keep it idling. with throttle all the way pulled...
Check air filter- clean or replace, Make sure you have fresh fuel, A new spark while you are giving it a service, Do you know how to tune the saw? Start with basic settings 1 turn on the low and 1 turn on the high And adjust from there, You might have turned the idle up too high. The choke should always be fully in when saw is running. Hope this is a good start
Oct 04, 2013 | Husqvarna Garden
Need a new muffler for a husqvarna chainsaw model #142 e-series where can i find one
The part no. is 530069415, available from any Husqvarna dealer, or try the web.
Good luck.
Feb 02, 2011 | Husqvarna Chain Saw 20" Bar
Chainsaw ran out of gas. Filled tank will not start now. Husqvarna 450 e=series 18"
Those saws are very finicky. First shake the saw very vigorously, as the saw running dry mayy have sucked dirt to the intake screen. Clean the plug and check gap. Prime, choke and pull till it starts. your plug may be foulled, this happens alot when a saw leans out from running out of fuel.
Jul 22, 2010 | Husqvarna 450 e-series 18" Chain Saw
142 chain saw. Starts but will not pick up when
Check the fuel lines for hardness, cracking, splitting, or end rot. Check the muffler for plugging. Check the carburetor fasteners for tightness. Are you using fresh fuel mix? If the carburetor jets have been adjusted, try turning both CW to stops (lightly) then back out each CCW 1-1/2 turns. Engine should start and run--allow to warm up. Pull the throttle full on, and adjust H needle CW until the engine starts to speed up, but still 4-strokes. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Let idle and adjust L CW for fairly smooth running, but still allows the engine to 'follow the throttle'. Hope this helps!
May 13, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Remove, clean and reinstall the muffler and spark arrestor, if no better the "L" needle may need adjustment.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
Most chainsaws die because they are are run lean. I am going to inject a little Lou theory here. Air leaks and defective fuel delivery systems account for most chainsaw failures. Constant adjustment of needle valves can easily camouflage more serious problems that result in burning up your saw.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 21, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Need a new muffler for a husqvarna chainsaw model #142 e-series. Who woululd have it in stock to purchase today
How do you feel about a flight to Sweden?
Use the Dealer Locater here:
http://www.husqvarna.com/us/
Set the distance to 500 miles and start phoning.
Sep 17, 2009 | Husqvarna Chain Saw 20" Bar
I am having problems with my husky 142 with the .043 gauge bar
have been running saws for over 20 years and have found you can run pretty much any pitch chain on any saw (as long as the lengths matre up)
think about what you are going to be mostly cutting tho. if its softish wood get a chisel type chain.
have fun
Apr 15, 2009 | Husqvarna Garden
Garden Logo
44 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
