Question about Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive
I'm getting "Internal Error 8211" in my Onetouch 4. Why is that?
  • 89 Answers
Reasons for implant revision included documented internal device failure (46 percent), ..... (770) 205-8211... this means that there is some internal devise error which had occured during installation of some applications
Posted on Jul 31, 2009
What's your problem?error code 0x80004004 when opening maxtor onetouch 4 external hard drive files
im not up to speed with this type of error or what its associated with
if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
hope it helps
May 25, 2012 | Maxtor OneTouch 4 500GB External USB 2.0...
Cellone gprs settings in u.p. east
Manual Bsnl Gprs Settings
Account Name – BSNL WAP
Username –
Password –
Proxy – Enabled/yes
Homepage – http://wap.cellone.in
Proxy and Server address – 10.0.0.10
Proxy and Server Port – 8080
Acces Point Name – gprswest.bsnl.in or mizone
Data bearer – GPRS/ Packetdata
Authentication Type – Normal
May 08, 2010 | i-mate SP5m Smartphone
I am using sony ericsson w890i when i tried to use for gprs or mobile internet then my phone shows the message "data account does not exists please check your settings" How i can get these data account...
which operatr are u using
to create a gprs settings
goto
Menu >sttings>Connectivity >Internet Settings >Internet profiles> create a new profile
AIRTEL MANUAL GPRS SETTINGS
AIRTEL LIVE
Account Name – Airtel_live
Homepage – http://live.airtelworld.com
Username – Blank
Password – Blank
Proxy – Enabled/yes
Proxy and Server Adress – 100.1.200.99
Accespoint Name – airtelfun.com
Data bearer – GPRS/ Packet Data
MOBILE OFFICE
Account Name – MO
Homepage – http://wap.google.com
Username – Blank
Password – Blank
Proxy – disabled/no
Accespoint Name – airtelgprs.com
Apr 16, 2010 | Sony Ericsson W890i Cellular Phone
My C:\1386 has error 8211 on my external Maxtor 4 One Touch hardi
1st do restart ...and 2 try to do format ?? or wait me and i will share a programe it will fix ur problem
Mar 13, 2010 | Maxtor Hard Drive
Onkyo TX 8211 protection mode is activated and i want to know how to deactivate it????
Eliminate the short or overheating problem it thinks exists. Disconnect all speakers first to see if one of them is the culprit. If it's internal, take it to a shop.
Jan 19, 2010 | Onkyo TX-8211 Receiver
Error Code E52 Brother HL1650
In fact the noise/E52 service problem might be easy to fix:
You just have to oil the mirror motor shaft in the laser unit.
Step-by-step instruction:
1 – Remove gently the top cover of the printer ( 4 screws – 2 on top/front + 2 in back/side).
2 – Be careful with the connectors going to the top LCD panel. You might want to disconnect the shorter one.
3 – Remove the laser unit located on top of the printer covered by a steel plate.
To do that:
1 – Unplug (pull) the white flat connector going to the left side of the laser unit.
2 – Unscrew the 3 screws keeping the laser unit in place.
3 – The lower/right screw also maintains in place the second connector going to the unit. Remove it and unplug (pull) the connector.
4 – Squeeze out the laser unit from under the wires (going back and up).
You now have the laser unit outside of the printer.
1 - Remove the steel plate of the laser unit. There is a plastic shutter that will come loose. Don’t loose it and take note of its location in case you need to put it back.
2 – Unscrew the 4 screws maintaining the motor section and remove it.
3 – There is a small piece of black plastic that maintains the top part of the motor unit (with the mirrors) on the left side of the board. Twist it and remove it.
4 – Pull up the mirror part.
5 – Be careful during all that not to touch any of the mirrors or prism or whatever seems to conduct light. If you do, you can always clean with isopropyl alcohol or glasses solution.
6 – Put some sewing machine oil on the shaft. Juuuust a little. I used machine oil SAE 20 or 40 (not sure – I didn’t look). WD40 would probably work also. Again, not too much – wipe the excess.
7 – Put everything back together.
Jun 21, 2009 | Office Equipment & Supplies
Canon MP 210 gives E5 error and will not print. ??????
To do that:
good luck
Nov 27, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Onetouch 4 internal error 8211
That error occurs when the 3 Quickbooks files don't have the same date. I'm not sure how they get out of synch, but if you check the dates of the files on your Maxtor backup, you'll find they are different.
The easy solution is to delete the files from your Maxtor backup, and then immediately do another backup. Maxtor will copy the current files over and you'll be all set.
Oct 26, 2008 | Maxtor Hard Drive
Sep 16, 2008 | Maxtor Hard Drive
Backup error
It's been suggested that the software Maxtor bundles with the drive is unreliable at best. you could uninstall the software from your computer then reinstall the latest version to see if that resolves your issue. Otherwise you will be forced to use ntbackup or a 3rd party backup solution.
Jun 02, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive Logo
341 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
