Question about Hoover Vacuums
Purchased a Hoover air stick pro.? It was told that it will the the job as a vacuum cleaner but it didn't it kept blocking up every few minutes.
Soon after the problem was back, I took it back and. Asked to have replaced with a proper vacuum cleaner. The refus to do because by now it was 12 months old. Although the warrant is for 2 years. Please I need help l can't afford to pay another $551.10. Mary sammut Thanks
  • Mary sammut
    Mary sammut Feb 06, 2018
    The fect is that they miss lead me by telling me that it will do the job as a vacuum cleaner. and the first time I took it back was only ten months old, also they gave me the last one that was as displayed because I was told they didn't have anyone. Mary
  • Bill Boyd Feb 06, 2018
    they did not mislead you as it does the job of a vacuum cleaner
    If you had a problem , you would have taken it back with in days and not 10 months
    You say that it is blocking up fast
    Begs the question , how often do you clean out both filters
    one filter should be done daily and the other weekly
    And yes I have the same and it does not block up if properly maintained and it is 2 years old
    Top Expert:
  • Hoover Master
  • 53,730 Answers
The fact is that it is an air stick and not a full on vacuum cleaner
it is meant to replace a dust mop or broom and is designed for a quick clean
The company has every right to refuse to exchange it simply because you want a better product and you have used it for 12 months
IT runs for 20 minutes on normal vacuum operation and for 6 minutes on high speed or boost program
If you want another vacuum cleaner , sell the one you have on e- bay or gumtree and then get a different unit
Posted on Feb 06, 2018
Testimonial: "I am Mary sammut, a widow, 77 years old. Email marydsammut@gmail.com. I didn't get to write it because I missed the spot. Thanks Ps I wish t could talk to you."
    Habit-Forming:
    Scholar:
  • 154 Answers
YOU JUST SPEND $55I.10 FOR SOME THING THAT AT A GOODWILL YOU'LL FIND IT FOR $19.99 YES! YOU WERE MISS LEAD, THRER ARE POEPLE THAT WANT A RICH LIFE
BY PREYING ON THE ELDERLY SO! MY DEAR I WANT YOU TO GO BACK WITH YOUR CHIN UP HIGH TO THE STORE AND ASK FOR THE MANAGER, YOU EXPLAIN TO THE MANAGER THE SITUATION AND IF THEY DON'T FIX THE PROBLEM ,YOU ARE CALLING [ 3 ON YOUR SIDE ] AND YOU
WILL CONTINUE UNTIL YOU GET RESAULTS AND THAT IS A PROMISE...
  • 19 Answers
SOURCE: How to remove handle from Hoover 5445-900 upright wind tunnel vacuum
Hoover.com doesn't have a manual specific to your model but there is one similar which will show how to remove the upper handle from the body.
http://www.hoover.com/pdfs/manuals/U5467900.pdf
Do you have a replacement switch? If not I believe you can buy one from Hoover (the switch and/or the upper handle assembly). Unfortunately your model isn't listed on the website, is this a new vacuum? I recommend giving them a call, that would be the easiest way.
Also remember when working with electronics to unplug the vacuum. Even when there is no power residual electricity can remain in the wires. If you feel unsure, take it to a repairman.
Hope this helps!
Posted on Dec 22, 2007
reddevil6
  • 1673 Answers
SOURCE: changing belt on vacuum cleaner
If you can't see the motor shaft then you will have to take the top cover off. Some have a couple of scres to remove from the bottom. Then is a slot on each side, from the bottom put a flat blade screwdrive in the slot and push out and up to release the locking tabs. The knob may pop off so watch for that coming off. Put the belt on the brush roll, then feed the belt up thru the opening and stretch it to go over the motor shaft. Put back together.
Posted on Jan 24, 2008
SOURCE: I need to replace the
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=566792
Generic problem for all Vacuums
posted by Deb in Iowa on May 03, 2008
I need to replace the belt on the power nozzle of my Hoover Dimension 1000 Model S3491. Unfortunately, I have no written instructions on how to do so. I purchased the vacuum cleaner in the mid-80s. Are the instructions still available? Thanks in advance.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I believe so, but you would have to contact the Hoover Factory and they would have to send out either the owner’s manual or a copy of the owner’s manual from the fische. I remember this vacuum cleaner well. In order to change the belt you need to remove the 4 screws in the bottom of the power nozzle and then the top cover will lift off from the back to the front and then you can get in to change the belt. Always use the Factory Genuine belts instead of the replacement belts, they last longer and the average belt change for a flat belt is every 4 to 6 months as a rule for the best cleaning. In order to change the belt, lift up the pulley side of the brushroll and slide off the old belt and then slide on the new belt and re-install the brushroll, then use a belt puller or screwdriver with a hook on the end and to pull or stretch the belt onto the motor pulley, once you have it on the vacuum track the belt in a straight line and then reinstall the top cover and screws in reverse. If you have questions please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 27, 2008
GoVacuum1
  • 6 Answers
SOURCE: Bosch Vacuum Cleaner: I changed
Greetings from GoVacuum.com,
It sounds like you may have a bad thermal switch inside the machine. Most vacuum cleaners have a switch connected to the motor, so if the vacuum cleaner is running hot, it will shut off to prevent any damage to your motor. You did all the right things by checking the bag, making sure the hose was NOT clogged, and replacing HEPA filter.
Most of the time on canister vacuums, the reason is caused by a clog in the hose, or somewhere in the powerhead. If you're sure that there is no clog anywhere, it is going to be the thermal switch on the motor.
Here's a link to the parts schematic for the Bosch upright vacuum. I hope it helps you in determining how to access the thermal switch. A word of warning to you before you try it, this is a very tough vacuum cleaner to work on, you may want to bring it in to a vacuum repair shop, as this is not an easy repair.
Here's the link;
http://www.essco.net/Customer/SchematicFrame.asp?FileName=Turbo%20jet%20upright.pdf
Please let me know if you have any other questions,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Posted on Aug 18, 2008
SOURCE: Shark Pursuit Euro-pro X vacuum cleaner, 12 amp, upright model
This vacum cleaner is equipped for auto shut off when it gets hot , It gets hot when it gets clogged either the little sponge filter is to dirty or the the round white filter in the dust collecting container.
But if they are both clean then it is clogged in the line probably with lot of carpet fiber, in that case you ned to take the dust container out and possibly the assembly from bottom like when you change the belt, then take of the Handle where the flex hose is attached, then you gonna need a wire hanger bend a long shape close to the shape of the hose line from handle to where it curved around in the bottom opening where it collects the dust behind the spin brush the just stick the hanger from the handle side cause the clog is probably in the lower side then just push the clogs out . Be care full not to puncture the flex hose with hanger. Its probably a good idea to bent the tip of the hanger so that it wont poke hole in the flex hose.
That's what happened with mine I spend hours and hours and days to figure it out. I could have just through it away, but it just kind a pissed me off and the War was on as stubborn as i am, but finally I won and I got the satisfaction of the sweet victory.
Waste lot of time though but it just one of those things. It never messed with me again.
But that is what's wrong with it. Good luck it a good vacum though very power full.
Posted on Apr 17, 2011
When you turn it on the lights on the battery come on and the brush roller will turn but the suction motor will not turn on.
Hoover Air Cordless Series 3.0 Bagless Upright Vacuum ...
www.amazon.com/Hoover-Cordless-Bagless-Upright...
Amazon.com, Inc.Hoover Air Cordless Series 3.0 Bagless Upright Vacuum, BH50140 ... The batteries come pre-charged, plenty to get up and running. ... The brush will stop as soon as the handle is in the upright position for like using the attachments. ..... and in need of charge, in carpet mode, the motor runs, but the brush roller won't spin.
Hoover Air Cordless Series 3.0 review - Best vacuum cleaner
www.vacuumsguide.com/hoover-air-cordless-series-3-0-review/
Rating: 4 - ‎Review by Jason Roberts
Aug 4, 2014 - Hoover Air Cordless Series 3.0 is a new upright vacuum cleaner reviewed by ... power, 2 batteries - each lasting 25 minutes, good filtration system,light ... Just as in the case of the Linx, it filters dust particles, but doesn't come with HEPA filtration. ... Multi-Floor Cleaning - you can turn the brush roll on or off.
Dec 18, 2015 | Hoover Air Cordless Series 3.0 Bagless...
Hoover advance path steamer practically new started smelling like burning now won't turn on
Service Center Locator - Hoover
hoover.com/locator/
The Hoover CompanyFloormate Scrub Cleaners · Steam Cleaners · Stick Vacuums · Carpet Cleaners · Parts & Solutions · Search Parts · Bags · Belts · Filters · Cleaning Solutions.Missing: advancepath
Hoover steamvac repair - YouTube
? 6:16
https://www.youtube.com/watch?v=cyenpuw2XyM
Apr 23, 2014 - Uploaded by BCtruck, rebuild, repair,repurpose
Its ben two years since we had the carpet in the sunroom steamcleaned. It pains me to pay someone else to ...
Nov 07, 2015 | Hoover Vacuums
My Hoover pure power 1700w upright, bagged vacuum cleaner shuts down after 5 minute's use. Although I purchased the pure Hoover power 1700w upright vacuum cleaner around eight years ago it has not u
Are the brushes worn down too far? As they wear the springs tension gets weaker. The brushes can also get stuck inside the channel they slide in. Could also be a buildup of dust etc inside and around the internal fan or commutator, etc.
Jan 18, 2015 | Hoover Vacuums
The vacuum cleaner works for a few minutes then shuts off.After a few minutes it will start again,but soon shuts off again.
There may be as many as three air filters in the vacuum. Remove and thoroughly clean all of them and try again.
Gary
Apr 18, 2011 | Hoover Vacuums
Why does my vacuum cleaner quite working about two minutes into vacuuming? It just shuts off. I have the pet fur picker upper version
Sounds like overheating of motor operating a thermal cut out ..Clean all filters you can run machine with no filters fitted to try if okay first.....
Jan 31, 2011 | Hoover U5753-900 WindTunnel Bagless...
Where do i add soap to hoover steam cleaner model 5835-900
Isn't there a detachable soap reservoir that is kept on with movable clips?
Feb 06, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Hoove Cyclonic Bagless vacuum shuts off after only a few minutes
The motor has a protective overload cutout device to stop it from over heating - this can be caused by a blockage of some sort in the hose or brushroll compartment or blocked filters.
After checking the above and it still cuts out, take it back under gurantee
Sep 20, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hoover fusion plus on/off button works on and off.
it's overheating.. there is something blocking air flow somewhere follow suction from floor to bag there's something there
Jan 17, 2009 | Hoover Plus U5435-900 Bagged Upright...
Brushes not turning
Check the shaft on top of the brush block to make sure it hasn't broken, if brush block is ok, then most likely the turbine is bad and will have to be replaced.
Dec 10, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Leaking
My machine leaked badly BUT it was my own fault. There is a one-time only setup procedure where you squeeze the trigger and push the Clean-Surge button to lock a rod into place. Push the Clean-Surge button VERY HARD. There will be a loud SNAP which sounds like you broke something, but you didn't. I didn't push hard enough initially, all I got was a click which I thought was enough. My machine leaked so I called the help line. They told me to push the button harder, and sure enough, they were right. Until you get that snap, the Clean-Surge (which releases a little extra water-cleaner solution) is on all the time, hence the leaking
Sep 22, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
172 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
