Question about Foxconn 865M01-G-6LS Motherboard
Need manual for foxconn 865m01-g-6els
The power on wires tha attach to the case came loose and im notsure what pins they go on .
  • Anonymous Jan 06, 2008
    I'm Peter Szigeti, repair technician, would you mind if foxconn 865M07 and 865G7MC service manuals send?
    Thank you in anticipation!
    My e-mail:
    Good work, good day!
  • Anonymous Feb 24, 2008
    network card not working
Thank you
Posted on Sep 20, 2008
  • 44 Answers
Here you go:
Posted on Dec 19, 2007
DIY foxconn tower caseTSAA891 connection to abit NF7-S Motherboard
What are you asking for assistance with? Connecting the wires (if so which ones) or finding a manual?
What cables are you having trouble with? If it is the power supply cables you are having problems with, bear in mind that most modern motherboards/PSU's use a 20+4 pin arrangement. Some older PSU's have a different connector.
It could be that you need to update the PSU to match the requirements of the motherboard
Oct 11, 2007 | Computers & Internet
Dont know where ground wires go
Time to Perform: 10 to 15 minutes.
Preparation / Warnings:
If you have not already done so, please read the section on general installation and assembly tips. Pay particular attention to the notes about connecting cables.
For reference, you may want to read this section describing the cables and connectors coming from the power supply, and/or this section describing the connections on the motherboard.
Motherboards and system cases vary.
Your motherboard may not have all the items I mention here, and the same holds true for your case.
Furthermore, you may find that your case and motherboard don't match in every situation; for example, some cases have a turbo button and some do not, and some motherboards have a connection for a turbo button and some don't.
Watch out for "off by one" errors when attaching cables to pin headers. In particular, some motherboards combine several pin connectors into a larger block.
The individual connections are the same, the motherboard just physically groups the pins together into a larger matrix. Be careful when working with these as making a mistake is much easier to do. Refer to the manual.
If the system is in a tower case, it is much easier to perform this procedure with the case resting on its side.
LEDs have two wires and are unidirectional, so they will not work if attached backwards.
You need to connect the positive lead from the case to the positive pin on the motherboard, and the same with the negative.
Unfortunately, the case connector almost never has the positive and negative labeled. Fortunately, attaching them backwards will usually not cause any damage; the LED just won't work.
One tip you can use: most cases employ for each LED one colored wire (green, yellow, red, orange, blue) and another wire that is either black or white.
When this is the case, usually the colored wire is positive (signal) and the black or white wire is negative (ground). This isn't always true, but it's better than a random guess in most cases.
hope this helps
Aug 02, 2012 | Foxconn Winfast K8m890m2ma-rs2h Socket Am2...
Hi Expert, I am switching Foxconn 661M03-G-6L from my old PC casing to a new casing but forgot to lable the pin connections for the following: Power Switch, Power LED, HDD LED, Reset Switch and Speakers ...
You need the manual which you can get here for your board, and download it at the bottom of the page, once you have the manual, then you should see the connections. The other way to tell is to look closely on the board, it might say which goes where right by the connection on the board, and then the wires should say on them what they are, and you can put them where the board says, if you have that on your board.
Dec 01, 2010 | Foxconn 661M03-G-6L P4 Socket 478/SiS...
I need to get the power connection wires for foxconn n15235
wires should be on the tower,were they go should be on the board.
there probably know where near the acctual pins,look all over the board with a tourch.
forget that here download the manual
Sep 30, 2010 | Foxconn 45CMX socket LGA775 motherboard...
The board is 24pin im using a 20pin supply is that right or do i need a 24 pin supply thanks mark
No problem, those 4 extra wires are there to provide extra power to the video card in powerful pc's - yours isn't one so no problem whatsoever.
Jun 18, 2010 | Foxconn 945G7MA-8EKRS2 Motherboard
Instructions on connection led power and hdd led
go there
Get the manual and download it on the desktop.
Open the manual with adobe reader.
On page 21 is the instruction
Jun 10, 2010 | Foxconn 650M02-G-6L Motherboard
Connect power swithc and led cables to foxconn n15235
Still have your Foxconn manual? Turn to page 19. See figure FP1.
Download manual from Foxconn, click on the link provided;
System cases vary when it comes to wire colors. The most common wire colors for positive are, solid blue, light blue, solid red, solid green, light green. Negative wire colors. Each led, IDE-LED, Reset, PWR-LED and PWRBTN should share a negative colored wire. Common is the solid color white but this can vary from case to case.
Nov 10, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
My father in law opened the case to clean out the dust and now the computer won't turn on at all. there are three small wires that are loose they are labeled power sw hdd led and another led i can't...
they should be attached to the pins on the motherboard as they are normally marked on where they go
the pins are on the edge nearest the bottom front of the pc
they normally look like this
just a case of matching them up to the wiring
if your not sure then go to motherboard manufactures website and download the manual from there.
Aug 18, 2009 | eMachines W3506 PC Desktop
Front panel connections
can someone help me on how to wire fp1 on foxconn motherboard
Sep 16, 2008 | Foxconn 848P7MB-S Motherboard
Foxconn 865M01-G-6LS Motherboard Logo
1,315 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
