SOURCE: Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
SOURCE: The brush bar on my Dyson DC17 stopped turning.
If this model has a brush control - i.e a roller at the side of the model which controls brush to spin or not, then its a protected brush model - therefore even if the drive belt is intact the Dyson would have to be repaired by a service personnel or professional. The brush protection isn't able to be taken apart and sounds like it may well have slipped off due to tension.
SOURCE: Hoover hu 4207/1 pet hair removal turbo brush wont revolve
Try Larryclare1's solution for a Kenmore and see if it helps. Worked wonders for both my turbo brush attachments. http://www.fixya.com/support/t1095798-kenmore_model_116_powermate_jr_stopped
SOURCE: The brush in my bissell vacuum does not work
Follow the link below to the belt change instruction video on Bissell.com.
proheat-2x/">http://www.bissell.com/how-to-videos/replace-brush-proheat-2x/
SOURCE: hoover aquamaster
sounds like you need to attach the air hose
with reservoir in place you clip on the lid with tubes attached, one of them goes down to the floor cleaning nozzle, the other tube should be about 20cm long with an end piece,
this is the air hose and it fits into a small hole under the reservoir on the motor housing (the heavy mains powered part that clips onto the big recovery drum that sits on floor)
it's mentioned briefly in the manual, here it is in pdf form http://www.box.net/shared/rnh39ffjcq
