Front loading washer stops after the wash cycle and won't rinse...blinks "F-20" on digital screen and I have to restart. It won't proceed to the rinse cycle. Once I restart it, I think it works fine.
  • Frank May 11, 2010
    check your owners/service manual. It has all the error codes. What brand washer and model number is it?
    President:
  • 1,776 Answers
I don't know what kind of washer you have and what the code means, but I can say that if it is running normally, but just doesn't want to rinse, I would look at a cold water supply problem. That's because cold water is what is used in the rinse cycle. I would check to see if there is a faulty solenoid on the water inlet valve. It can be checked with an ohm meter or multimeter for continuity to see if it is faulty. Also check the small screens in the inlet valve and make sure they are not clogged up. Sure hope this helps and best wishes.
Posted on Jul 31, 2009
Why won't my front load washer fill in wash cycle unless I use rinse/cycle first?
either the motor brushes are worn most probable or the outlet presure switch has an issue {used to see if there is water still in the drum by the control logic}
Nov 28, 2014 | Washing Machines
After working well for six months, my washer now expels water at random points during the wash and rinse cycles.
Check inside the fill hose for debris. There is a screen designed to block debris from getting inside the machine valve. If the screen builds up with debris the water slows down. Sounds like the water is filling too slow. Also the unit and/or the load may not be balanced causing it to stop and drain out. If it's okay then see what lights are blinking when these events occur and post here.
Jun 06, 2013 | Haier HLP21E Top Load Washer
My Whirlpool GHW9250ML is having problems spinning
My Whirlpool Front Load Wasehr Model# GHW9250ML is having problems spinning on the final rinse cycle. The machine shuts down and the letter F appears on the digital read out.
Mar 06, 2010 | Whirlpool GHW9250M Front Load Washer
LG tromm washer stuck in rinse cycle
  • I had the same issue of being stuck in rinse and timer stuck at 20 min. Mine was a water flow problem, at the back of the washer where you hook up the water there is a small in line screen to stop debris from water supply. I removed them, they were clogged, cleaned them up, works great!!!
Aug 22, 2009 | Frigidaire GLWS1339CS Top Load Washer
Final spin /rinse cycle won"t stop
It's usually a control board problem. sorry for the bad news :(
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Frigidaire front loading washer stopped at rinse cycle. 3 beeps
When in doubt check the easiest thing to check. The pump can cause a number of errors to come up. Since the unit stopped in rinse I would start but checking to make sure there is nothing obstructing the pump before going to the expensive parts.
Feb 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
