Code p 0137 refers to heated oxygen sensor (HO2S) 2 bank 1---low voltage ===causes --exhaust leak---wiring short to ground---HO2S --ECM
it also refers to oxygen sensor(O2S) 2 bank 1--low voltage ===causes exhaust leak---wiring short to ground--O2S-- ECM
HO2S sensors are in the exhaust manifold before the cat converter and O2S are in the pipe after the cat converter there is a flex section of exhaust pipe covered by a stainless steel mesh and they crack under the mesh
I suspect that it is the HO2S that is faulty as it reports the gas composition of the exhaust gas so that the ECM can adjust the mixture
SOURCE: 98 subaru impreza knock sensor
at the top of the block under the plenum runners.
please leave feedback
cheers
SOURCE: PO137, PO 138 codes
well on my car these are reffering to the sensors in the exhaust, the upstream sensor(before the cat) and the downstream sensor(after the cat) the downstream sensor can act up if it is lazy or sluggish, or due to a bad catalytic converter or a clogged one. however there are sensors on the exhaust manifold which are determined by driver side or passenger,my opinion is to get a scanner for about $100 to $150 and you can figure out many of these codes yourself.
SOURCE: Knocking/juddering when taking off in first gear subaru impreza 1
Sounds like warped fly wheel.
SOURCE: 95 subaru impreza ;speedometer quit,engine light stays on
i had this problem with mine if your cable spins wen the car is moving its not the gear box end or the cable its the speed sensor in the speedo its self its very easy to fix you have to strip the speedo out of the case the sensor is only small and on the under side of the speedo the sensor is about 50 mm long and 10 mm wide change that and it should be ok
oh remember to reset your ecu
SOURCE: Subaru Impreza gas cap door won't open
If there is one - In trunk - directly behind the gas filler door - behind trunkliner (carpet)
The cable should not have any problems... use a partner to hold the door release and try and pry it open with your fingers.
The spring popper may be bad.
Try this if you dont have an assistant :D
I had this problem with my STI -- easy to fix by bending the little metal on the inside of the fuel door that provides the spring action to open the door. 5 second fix
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question!!
