Question about Compaq Refurbished TC1000 1GHZ 256/30GB/10/10056K/10.4" TFT SCREEN TABLET PC
FIND MOTHERBOARD TECRAM4S435 replaced hard drive then 3 weeks later screen will not come on tec said had short in motherbaord hardly ever used this unit not transported around at all
  • 334 Answers
Hey there copy and paste the following link since this site can't seem to get the hyperlink tool to work. This is for the motherboard for your model laptop at the cheapest I could find it.
http://www.getpartsonline.com/p000428380.html
Also, replacing the motherboard on a laptop is not exactly fun. Go to the link below, it is something I have come accross before. It is a step by step guide with pictures for completely disassembling your laptop which you will be doing. I suggest reading the beginning and make sure you have everything you need before starting. Good luck and let me know if there si anything else I can do for you
seth
http://www.irisvista.com/tech/laptops/ToshibaM2/tecra_M2_disassembly_1.htm
Posted on Jul 30, 2009
Advantech PPC-1532T Power Supply beeps
Try a search for Make and Model beep codes and light codes.
Jun 05, 2016 | Tablets & eReaders
How to extend the short battery charge on Zeepad
You can decrease LCD brightness to improve you battery time
Jun 30, 2014 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
Im looking for to fix the computer thats keep coming on the it shows a blue screen then it cuts off and it comes back on and it does it agen.
Hi
You don't say which version of windows you use.
This is a serious fault. You either have a hardware fault (hard drive, memory or graphics card), a corruption of windows or a virus infection.
If you can, use your cellphone to take a close up full frame picture of the Blue screen so you can read it carefully all the way through to see advice on what the fault might be and some recommendations on how to fix it.
First you must back up any important data you have on the computer.
If you know how to remove the hard drive, (unscrew small cover underneath with CDs icon next to it, then unscrew hard drive bracket containing hard drive and lift both up carefully) you should unscrew the bracket holding the hard drive and then insert the hard drive into an empty hard drive enclosure. connect the enclosure to another computer and back up all important documents, pictures, music, spreadsheets, designs, favourites, contacts etc.
Then put the hard drive back in the computer as before and use a Windows XP, Vista or 7 Tablet Edition CD or DVD to boot from the disc instead of the hard drive by tapping the F12, F11 or F10 function key a few times at the beginning of the boot and then attempting a Repair Installation of Windows.
Then restart, remove the CD or DVD and hopefully it will boot successfully.
Post a further comment specifying your Windows version if you need more help.
Hope this helps.
Aug 24, 2011 | Compaq tc4200 Tablet PC
Install new hard drive m280e
~er~ what do you wanna to say ? how to install new hard drive?
if yes,you can reference the article :Illustrated how to replace a laptop hard drive
hope it can help you
Jan 13, 2010 | Gateway M280E
I had a cylic redundancy error and now the computer turns on but no display whats wrong?
Take out the memory and then install the memory one stick at a time in each slot one at a time. Make sure to turn on the laptop after each stick reinsertion to see if you get video.
If you don't get video then go ahead and take out the hard drive and dvd drive as well. Now try turning on the laptop, if you still don't get video then the motherboard is bad and would need to be replaced.
Jan 06, 2010 | Fujitsu LifeBook T4220 Tablet PC
Difference between HDD and SATA
Buying a new SATA hard drive is confusing if you don't understand the differences between the various drive types. Which hard drive should you buy?
SATA Hard Drives (Serial ATA) are the most popular drives being sold today. Alongside them in the store however you will also find boxes labeled Parallel ATA or SCSI. So what are the differences between these hard drives and which one should you purchase? Your decision is dictated by what your computer can accept. Check with your computer's manufacturer to see which drive style you can use. Most newer computers purchased within the last two years accept SATA connections. If your computer cannot accept one of the newer SATA hard drives you can purchase SATA adaptor cards that plug into an empty expansion slot on your computer's motherboard. You can purchase SCSI adaptors as well, so follow these tips to guide your decision.
SATA vs PATA: Serial ATA vs. Parallel ATA Drives SATA hard drives have many benefits over their older cousin, the Parallel ATA drive. Chief among these differences are:
  • SATA hard drives are faster and perform much better than traditional ATA drives and are better for high bandwidth applications such as video editing and multiplayer gaming.
  • SATA drives use a smaller, cheaper cable to connect to the computer's motherboard. These cables can also be up to three feet in length compared to eighteen inches with Parallel ATA cables.
  • SATA hard drives can be hot swappable, meaning that they can be disconnected and reconnected without powering down the computer. There are limits to this of course. You should never disconnect your boot drive while the computer is operating.
  • SATA cables are easier to plug in without damaging the delicate connecting pins on the drive.
  • SATA hard drives are significantly faster than external USB hard drives.
SCSI Hard Drives SCSI hard drives are the elders of the storage world. SCSI is one of the oldest specifications but it is also the fastest and thus has been widely used in network servers and other high speed, high bandwidth applications. Unfortunately this high speed storage has also meant much higher costs. SCSI drives were once standard in all Macintosh computers but have since been replaced by the cheaper SATA based hard drives.
  • SCSI drives are also hot swappable, similar to the SATA drives.
  • Some varieties of SCSI can be used with SATA
  • SCSI drives are often set up in a mirroring arrangment to allow for instant, continuous backups of the hard drives.
  • SCSI drives are still the most expensive drives on the consumer market.
Your basic rule of thumb should be to purchase a drive that is designed to work with your computer's motherboard. Try to avoid using SCSI adaptors or SATA adaptors unless absolutely necessary as the whole point of using a specific kind of hard drive is to get the most speed and storage for the money.
Thanks alot,
Sanjeev Kumar
Jan 22, 2009 | Tablets & eReaders
Virus or PC problem?
Sounds like a hardware problem. And since your computer is failing like that, my guess is it is the hard drive making that noise. You need to isolate the location of that noise. If it is coming from the hard drive I suggest you back up your data *immediately* using some kind of CDROM based disk imaging software where you can boot to the cd (so you use the hard drive as little as possible). One such program is Image For Linux (http://www.terabyteunlimited.com/image-for-linux.htm)
Jan 26, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Humming?
Make sure sound is comming from ur hard-drive.If it show possible reasons can be.... 1. Your hard-drive is not screw-up proerly. It is unbalanced. 2. Take care you hard-disk safely it may cresh soon.For long age of your hard-disk shut down your pc properly.
Sep 10, 2007 | Toshiba Portege M205-S810 Tablet PC
Battery light stays on even after comp is turned off or the battery charger is unplugged
hi, sounds like you need to replace your hard drive, blue screen of death means 2 things bad memory or hard drive regards
Aug 19, 2007 | IBM ThinkPad X41 Tablet PC
Tablets & eReaders Logo
Top Compaq Tablets & eReaders Experts
Vernon Taylor
tosin_christ
alibaba69
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
