Winter Sports Logo
Eric Stoddard Posted on Feb 05, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 97 xlt limited 600 triple. Rebuilt engine. Put it back in sled and have no spark. Check stator . Is in same spot as when took it off. All wires are hooked up. Has me puzzled.
vtrktrmn
Level 2:
Sergeant:
  • Expert 201 Answers
  • Posted on Mar 04, 2018
vtrktrmn
Expert
Level 2:
Sergeant:
Answers
201
Questions
0
Helped
107293
Points
569
Sounds like you have a wire shorted in the stator , it may be pinched to ground.
5 Related Answers
Anonymous
  • Posted on Feb 15, 2009
SOURCE: pontiac sunfire
I had that problem last year. I bought a new starter but it was not the correct one for my car. For the 98 there are two different starters. I bought the wrong one the first time. My step father started to put it one and realized it was not the same as the one he just pulled off. Ending up taking it with us when we returned the orginial one I bought. The orginial one I bought was about $70 the correct one was $400. The auto store did not have the correct one listed as a replacement part. Until the number off of the part was keyed into the system and found out that it was just not the common replacement part.
Anonymous
  • Posted on Feb 20, 2009
SOURCE: 96, polaris 600 xlt # 3 no fire
The problem was contaminated pump/fuel. Disassembled carbs and pump, inspected and cleaned, engine runs like new. Thank you
Anonymous
  • 453 Answers
  • Posted on Jul 13, 2009
SOURCE: Have a 1998 F-150 XLT, 4.6 (6) Windsor Engine.
Could be the coil pack should be read in ohms about 7 to be good
Anonymous
  • Posted on Jan 23, 2010
SOURCE: I have a 96 polaris xlt 600. The sled will start
it sounds like your clutch
Anonymous
  • 35 Answers
  • Posted on Feb 19, 2010
SOURCE: I have a 1996 polaris xlt with weak spark. I put
you just make a ground, and pull the engine over, if it is weak spark all the time, it is probably the coil, there isnt a meter, its just feel, if its running like ****, replace the coils and see what happens, this happend to me
I have a 97 polaris xlt 600 triple that now hard to start and seems to flood very easily and sometimes backfires. I have spark on all 3 plugs.
Check the diaphragms in the fuel pump most likely flooding through the engine pulse tube from the crankcase.
Would just like some reference points to go from on adjusting the throttle cable to sync carbs up really close
You do not adjust the throttle cable, you adjust the idle speed hard stop screws with a carburetor manometer hooked up to the vacuum sync port on each carb.
Jan 23, 2017 • Motorcycles
93 xlt 580. Only runs on 2 cylinders sometimes at cold. Change plugs and works sometimes.. Not always same cylinder.. Any way to check stator,coil?
Ask The SnowMan Your Sledding Questions Answered: Off ...
www.off-road.com/.../ask-the-snowman-your-sledding-questions-answer...
Mar 1, 2009 - Its a 96 polaris indy xlt 600 triple not the special edition though. ... THEM SITTING ON THE HEADS BUT ONLY 2 CYLINDERS ARE RUNNING WHEN ... Q: I have a arctic cat ext580 the compression in both cylinders is about 70psi .... i have a93 polaris 600 xlt and I just got home and the antifreeze is ...
93 XLT Carb settings? - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris.../41045-93-xlt-carb-settings.html
Nov 27, 2009 - I bought a new to me 95 polaris sport last year. it had not run in twoyears. ... It's all in the tuning, clutching, jetting and gears.. i have a 93 xlt 580 and i ... he is loading up with fuel and just cutting the spark out of a cylinder.. i had ... XLT w/ Triple Pipes Question?
May 8, 2013
93 XLT Ran Great, Shut Down, Now Backfires
Feb 13, 2012
Dead cylinder
Dec 11, 2011
1998 ski doo f3 700 wont run right
Feb 22, 2011
More results from www.snowmobileforum.com
Polaris Indy 600 XLT HELP! - Snowmobile Fanatics
No spark on a 1995 polaris xlt 600
Could be a bad cdi box. Ive this problem with my xlt when I go for a ride, stop to eat and head back out to go home it won't start. I've usually had to choke it, and pull until it starts. My issue is carb settings. If you don't have spark I'd try replacing your cdi. If you know someone with the same sled try there's.
3helpful
My 1995 polaris xlt 600 triple has no spark what could be wrong
COULD BE THE THROTTLE SAFETY SWITCH OR THE STATOR. CHECK TO SEE IF IT HAS SPARK AT OPEN THROTTLE, IF SO IT IS THE THROTTLE SAFETY SWITCH. THEN IF U PICK UP A MANUAL IT WILL WALK YOU THROUTH THE TESTS FOR ALL THE OTHER CONPONENTS.
THERE ARE MANY THINGS THAT CAN CAUSE NO SPARK.
Polaris xlt 1994 hey i start up me sled let it warm up then i push on the gas and it wants to die out solution??
I have a 1996 polaris xlt 600. I changed the coils, spark plugs, cdi box, put fresh gas, and did a compression check on motor witch read 98 across the board. I also rebuilt the carbs and they were tuned. My problem with this sled is when it gets warmed up the motor dogs out. could it be the water pump making this happen?
3helpful
2answers
1997 Polaris XLT Triple. Do I really need to pull
I have 1995 and a 1997 XLT. i have rebuilt the recoil on the 95 and all it takes is the few bolts to take off the cover and take the pipe off. if the 97 is any thing like my dads 94, you may have to pull the engine up a bit, the bottom left bolt cant fully be backed out with out hitting the side of the belly pan retainer, all it takes to pull the motor up is one nut in the back of the motor mount, and one bolt off the front, and it will tip up enough
Top Limited Winter Sports Experts
Arnie Burke
Arnie Burke
john h
ADMIN Andrew
ADMIN Andrew
Are you a Limited Winter Sport Expert? Answer questions, earn points and help others
