Question about GE DBSR453EBWW Electric Dryer
Alternative cleaning for a self cleaning gas oven
We have a self cleaning GE stove model JGBP30WEH2WW and it's self-cleaning. However, when we use it, our fire alarms go off, even with windows open. As an alternative, what type of cleanser can be used to clean it myself. It has baked on stuff from Thanksgiving turkey.
  • 213 Answers
Re: Alternative cleaning for a self cleaning gas oven
Easyoff makes a oven clean that is for selfcleaning ovens. just make sure you get the one that says for self cleaning oven and youll be fine
Posted on Nov 24, 2007
0 characters
3 Points
My stove is a GE and everything works but the burners and oven.
check your breakers everything you said means not enough voltage
Apr 05, 2014 | GE Stove/Oven/RanSurface Burner Knob -...
Gas flame too low
Gas pressure diminishes when the line get surface debris collecting inside of them. Get some Smoking PIPE cleaners, from a tobacco shop or WalMart, and run then down all ports with the gas turned off. If you have Canned Air, used to clean computer parts, the works somewhat as long as the probe from the can makes a positive contact wit the burners /or pilot ports.
Feb 26, 2014 | Bosch Stove / Oven / Range Gas Control...
GE gas stove ....control panel has no power to turn oven on but oven does have i need to replace control panel
I try to clean it up a thin tool pen and then put the fan on it and then try Does it work
In the case did not solve the problem, change the panel
Oct 09, 2013 | GE Stove/Oven/RanSurface Burner Knob -...
Westinghouse oven no gas but supply and power is good
Your subject line says dryer but the text is about a stove.... This applies to your stove. Check to see if something fell down the back of your stove, there usually is a gas shut off at the floor that may have been inadvertently turned off. You may have to pull out the stove slightly, to see behind the stove.
Jan 12, 2013 | Westinghouse WGQ332HS 5.7 cu. ft. Gas...
Ge gas range code f7
Hi. This is a Shorted key panel membrane switch. This will require you to replace the oven control board in this case.(F-7)
Oct 01, 2009 | Dryers
Self clean oven won't come on after I cleaned it
It turned out that the lever for locking the oven wasn't pushed all the way after I cleaned it. We just keep playing with it and finally the oven came on.
Feb 10, 2008 | GE DBSR453EBWW Electric Dryer
GE DBSR453EBWW Electric Dryer Logo
75 people viewed this question
Top GE Dryers Experts
Richard Roth
Richard Roth
John Tripp
John Tripp
Are you a GE Dryer Expert? Answer questions, earn points and help others
