Question about White Sewing Sewing Machines
How to thread the needle
No i just want to learn how to thread the needle correctly on my white sewing machine
  • White Sewing Master
  • 1,388 Answers
You will find a vast array of threading diagrams at the link HERE
Without the model number I cannit be more specific.
If your model is not shown, tale a look at the others for one that is similar.....there really is not a lot of difference from one to another once you see the logic of the thread being
1. Directed from the spool to the .... 2. Tension Unit, then a 3. Length pulled by the take-up arm, 4. Held and then directed 5. Through the needle eye
Hope you have some joy with this.....it is probably all outlined in your Instruction Manual too
Regards
Martyn Bargainbox
Posted on Jul 30, 2009
2 Suggested Answers
  • 152 Answers
SOURCE: Cannot get the bobbin thread to come up with the top thread
1. Make sure the needle is up in the machine all the way.
2. Make sure the flat side of the needle is facing the rear of the machine
3. Only turn the handwheel on the side of the machine towards you, never away from you.
4.Double check your threading of the top of the machine.
5. Also make sure your using the proper needle, your machine takes the most common needle on the market but some look like it and are shorter or longer and wont work properly. Also make sure your not buying needles for a singer serger.
Posted on Oct 07, 2009
Will not stitch
Is the machine plugged in?
Is the bobbin winder on?
Is there a new needle in the machine, right way around and fully up in the needle clamp?
Will the needle thread pick up the bobbin thread?
Will the feed dogs advance paper or fabric?
Is it set for a particular stitch?
Is the machine correctly threaded?
Is the machine correctly lubricated?
Dec 29, 2013 | White Sewing 1888 Mechanical Sewing...
I have re-threaded, changed needles, adjusted the differential and cutting width but cannot sew a single seam without the stitches skipping, sometimes several in a row and sometimes only one.
SKIPPED STITCHES ON A SERGER
1. Is the needle bent or worn--replace
2. Is the needle inserted correctly into the needle holder--check needle
3. Is the Serger threaded correctly--rethread
4. Is the presser foot pressure right for the fabric--adjust
5. are the needles the correct ones for the serger
6. Possible timing problem--need to be checked at a sewing machine shop
Sep 18, 2013 | White Sewing Speedylock 1600 Mechanical...
Top thread will not work ive tryed changing needles is there a special needle to use
the needle used depends on the fabric being sewed. the needle must move thru the needles eye smoothly.
make sure the machine is threaded correctly, using every thread guide
make sure also the bobbin is wound correctly and that the bobbin is inserted into the bobbin case correctly, if the bobbin is turned the wrong way the machine wil not sew
here is a link for a free manual, if you don't have one
http://www.singerco.com/uploads/download/756_white-3300-emb-x.pdf
Sep 07, 2013 | White Sewing W3300 Computerized Sewing...
When I sew, the topstitch looks fine but when I turn it over, there are large loops of thread?
clean under the needle plate where the feed dogs are for lint
also clean in the bobbin area for lint or loose threads
also check the top thread tension--try 3 or 4
rethread the machine top thread & bobbin
make sure the bobbin is wound correctly- if it's not wound correctly it will cause sewing problems
also change the needle
Nov 17, 2010 | White Sewing 1418 Mechanical Sewing...
Cant thread bobbin
To learn how to solve thread bobbin and select the correct needle, I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional step-by-step repair guide written by an expert. Besides Singer sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
May 11, 2010 | Singer 57817 Computerized Sewing Machine
My sewing machine will not sew it only makes holes in the fabric from the needle
Assure the needle is threaded correctly.
Either its not properly threaded when you start to sew
OR the bobbin isn't correctly installed causing it not to catch the thread when sewing.
OR (possibly just with old machines) the tensioning needs to be adjusted.
It is difficult to say without seeing.
Hope this helps at least some. Good Luck!
Jul 31, 2009 | White Sewing White 3032
Bobbin thread not feeding into the upper needle thread
completely unthread the machine....ensure the needle piston shaft is in the correct position and retread the upper. reinstall the bobbin and turn the machine by hand to engage the bobbin thread. Draw the bobbin thread through the stitch plate and with the needle thread, allow to trail off the back. attempt to sew a piece of scap material.
please let me know what happens at this point.
clarkco
Feb 08, 2009 | White Sewing Fashionaire Sewing 2380...
Sew easy sewing machine breaks thread
The machine is not threaded correctly, also use medium weight fabric. Check the size of needle. Try a size 14. The bobbin tension may be to tight. If nothing works take it to an expert. After he fixes it make sure he shows you how to thread it.
Nov 12, 2008 | White Sewing 1740 Mechanical Sewing...
White Jeans Machine
I agree about the needle, took me forever to learn that one. I have a Kenmore Sewing Machine that would not pick up the bobbin thread every time I tried it after having it for a while. I would go to my other machine and use it. Then my daughter in law put in a new needle and it worked perfect until I tried to stitch a different type of material. It was then it clicked and I started researching needles for machines. You have to use the correct size needle for the material you are sewing or it will not work right. Also if your needle is dull or bent you will also have problems. Here is a site that may be helpful http://www.taunton.com/threads/pages/t00185.asp You can find more info by searching for "sewing machine needle information" Hope this helps.
Happy Sewer
Feb 11, 2008 | White Sewing 1766 Mechanical Sewing...
Brother 3022 Mechanical Problem
Make sure your needle is in correctly. Check your threading again. If that does not work, remove throat plate, install new needle, turn hand wheel until needle is at its lowest position and observe if the hook is exactly behind the eye of the needle. If that is correct then you do not have threaded correctly. If it is not then the machine needs to be re-timed.
Oct 09, 2007 | White Sewing 2037 Mechanical Sewing...
Open Questions:
Sewing Machines Logo
69 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
