Question about Sport & Outdoor - Others
I have a 30in. belt on my mulcher. It is supposed to be 29in. When I install it the mulcher tines turn without engaging it. Would the 1 in. longer belt cause this to happen?
    Champion:
  • 225 Answers
Its possable,one inch longer belt withouta belt adjustment is a huge amount of slack.
Posted on Aug 02, 2009
Why did my tines stopped working
Hello, Did you notice if the tines moved when you turned the belt pulley to install the new belt? If the tines do not move when you rotate the driven pulley by hand, the worm gear might be stripped. If the tines do move when you rotate the driven pulley by hand, the belt tensioner might not be working properly. It could be as simple as an adjustment.
Aug 28, 2014 | Garden
Own an older (1990's) American Yard Products model WER500 Weedeater rear tine rotortiller. The engine runs great but when I engage to til, the tines won't turn. The belt is fine and pulleys turn...
Yes, there are shear pins on the tines and on the wheels. Can you check to see if the belt actually moves when the pulleys turn?
May 13, 2011 | Garden
TILLER WILL START/RUN BUT BLADES DON'T MOVE..TILLER PART DON'T MOVE? MTD21AH413B129287-424
Hello, W/D here.
The motor drives a belt, and the belt drives a pulley that causes a chain to drive the tines (blades). For the belt to drive the tines, an idler pulley has to put tension on the belt. This is moved into position by a lever that pulls the pulley into tension on the belt, and tension is maintained with a spring when the lever is locked into place.
1. Make sure that the tines will rotate with the belt off. If there is difficulty, check for debris holding the tines (roots, etc.). If necessary, remove the cap covering the chain cover inspection port, and with the machine tilted back, observe for proper operation of the chain while moving the tines by hand. Lubricate the chain according to your manual. If your chain is not working properly, disassemble down to the chain case, and inspect the chain and sprockets. Chain is radily at places like Motion Industries, WW Grangier, or a bicycle shop. Often overlooked, check that the pulley set screws are tight, and causing the shaft attached to it to actually rotate. Check the pins and locking cotter pins in the tines, make sure that they are pinned to the shaft.
2. Check the belt. An old belt can stretch to the point where it will no longer work. The "V" belt can also wear down to where insufficient friction can be applied to the driving or the driven pulleys to cause it to rotate.
3. Check the condition of the idler pulley and spring. Make sure that the lever places tension on the belt. It should be somewhat difficult to engage the idler pulley when the belt is new. You may have an adjustor on the idler that will tighten the belt.
Best regards, --W/D-- Please provide feedback for our solutions so that we may continue to improve in helping others. Thanks.
Feb 24, 2011 | Mtd Products Yard Machines 158CC Tiller
The tiller won't stay in gear for the tines to turn. It jumps into forward without turning the tines.
Check the wire to make sure that when you engage the tines it is actually engaging the lever. This seems like your are either low on the fluid for the trans or it is stuck in place and will need some good lubrication and turned by hand. You can also with the engine off, engage the tines, and try to turn it by hand. if it turns by hand then the tarns is no good.
Nov 09, 2010 | Yard Machines 21A240M000 Garden Tiller
I need to find out what size belt for tine engagement on a Dayton 5hp Tiller model # 32885 C144B
a simple way to figure out the length is to engage the tine mechanism and take a string and wrap it around the pulleys mark it and take it to any belt store, and buy the Belt you need. You will need to know if it's a 3/8s or 1/2 inch drive belt. Normally tine belts are half inch or 5/8 wide on a 5 horse power motor, You can get these belts at sears or Nappa auto parts store. hope this helps.
Mar 19, 2010 | Garden
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
I have an older (30 yrs) Ariens front tine rototiller. Over the past few times I've used it, I've noticed that the tines have started to turn even when I do not have the clutch engaged. It's to the point...
Your belts are grabbing, make sure they are loose when not holding clutch lever. Also make sure that the guide pins are close enough to hold the belt loose when not engaged, I have the same tiller I use now.tines cannot turn if belt is loose enough. Maybe you bought the wrong belts A verses V belt.
Jul 09, 2009 | Garden
Put it in gear and as soon as it has a load it stops tines and wheels. Has trans grease, and have tried to tighten belt by the two side adjustments but it will not move? It is an older tiller Kohler engine...
It sounds like the key that holds the pulley on the front of the tiller transfer case has sheared into. Carefully remove the belt safety cover so the belts are exposed and start the tiller. With a flashlight look at the pully on the lower shaft and shaft area. Carefully engage the tines and see it they are turning. With a second person visually, from the side, inspect the pulleys to make sure they are turning. Now carefully load the tines and see if the pullies of shaft stop turning. If the shaft stops and the pulleys keep turning then the key on the shaft has sheared off. If both keep turning then you have something that has broken or sheered in the transfer case. This type of inspection is dangerous and needs to be done at a distance with a flashlight so you can see down in the shaft area when standing off to the side while someone loads the tines. It is very difficult to try and see if the shaft is sheered in the pully as is the case without the engine running. The key has friction and it is difficult to turn the tines with the drive engaged to the engine. The only other option is to disassemble the transfer case to see what has gone bad. Please be careful testing it. Good Luck, RAC
Mar 07, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Sport & Outdoor - Others Logo
22 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
