I've never worked on one of these machines but i can tell you whenever there's a power outage and then when the power comes back on the surge can take out the electronics so if you had almost double the power going into that machine i'd have to say it's fried and most likely burnt out the computer board or more.if you want to talk to someone else write back but send the full model number off of the washer and maybe someone who knows this machine can help you but the only way to tell is by checking it out with a meter and see what got damaged from the power surge but double the voltage,that's not gonna be good,hopefully there's a fuse or something in there that could be popped but check it with a meter to see.
SOURCE: I have a Defy
my laundromaid electro logic 920 is making unususl noise when rinsing!!
[email protected]
SOURCE: Defy - 13KG Laundromaid 1300
Here's a solution I've gotten from one of the experts..
"Clean the drain motor lint tray/filter. So many 'faults' are
caused by blocked filters. The motor is unable to drain all of the water
in the allotted time.
If you are unsure where the filter is, it is normally behind the front
lower (kick) panel (or in some machines at the rear in an awkward
position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the
drain motor and ensure it is not jammed by a foreign object such as a
needle or a toothpick. It should be able to be turned by hand/finger-
the power IS OFF!
At this point it is also possible to test if the motor works. No clothes
or water in the machine, select a spin cycle and put the power back on.
You should be able to see the motor turning at some point, possibly
straight away. If it doesn't work then the motor is malfunctioning!"
Hope this helps.. Good luck! :)
SOURCE: I have a defy electrologic
My laundromaid washing machine is not cutting water after filling please help
