Question about Sony Playstation 3 (PS3) Console
The system turns on but there is no picture and it sounds the fan doesnt even start to run
  • 98 Answers
Try doing a display reset, Turn the PS3 off. Then turn it back on but once you turn it back on continue to hold the power button until you hear the beeps. It will reset your display. If that doesnt work let me know.
Posted on Aug 03, 2009
Ps3 will not recognize hdmi cable, cable is good
Posted on Aug 04, 2009
Just rebuilt top end of motor replaced everything I could think of to do with the radiator fans and they still won't kick on even when I turn on the defrost what else can I do?
My buddy used to have a car that he wired the fans to a toggle switch in the cab. I know it sounds bad, but its cheap & will get ya by till you figure it out
Jan 12, 2011 | 1996 Chevrolet Camaro
Ps3 wont stay on very long doesnt show up on the screen but no failure in light or anything also doesnt sound like its even running
hi sounds like , system fan not working.and if so for how long was it not working, might damaged the processer ,other components. thanks
Sep 29, 2010 | Sony Playstation 3 (PS3) Console
Fans stay on
Well, it really sounds like you don't have enough reserve power in the battery. You ought to be able to run that fan for 20 minutes, but still start the car. But that is a different topic.
If the switch is old, the points might be ever so lightly welding themselves together from arcing when the fan is needed. Then the switch needs to cool more than it otherwise would to pull the contacts apart.
I would replace the fan switch in the radiator before doing anything else.
That fan runs from time to time even when the coolant is not overheated. It is designed to prevent overheating, not to correct overheating once it occurs (though it will do that too, if it comes to that).
Jun 16, 2010 | 2002 Isuzu Rodeo Sport
2002 dodge status with new alternator and battery...wont charge batt once running and fan doesnt kick on automatically but works if manually turned on. any suggestions?
even thow alt is new it could be bad,,,the fan runs off a temp sender,,if it is bad it will not turn fan on,,,on fan runs off temp sender one run off your a/c or defroster,,if u get a chance to go to auto zone or advance auto they can ck out your charging system for free,,,, hoped it helped,,
Apr 25, 2010 | 2002 Dodge Stratus
My LG DLP RU-52SZ51D rear projection TV doesnt turn on.
See if Lamp Fan is running it can be defective and if Fan is OK it will be Ballast Board, Call Encompass Parts 1-800-638-3328
Dec 31, 2009 | LG RU-52SZ51D 52" Rear Projection...
Computer isnt running
If that is the case your system need to check the battery for fault and does it happen with the power source too i fthe same problem check your processor fan if its bad when you on the system and is not blowing that might have cause the processor itself to get bad you will have to change this ones and then your system will be ok right rate this solution.
Nov 27, 2008 | Toshiba Satellite A205-S4617 Notebook
Pc Seems to be dead wont load bios post moust doesnt work or keyboard or monitor
I have the same problem, the CPU fan spins, keyboard lights blink, no start up screen, or bios.
But, when I push a few times on the pc reset button, then the CPU fan is becoming still, the keyboard light are out and I can start the computer again in a normal way.
Can this one be a temporally solution for you too? Do you have any suggestion about?
I guess it can be an electricity dysfunction of a wrong fixed cable.
Oct 15, 2008 | Biostar P4M80-M4 Motherboard
Outside Fan Problems
TRY CHANGING THE CAP FIRST BUT MOST UNITS ONLY USE THE CAP TO START THE MOTOR NOT TO KEEP IT RUNNING SO IT SOUNDS LIKE YOU HAVE A BAD CAP AND THATS WHY IT DOESNT START HOWEVER IF IT STOPS RUNNING WITHOUT THE THERMOSTAT TELLING IT TO (OR IN THE MIDDLE OF A CYCLE) THEN YOUR RUN WINDING IN YOUR MOTOR IS GOING BAD YOU CAN REPLACE THIS MOTOR PRETTY EASY AND IF YOU USE AN AFTER MARKET INSTEAD OF AN OEM MOTOR YOU CAN SAVE YOURSELF ALOT OF MONEY. PS BE CAREFULL WHEN CHANGING YOUR CAP BECAUSE EVEN WITH THE POWER OFF IT CAN SHOCK YOU.AFTER SHUTTING THE POWER OFF USE AN INSULATED SCREWDRIVER AND TOUCH IT ACROSS THE POLES AT THE TOP OF THE CAP TO GROUND IT AND REMOVE POTENTIAL ENERGY.
Jul 22, 2008 | Weather King 10AJA2501AH Air Conditioner
Sub woofer its on for 3 sec..
your cooling fan is not engaging and coming on like its suppose to. One, the fan is probably burned out, which sucks because its low voltage and the only thing on the board that is low voltage. Two, there is a thermostat type component that tells the fan to start which HAS burned out and doesnt start the fan accordingly. If you look at the back fan and turn everything on you will see the fan either doesnt start or starts right as the relay trips turning the sound components off. If it starts at all your fans good.The thermostat component will need to be replace and I cant recommend a source. Just trying to explain the problem so you can look for the right repair. Hope it helps. I have one of these and have found this is the problem, but cant find the solution.
Apr 28, 2008 | JVC TH-M505 System
Sony Playstation 3 (PS3) Console Logo
358 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
