Question about Philips GoGear SA3245/37 Digital Media Player
How do i reset my gogear
Need to reset so i can snyc to computer...wont snyc to compter
    Sergeant:
  • 138 Answers
There is a needle size hole in the bottom next to the hold button. You are going to have to use something small like a needle to push it. Or you can hold the up button while plugging it in the computer.
Posted on Jul 30, 2009
My volume button broke
1 Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
2 Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager." This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button. Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode. Click the "Repair" button when it appears on your computer, then follow the steps to fully recover the GoGear. Properly disconnect your GoGear from your computer and restart the device.
3 Recharge your device if your GoGear dies suddenly while playing. Connect the GoGear to your computer via the supplied USB cord. Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on. This will begin the charging process of your GoGear. If recharging doesn't work, the battery may need to be replaced. Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
Apr 17, 2012 | Philips GoGear ViBE Digital Media Player
Wont come back on!
What OS are you using?
I know that it is not fully compatible in Vista.
1) Try using an XP machine and plug it in there, in any case, reformat the MP3 player using FAT.
2) Try uninstalling all software for your MP3 player from your PC and reinstalling it.
3) Here is something else you might want to try:
Try doing a soft reset.
  1. Press and hold the Power On/Off key and the Volume + key for a couple of seconds.
  2. Then switch on the GoGear using the Power On/Off key.
This is soft reset, your songs will not be lost.
4) If all else fails, it's time for a factory reset:
  1. Connect the GoGear to the AC adapter and to your computer.
  2. Make sure all other applications such as Philips Plug-in, Windows Media Player or Windows Explorer that access the device are closed or else Device Manager will not recognize the device. Launch the Device Manager at Start->Programs->Philips Device Manager->Philips Device Manager on your PC.
  3. Select the REPAIR tab on the dialogue box and then click "Repair" to start repairing.
    IMPORTANT: All music & content of your micro jukebox will be erased once the repair function completes. 051028091949_1746.gif 051028091949_1747.gif
  4. When repair is complete a dialogue box will pop up; click "OK" and unplug the GoGear from the computer. 051028091949_1748.gif
  5. Follow all the on-screen instructions to complete the repair.
  6. The Device Manager will close automatically once the success message is displayed. Close all opened applications and then unplug your GoGear.
  7. Once the GoGear is disconnected from the computer, the display will show “Firmware Upgrading” for a couple of seconds and then start up as usual.
Hope That Helps!
Dec 12, 2007 | Philips GoGear HDD6330 MP3 Player
How do you snyc from i tunes onto a go gear
Hi there. This is impossible as iTunes is a software produced by Apple for Apple products therefore iTunes will only be able to sync to Ipods, Iphones and Ipads and not to your Philips GoGear.
Please use the normal My Computer>Removable Device>respective folder such as music to transfer your files.
Please rate and comment, thank you.
Apr 28, 2011 | Philips GoGear HDD1830 MP3 Player
Go gear vibe has been frozen for about 25 min. wont shut off or anything
Hi, i stuck a pin in the reset hole, (to the right of the lock switch) and it shut it off, than all you have to do is turn it back on..
The Philips GoGear is a portable MP3 player with additional functionality such as the ability to record your voice or the radio. Some minor problems may develop in the device that keep if from working normally. The most common issues are the GoGear freezing, not powering on and memory-error messages. Troubleshoot your device to return your GoGear to normal operation.
Unresponsive
1. Your GoGear may not respond to button presses from time to time. This is often caused by an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
If the GoGear freezes after uploading a file to the device or if one song or sound file freezes the device each time you play it, the file is likely corrupt and needs to be removed from the GoGear. Connect the GoGear to a computer and delete the file from the device.
GoGear Does Not Power On
Problems with powering up the GoGear are often the result of an exhausted battery. If you cannot power on the GoGear, charge the battery with the supplied charger.
In some instances there is an error with the device that is keeping it from powering on. Unlike the errors that freeze the device, errors that keep it from powering on cannot be cleared by pressing the "Reset" button. The errors need to be fixed by using the "Firmware Manager." The Firmware Manager is a computer program that restores your device to their factory conditions. You will be able to use your device again after restoring it to factory conditions, but you will lose all of the data on your GoGear.
To use the Firmware Manager, open the installation CD supplied with your GoGear and follow the onscreen instructions to install the Firmware Manager on your computer. Plug the GoGear into the computer and check that your computer is connected to the Internet. Open "Firmware Manager" on your computer. You will be prompted to "Restore" the firmware or "Update" the firmware. Since you need to restore your device to working order, select the "Restore Firmware" option. Updating the firmware will not delete the files or errors that are causing the GoGear to malfunction.
Once the process is complete and your GoGear can power on again, consider updating the firmware. Updates give your device extra functionality and repair errors in the device.
Memory Full
The GoGear allows you to make voice or FM radio recordings and saves the recordings to the internal memory. The internal memory is limited and the GoGear may show the message "Memory Full" when trying to save recordings. When you receive this message, plug the device into the computer and delete any extraneous files or files you no longer want to keep on your device. This will free up memory so you can save more recordings or place additional music files on the GoGear.
Hope it helped..
Have a nice day.
Feb 22, 2011 | Philips GoGear ViBE Digital Media Player
Ive connected my mp3 to my compter and it usaully says charging or fully charged, or do not disconnect, and now it wont even show that or turn on. what should i do?
Try resetting the device it?s usually a small pinhole on the back or side of the device try holding that in for about 10 seconds
Oct 31, 2009 | Philips GoGear Flash MP3 Player
How do i fix my mp3 it dont turn on or show up when pluged into da computur
it shouldnt turn on anyway,and if it doesnt show up on da screen when plugged up then thats a real problem
Oct 07, 2009 | Philips GOGEAR SA6045 MP3 Player
Ipod wont show up on itunes
first try reainstalling itunes if that dosnt work try restoring your ipod.
Jul 09, 2008 | Apple iPod touch
My philips gogear wont turn on
Disconnect the GoGear from the computer
Reset it first (pinhole in back - safety pins work best), even if nothing happens - just to be on the safe side
Nothing will happen still, but we are OK
Make sure the power is off, and hold in the volume + button, reconnect the GoGear to the computer while holding in the volume + button, and continue holding volume + until a window pops us saying Found New Hardware Wizard
Go through the Found New Hardware Wizard, and the GoGear should be working again - the player will be revived
Write me back if this fails to resolve the problem.
-Tha Mp3 Doctor
Jun 17, 2008 | Philips GoGear HDD6330 MP3 Player
MY PHILIPS MP3 WONT TURN ON !!!!!!!GRRRRR I NEED HELPPPPPP!!!!PLIZZ
WARNING: this process will erase all songs off the GoGear.
Disconnect the GoGear from computer.
Turn the GoGear off.
Hold in the volume + button.
Reconnect the GoGear while holding in the volume + button.
Continue holding the volume + button.
After 5-50 seconds, Windows will pop-up a "Found New Hardware Wizard." - complete the wizard (BTW, you can take your hand ff the volume + button now).
Good To Go (Gear)!
-Tha Mp3 Doctor
Apr 04, 2008 | Philips SA5125/37 MP3 Player
Philips GoGear SA3245/37  Digital Media Player Logo
192 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
